Subject: |
RE: GOOD Naming conventions for devices and Epics records |
"Lawrence T. Hoff" <[email protected]> |
To: |
[email protected] |
Date: |
Fri, 17 Nov 2006 22:16:01 -0500 |
I think what is important in this thread is not what naming convention
is being used at site X, but rather what makes a GOOD naming convention.
Here is what I learned from naming conventions with epics.
1/ I like to know which hardware part is providing the signal.
This provides a tremendous help for low level debugging.
(ex. Signals is from pin 2 on ADC 3 on computer X [located at Y])
2/ End user cares about the meaning of the signal.
(ex. Temperature of gun, setting of 3rd magnet in transport line)
3/ PV names are often found hardcoded in programs
4/ Low level and high level programming is managed by 2 different
groups.
Solution:
Use several (two) naming conventions!
One for each level and use ALIASING!!!!!
There is clearly a need to maintain both "mission oriented" and
"hardware oriented" mechanisms for referring to channels. The former is
needed for facility operation, and the latter for tasks such as
installation,
debug, and maintenance.
Aliases are not the only way of achieving this. Other alternatives
generally use the "mission oriented" name as a key to lookup the
"hardware oriented" channel description.
It may be a matter of personal preference which technique seems
most natural. Facilities which make good use of DBs to manage their
H/W configuration might wonder why this is even a subject of
discussion!
In the absence of a comprehensive configuration DB, the
alias solution seems to offer substantial benefit. Even in the
presence of a configuration DB, the alias solution seems very
natural to me (FWIW).
-- Larry
RE: Naming conventions for devices and Epics records Purcell, J. David
Error while cross-compiling EPICS for arm éæç
<2006>
2025
2026
<2006>
2025
2026
