1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Naming conventions for devices and Epics records
Cc: tech talk <[email protected]>
Date: Fri, 17 Nov 2006 12:33:20 -0500
It's true that we have had problems with the sequencer going over 28
characters, but I think they're less of a problem than it would be to
try to stay within 28 characters.
> -----Original Message-----
> From: Andrew Johnson [mailto:[email protected]]
> Sent: Friday, November 17, 2006 12:28 PM
> Cc: tech talk
> Subject: Re: Naming conventions for devices and Epics records
> I would also suggest that you try *really* hard to limit your record
> names to the maximum recommended 28 characters.  You *can* make them
> longer (up to 60 characters), but until the EPICS 40 character string
> length limit goes away (which means until the Channel Access protocol
> gets revised and the database and all of the tools are modified to use
> variable length strings) using longer names *will* end up causing you
> difficulties.  SNS thought they had got away with using longer names
but
> they found problems with long strings in the SNC/Sequencer, which I
> don't think they've managed to fix.
> Why is the recommended limit only 28 characters?  Well if you want to
> change a link field via Channel Access you only have 40 characters to
> hold the complete link value, and as well as the record name the link
> might need dot field name (5 chars with the standard record types) and
> the flags NPP/PP/CA/CP/CPP and NMS/MS which will need another 7 chars
> (you can omit the space between them if necessary, but not the one
that
> terminates the field name).  That leaves just 28 characters for the
> name, and yes I am allowed to leave the terminating \0 byte out of
that
> calculation.
> - Andrew
> There is considerable overlap between the intelligence of the smartest
> bears and the dumbest tourists -- Yosemite National Park Ranger
GOOD Naming conventions for devices and Epics records Emmanuel Mayssat
Re: Naming conventions for devices and Epics records Andrew Johnson
Prev: Re: Naming conventions for devices and Epics records Andrew Johnson
Next: GOOD Naming conventions for devices and Epics records Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
