1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: AAI/AAO database information
To: David Dudley <[email protected]>
Cc: [email protected]
Date: Mon, 06 Nov 2006 09:53:13 -0600
David Dudley wrote:
I've seen references to AAI and AAO records someplace, which I assume
are Array Analog Input and Output.  Is support for that put in the
device driver?
The aai and aao records are a bit of an anachronism; they're not really used very much, there's no soft or test device support included in Base, and they're not documented anywhere either. I think they were contributed by one site a long time ago, and we just haven't got around to removing them yet (they'll be gone if R3.15 is ever released).
I have a condition working with the Multilin control relays, where I
need to be able to generate a multiple register output sequence,
where the entire sequence is done in a single record. This would fit
that perfectly, I think.
Use a waveform record if you want device support where the whole array comes from a CA client. However if you're going to want to be able to set some individual elements from another record they you'll be much better off writing device support that takes the higher level parameters and combines them into the appropriate array/sequence internally.
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
Re: AAI/AAO database information Till Straumann
AAI/AAO database information David Dudley
Prev: about last edm problem marco_hair
Next: Support for Strings in database records.... David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: AAI/AAO database information David Dudley
Next: Re: AAI/AAO database information Till Straumann
