1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ant problem when building Irmis
To: Lecorche Eric <[email protected]>
Cc: [email protected]
Date: Tue, 07 Nov 2006 09:34:52 -0600
Hi Eric,
This is all very puzzling. If you are using java 1.4.2 and above you should not be having any of these problems. I feel like we are fixing symptoms, but not the basic problem. There seems to be something wrong with the java installation. Your solution for jsse.jar seems reasonable, but I can't explain why it does not accept that addition.
What hardware and operating system are you using?
If you type "java -version", what does it show?
Assuming you are on some kind of unix-like machine, what does the "which java" and "which javac" command display? I'm wondering if perhaps you have an old java JDK (pre 1.4.2) but a newer java JRE installed. The JDK is the full development kit with the javac compiler. The JRE is just the java runtime virtual machine (java). I'm wondering if you are compiling with an old javac.
What are your JAVA_HOME, ANT_HOME, and CLASSPATH environment variables set to?
Maybe this will help me with diagnosis.
regards, Claude
Lecorche Eric wrote:
Hi Claude,
Thanks to your help, I was so able to perform the "ant deploy" for the db directory ; to achieve properly that, I had to add the jce.jar and xml-apis.jar into the build.xml file
Now the problem comes for the apps directory, when running there "ant deploy" first I get the following error messages :
/compile:
[javac] Compiling 107 source files to /home/epics1/Irmis/irmisBase/apps/build/classes
[javac] /home/epics1/Irmis/irmisBase/apps/src/gov/anl/aps/irmis/login/DummySSLSocketFactory.java:7: error: ne peut repérer le package par défaut « javax.net.ssl ». Vérifier la variable d'environnement CLASSPATH et l'accès aux archives.
[javac] /home/epics1/Irmis/irmisBase/apps/src/gov/anl/aps/irmis/login/SimpleCallbackHandler.java:12: error: Superinterface `CallbackHandler' of class `gov.anl.aps.irmis.login.SimpleCallbackHandler' not found.
[javac] public class SimpleCallbackHandler implements CallbackHandler {
[javac] ^
[javac] /home/epics1/Irmis/irmisBase/apps/src/gov/anl/aps/irmis/login/SimpleCallbackHandler.java:22: error: Type `Callback' not found in the declaration of the argument `callbacks' of method `handle'.
[javac] public void handle(Callback[] callbacks)
[javac] ^
[javac] /home/epics1/Irmis/irmisBase/apps/src/gov/anl/aps/irmis/login/SimpleCallbackHandler.java:23: error: Class `UnsupportedCallbackException' not found in `throws'.
[javac] throws IOException, UnsupportedCallbackException {
[javac] ^
[javac] /home/epics1/Irmis/irmisBase/apps/src/gov/anl/aps/irmis/login/SimpleCallbackHandler.java:33: error: Type `NameCallback' not found in the declaration of the local variable `nc'.
[javac] NameCallback nc = (NameCallback)callbacks[i];
[javac] ^
[javac] /home/epics1/Irmis/irmisBase/apps/src/gov/anl/aps/irmis/login/SimpleCallbackHandler.java:41: error: Type `PasswordCallback' not found in the declaration of the local variable `pc'.
[javac] PasswordCallback pc = (PasswordCallback)callbacks[i];
[javac] ^
[javac] /home/epics1/Irmis/irmisBase/apps/src/gov/anl/aps/irmis/login/PersonRoleLoginModule.java:27: error: Superinterface `LoginModule' of class `gov.anl.aps.irmis.login.PersonRoleLoginModule' not found.
[javac] public class PersonRoleLoginModule implements LoginModule {/
[... may other errors ...]
/[javac] /home/epics1/Irmis/irmisBase/apps/src/gov/anl/aps/irmis/apps/pv/cfw/PVWindow.java:0: internal compiler error: Erreur de segmentation
[javac] SVP soumettre un rapport complet d'anomalies,
[javac] avec le source pré-traité si cela est approprié.
[javac] Consulter <URL:http://bugzilla.redhat.com/bugzilla/> pour les instructions.
So I imagined to do the same as for the db directory : we found that the javax.net.ssl package was in the jsse.jar file and I added the path to this jar file. Therefore, I get the following errors
c/ompile:
[javac] /home/epics1/Irmis/irmisBase/apps/src/CFWDemo/DemoDocument.java:0: error: archive .zip mal composée dans CLASSPATH: /usr/java/jre/lib/jsse.jar/
/[... same errors as in the first case ... ]
So first it does not solve the problem (javax.net.ssl is no longer found) and furthermore a new error occurs telling that "the archive .zip is badly organized into /usr/java/jre/lib/jsse.jar"). As I didn't find anything concerning this error and not being a Java expert, I don't manage to go further at this point ...
Any new idea to help me to get out from this ?
Thanks in advance
Eric
Re: ant problem when building Irmis Lecorche Eric
Re: ant problem when building Irmis Claude Saunders
Prev: Re: ant problem when building Irmis Lecorche Eric
Next: channel access client performance and gateway Rowland, J (James)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: ant problem when building Irmis Lecorche Eric
