I think what is important in this thread is not what naming convention
is being used at site X, but rather what makes a GOOD naming convention.
Here is what I learned from naming conventions with epics.
1/ I like to know which hardware part is providing the signal.
This provides a tremendous help for low level debugging.
(ex. Signals is from pin 2 on ADC 3 on computer X [located at Y])
2/ End user cares about the meaning of the signal.
(ex. Temperature of gun, setting of 3rd magnet in transport line)
3/ PV names are often found hardcoded in programs
4/ Low level and high level programming is managed by 2 different
groups.
Solution:
Use several (two) naming conventions!
One for each level and use ALIASING!!!!!
Q: What happens if you change hardware?
You change the low level PV names and the inputs of aliases.
No need to change programs, striptools configuration files, etc.
Enjoy!
Emmanuel Mayssat
Lyncean Technologies, Inc
On Fri, 2006-11-17 at 12:33 -0500, Gurd, Pamela A. wrote:
> It's true that we have had problems with the sequencer going over 28
> characters, but I think they're less of a problem than it would be to
> try to stay within 28 characters.
- RE: GOOD Naming conventions for devices and Epics records Gurd, Pamela A.
- RE: GOOD Naming conventions for devices and Epics records Chestnut, Ronald P.
- RE: Naming conventions for devices and Epics records Gurd, Pamela A.
<2006>
2025
2026
<2006>
2025
2026
