1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Scaling Database entries
To: Dirk Zimoch <[email protected]>
Cc: [email protected]
Date: Wed, 15 Nov 2006 10:44:59 -0600
Dirk Zimoch wrote:
if you driver does not set ESLO and EOFF, you can set it in your db. Calculate manually what to set. I did the same with StreamDevice.
Don't forget to set LINR to "LINEAR", of course.
If you want to set ESLO and EOFF yourself, you should set LINR to "SLOPE" rather than "LINEAR" or there's a danger the device support will overwrite your values if someone modifies any of the conversion fields. StreamDevice might not do so if it doesn't have a special_linconv routine, but then it's not following the full ai/ao standard. Most analog device supports will overwrite ESLO and EOFF; by relying on non- standard behaviour you're making it harder for someone to replace hardware using a StreamDevice interface with some other device, because they now have to change more than just the DTYP and INP/OUT field of their database records when they move (and they might not realize that).
StreamDevice should have some way for the author of a protocol file to specify what the device's raw range actually is for analog records, and it should perform the calculation of ESLO and EOFF from that raw range and the EGUL+EGUF pair. The other option you might want to support if you don't already would be to control whether any conversions get done at all - many instruments return engineering units anyway, and that's why the analog records allow the device layer to set the VAL field directly and return 2. This is used a lot for GPIB instrumentation.
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
Re: Scaling Database entries Dirk Zimoch
RE: Scaling Database entries David Dudley
Prev: Re: Scaling Database entries Dirk Zimoch
Next: EtherIP driver, BOOL tags Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Scaling Database entries Dirk Zimoch
