1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Error while cross-compiling EPICS for arm
To: tech talk <[email protected]>
Date: Sat, 18 Nov 2006 13:10:26 +0800
I have been working with cross-compiling EPICS for arm, but the ioc
application can't run on the target.
Building EPICS for linux-arm on the host
1.  Install a suitable cross compiler.  This release was built with a
version
of gcc 3.3.3 configured as a cross compiler with prefix arm-linux.  Let
ARM_LINUX_GCC be the root of the compiler, so that GCC is available as
$ARM_LINUX_GCC/bin/arm-linux-gcc.
2.  Extract EPICS from
    http://www.aps.anl.gov/epics/download/base/baseR3.14.8.2.tar.gz into
a
suitable directory.  Let EPICS_BASE be the path to the root directory of
this
distribution.
3.  Apply the patch thus:
    $ cd $EPICS_BASE
    $ patch -p0 <$LIBERA_EPICS/install/patch-epics-3.14.8.2
4.  Editing the site configuration file
    $EPICS_BASE/configure/os/CONFIG_SITE.linux-x86.linux-arm
and defining
    GNU_DIR=<expansion of ARM_LINUX_GCC>
5.  Make sure that linux-arm is included as a cross compiler target
architecture, by editing
    $EPICS_BASE/configure/CONFIG_SITE
and defining
    CROSS_COMPILER_TARGET_ARCHS=linux-arm
6.  Run make from $EPICS_BASE.  This will take a while...
    $ cd $EPICS_BASE
    $ make
Creating a example ioc application on the host
1.  mkdir <top>
    cd <top>
2.  $EPICS_BASE/bin/linux-x86/makeBaseApp.pl -t example myexample
    $EPICS_BASE/bin/linux-x86/makeBaseApp.pl -i -t example myexample
The following target architectures are available in base:
    linux-arm
    linux-x86
What architecture do you want to use? linux-arm
3.  Run make.
    $ make linux-arm
Run the ioc example on the target
1.  cd <top>/iocBoot/iocmyexample
2.  ../../bin/linux-arm/myexample st.cmd
The error appear:
../../bin/linux-arm/myexample: relocation
error: ../../bin/linux-arm/myexample: undefined symbol: pvar_func_asSub
What's wrong?
Thanks in advance
Yan Yingbing
SSRF BI group
Re: Error while cross-compiling EPICS for arm Michael Abbott
Re: Error while cross-compiling EPICS for arm Andrew Johnson
Prev: RE: GOOD Naming conventions for devices and Epics records Lawrence T. Hoff
Next: Re: Error while cross-compiling EPICS for arm Michael Abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
