1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Error while cross-compiling EPICS for arm
Cc: tech talk <[email protected]>
Date: Tue, 21 Nov 2006 11:56:54 +0800
> Have you made any modifications to your EPICS Base or the application
> area at all?  Please show us more of the output from make around the
> error message.
I have made only three modifications to my EPICS Base.
	1.  Apply the patch thus:
	    $ cd $EPICS_BASE
	    $ patch -p0 <$LIBERA_EPICS/install/patch-epics-3.14.8.2
	2.  Editing the site configuration file
$EPICS_BASE/configure/os/CONFIG_SITE.linux-x86.linux-arm and defining
	GNU_DIR=<expansion of ARM_LINUX_GCC>
	3.  Make sure that linux-arm is included as a cross compiler target
architecture, by editing $EPICS_BASE/configure/CONFIG_SITE and defining
    	CROSS_COMPILER_TARGET_ARCHS=linux-arm
I have not made any modifications to the application area. The output
from make the ioc application are shown below, and the output from make
my EPICS Base are attached in the file base_make_output.
make -C configure install
make[1]: Entering directory `/usr/local/epics/yan/configure'
perl ../../base-3.14.8.2/configure/tools/convertRelease.pl -h linux-x86
checkRelease
perl ../../base-3.14.8.2/configure/tools/makeMakefile.pl
O.linux-x86 ../..
O.linux-arm ../..
mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../.. T_A=linux-x86 install
make[2]: Entering directory `/usr/local/epics/yan/configure/O.linux-x86'
perl ../../../base-3.14.8.2/configure/tools/convertRelease.pl -h
linux-x86 CONFIG_APP_INCLUDE
linux-x86 RULES_INCLUDE
make[2]: Leaving directory `/usr/local/epics/yan/configure/O.linux-x86'
make -C O.linux-arm -f ../Makefile TOP=../.. T_A=linux-arm install
make[2]: Entering directory `/usr/local/epics/yan/configure/O.linux-arm'
make[2]: Leaving directory `/usr/local/epics/yan/configure/O.linux-arm'
make[1]: Leaving directory `/usr/local/epics/yan/configure'
make -C myexampleApp install
make[1]: Entering directory `/usr/local/epics/yan/myexampleApp'
make -C src install
make[2]: Entering directory `/usr/local/epics/yan/myexampleApp/src'
perl ../../../base-3.14.8.2/configure/tools/makeMakefile.pl
O.linux-x86 ../../..
O.linux-arm ../../..
mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[3]: Entering directory
`/usr/local/epics/yan/myexampleApp/src/O.linux-x86'
make[3]: Leaving directory
perl ../../../../base-3.14.8.2/configure/tools/makeIncludeDbd.pl
base.dbd xxxSupport.dbd dbSubExample.dbd
myexampleHello.dbd ../O.Common/myexampleInclude.dbd
Expanding dbd
../../../../base-3.14.8.2/bin/linux-x86/dbExpand  -I . -I ..
-I ../../../dbd -I ../../../../base-3.14.8.2/dbd
-o ../O.Common/myexample.dbd ../O.Common/myexampleInclude.dbd
Installing dbd file ../../../dbd/xxxSupport.dbd
mkdir ../../../dbd
Installing dbd file ../../../dbd/myexample.dbd
Installing dbd file ../../../dbd/xxxRecord.dbd
../../../../base-3.14.8.2/bin/linux-x86/dbToRecordtypeH  -I . -I ..
-I ../../../dbd
-I ../../../../base-3.14.8.2/dbd  ../xxxRecord.dbd ../O.Common/xxxRecord.h
Installing generated generic include file ../../../include/xxxRecord.h
mkdir ../../../include
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux
-D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I..
-I../../../include/os/Linux -I../../../include
-I../../../../base-3.14.8.2/include/os/Linux
-I../../../../base-3.14.8.2/include        ../xxxRecord.c
-I../../../../base-3.14.8.2/include        ../devXxxSoft.c
/usr/bin/ar -rc   libxxxSupport.a      xxxRecord.o devXxxSoft.o
/usr/bin/ranlib libxxxSupport.a
Installing library ../../../lib/linux-x86/libxxxSupport.a
mkdir ../../../lib
mkdir ../../../lib/linux-x86
/usr/bin/ranlib ../../../lib/linux-x86/libxxxSupport.a
/usr/bin/g++ -o libxxxSupport.so -shared -fPIC
-L../../../../base-3.14.8.2/lib/linux-x86/
-Wl,-rpath,/usr/local/epics/yan/lib/linux-x86
-Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86
xxxRecord.o devXxxSoft.o    -lrecIoc -lsoftDevIoc -liocsh -lmiscIoc
-lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca
-lCom  -lpthread   -lreadline -lcurses -lm -lrt -lgcc
Installing shared library ../../../lib/linux-x86/libxxxSupport.so
perl ../../../../base-3.14.8.2/bin/linux-x86/registerRecordDeviceDriver.pl ../O.Common/myexample.dbd myexample_registerRecordDeviceDriver > temp.cpp
mv temp.cpp myexample_registerRecordDeviceDriver.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I..
-I../../../../base-3.14.8.2/include        ../dbSubExample.c
-I../../../../base-3.14.8.2/include        ../myexampleHello.c
-I../../../../base-3.14.8.2/include        ../myexampleMain.cpp
/usr/bin/g++ -o myexample  -L../../../../base-3.14.8.2/lib/linux-x86/
-L../../../lib/linux-x86//
myexample_registerRecordDeviceDriver.o dbSubExample.o myexampleHello.o
myexampleMain.o    -lxxxSupport -lrecIoc -lsoftDevIoc -liocsh -lmiscIoc
-lCom
Installing binary ../../../bin/linux-x86/myexample
mkdir ../../../bin
mkdir ../../../bin/linux-x86
make -C O.linux-arm -f ../Makefile TOP=../../.. T_A=linux-arm install
`/usr/local/epics/yan/myexampleApp/src/O.linux-arm'
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c
-D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500
-D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3
-Wall          -fPIC -I. -I.. -I../../../include/os/Linux
-I../../../include -I../../../../base-3.14.8.2/include/os/Linux
-I/usr/local/armlinux/3.3.3/arm-linux/include  ../xxxRecord.c
-I/usr/local/armlinux/3.3.3/arm-linux/include  ../devXxxSoft.c
/usr/local/armlinux/3.3.3/bin/arm-linux-ar -rc   libxxxSupport.a
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib libxxxSupport.a
Installing library ../../../lib/linux-arm/libxxxSupport.a
mkdir ../../../lib/linux-arm
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib ../../../lib/linux-arm/libxxxSupport.a
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o libxxxSupport.so -shared
-fPIC -L../../../../base-3.14.8.2/lib/linux-arm/
-L/usr/local/armlinux/3.3.3/arm-linux/lib
-Wl,-rpath-link,../../../lib/linux-arm
-Wl,-rpath-link,../../../../base-3.14.8.2/lib/linux-arm
-lCom  -lpthread    -lm -lrt -lgcc
Installing shared library ../../../lib/linux-arm/libxxxSupport.so
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c
-Wall           -I. -I.. -I../../../include/os/Linux -I../../../include
-I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbSubExample.c
-I/usr/local/armlinux/3.3.3/arm-linux/include  ../myexampleHello.c
-I/usr/local/armlinux/3.3.3/arm-linux/include  ../myexampleMain.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o myexample
-L../../../../base-3.14.8.2/lib/linux-arm/ -L../../../lib/linux-arm//
-lCom
Installing binary ../../../bin/linux-arm/myexample
mkdir ../../../bin/linux-arm
make[2]: Leaving directory `/usr/local/epics/yan/myexampleApp/src'
make -C Db install
make[2]: Entering directory `/usr/local/epics/yan/myexampleApp/Db'
mkdir O.Common
`/usr/local/epics/yan/myexampleApp/Db/O.linux-x86'
Installing db file ../../../db/dbExample1.db
mkdir ../../../db
Installing db file ../../../db/dbExample2.db
Installing db file ../../../db/dbSubExample.db
`/usr/local/epics/yan/myexampleApp/Db/O.linux-arm'
make[3]: Nothing to be done for `install'.
make[2]: Leaving directory `/usr/local/epics/yan/myexampleApp/Db'
make[1]: Leaving directory `/usr/local/epics/yan/myexampleApp'
make -C iocBoot install
make[1]: Entering directory `/usr/local/epics/yan/iocBoot'
make -C iocmyexample install
make[2]: Entering directory `/usr/local/epics/yan/iocBoot/iocmyexample'
perl ../../../base-3.14.8.2/configure/tools/convertRelease.pl -a
linux-arm envPaths
make[2]: Leaving directory `/usr/local/epics/yan/iocBoot/iocmyexample'
make[1]: Leaving directory `/usr/local/epics/yan/iocBoot'
make[1]: Entering directory `/usr/local/epics/base-3.14.8.2/configure'
perl ../configure/tools/makeMakefile.pl O.linux-x86 ../..
perl ../configure/tools/makeMakefile.pl O.linux-arm ../..
mkdir O.Common
make[2]: Entering directory `/usr/local/epics/base-3.14.8.2/configure/O.linux-x86'
perl ../../configure/tools/convertRelease.pl -h linux-x86 CONFIG_APP_INCLUDE
make[2]: Leaving directory `/usr/local/epics/base-3.14.8.2/configure/O.linux-x86'
make[2]: Entering directory `/usr/local/epics/base-3.14.8.2/configure/O.linux-arm'
make[2]: Leaving directory `/usr/local/epics/base-3.14.8.2/configure/O.linux-arm'
make[1]: Leaving directory `/usr/local/epics/base-3.14.8.2/configure'
make -C src install
make[1]: Entering directory `/usr/local/epics/base-3.14.8.2/src'
make -C makeBaseApp install
make[2]: Entering directory `/usr/local/epics/base-3.14.8.2/src/makeBaseApp'
perl ../../configure/tools/makeMakefile.pl O.linux-x86 ../../..
perl ../../configure/tools/makeMakefile.pl O.linux-arm ../../..
mkdir O.Common
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/makeBaseApp/O.linux-x86'
Installing script ../../../bin/linux-x86/makeBaseApp.pl
mkdir ../../../bin
Installing ../../../templates/makeBaseApp/top/Makefile
mkdir ../../../templates
mkdir ../../../templates/makeBaseApp
mkdir ../../../templates/makeBaseApp/top
Installing ../../../templates/makeBaseApp/top/configure/CONFIG
mkdir ../../../templates/makeBaseApp/top/configure
Installing ../../../templates/makeBaseApp/top/configure/CONFIG_APP
Installing ../../../templates/makeBaseApp/top/configure/Makefile
Installing ../../../templates/makeBaseApp/top/configure/RELEASE
Installing ../../../templates/makeBaseApp/top/configure/RULES
Installing ../../../templates/makeBaseApp/top/configure/RULES.ioc
Installing ../../../templates/makeBaseApp/top/configure/RULES_DIRS
Installing ../../../templates/makeBaseApp/top/configure/RULES_TOP
Installing ../../../templates/makeBaseApp/top/supportApp/Makefile
mkdir ../../../templates/makeBaseApp/top/supportApp
Installing ../../../templates/makeBaseApp/top/supportApp/Db/Makefile
mkdir ../../../templates/makeBaseApp/top/supportApp/Db
Installing ../../../templates/makeBaseApp/top/supportApp/src/Makefile
mkdir ../../../templates/makeBaseApp/top/supportApp/src
Installing ../../../templates/makeBaseApp/top/supportApp/src/_APPNAME_.dbd
Installing ../../../templates/makeBaseApp/top/iocApp/Makefile
mkdir ../../../templates/makeBaseApp/top/iocApp
Installing ../../../templates/makeBaseApp/top/iocApp/Db/Makefile
mkdir ../../../templates/makeBaseApp/top/iocApp/Db
Installing ../../../templates/makeBaseApp/top/iocApp/src/Makefile
mkdir ../../../templates/makeBaseApp/top/iocApp/src
Installing ../../../templates/makeBaseApp/top/iocApp/src/_APPNAME_Main.cpp
Installing ../../../templates/makeBaseApp/top/iocApp/src/sncExample.stt
Installing ../../../templates/makeBaseApp/top/exampleApp/Makefile
mkdir ../../../templates/makeBaseApp/top/exampleApp
Installing ../../../templates/makeBaseApp/top/exampleApp/Db/Makefile
mkdir ../../../templates/makeBaseApp/top/exampleApp/Db
Installing ../../../templates/makeBaseApp/top/exampleApp/Db/dbExample1.db
Installing ../../../templates/makeBaseApp/top/exampleApp/Db/dbExample2.db
Installing ../../../templates/makeBaseApp/top/exampleApp/Db/dbSubExample.db
Installing ../../../templates/makeBaseApp/top/exampleApp/src/Makefile
mkdir ../../../templates/makeBaseApp/top/exampleApp/src
Installing ../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.dbd
Installing ../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.c
Installing ../../../templates/makeBaseApp/top/exampleApp/src/devXxxSoft.c
Installing ../../../templates/makeBaseApp/top/exampleApp/src/xxxSupport.dbd
Installing ../../../templates/makeBaseApp/top/exampleApp/src/sncExample.stt
Installing ../../../templates/makeBaseApp/top/exampleApp/src/sncProgram.st
Installing ../../../templates/makeBaseApp/top/exampleApp/src/sncExample.dbd
Installing ../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.c
Installing ../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.dbd
Installing ../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Main.cpp
Installing ../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.c
Installing ../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.dbd
Installing ../../../templates/makeBaseApp/top/exampleBoot/Makefile
mkdir ../../../templates/makeBaseApp/top/exampleBoot
Installing ../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@vxWorks
Installing ../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@RTEMS
Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@Common
mkdir ../../../templates/makeBaseApp/top/exampleBoot/ioc
Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@vxWorks
Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@Common
Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@Cross
Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@vxWorks
Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@RTEMS
Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/README@Common
Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/README@vxWorks
Installing ../../../templates/makeBaseApp/top/caClientApp/Makefile
mkdir ../../../templates/makeBaseApp/top/caClientApp
Installing ../../../templates/makeBaseApp/top/caClientApp/caExample.c
Installing ../../../templates/makeBaseApp/top/caClientApp/caMonitor.c
Installing ../../../templates/makeBaseApp/top/caServerApp/Makefile
mkdir ../../../templates/makeBaseApp/top/caServerApp
Installing ../../../templates/makeBaseApp/top/caServerApp/README
Installing ../../../templates/makeBaseApp/top/caServerApp/exAsyncPV.cc
Installing ../../../templates/makeBaseApp/top/caServerApp/exChannel.cc
Installing ../../../templates/makeBaseApp/top/caServerApp/exPV.cc
Installing ../../../templates/makeBaseApp/top/caServerApp/exScalarPV.cc
Installing ../../../templates/makeBaseApp/top/caServerApp/exServer.cc
Installing ../../../templates/makeBaseApp/top/caServerApp/exServer.h
Installing ../../../templates/makeBaseApp/top/caServerApp/exVectorPV.cc
Installing ../../../templates/makeBaseApp/top/caServerApp/main.cc
Installing ../../../templates/makeBaseApp/top/caServerApp/test.adl
Installing ../../../templates/makeBaseApp/top/caServerApp/vxEntry.cc
Installing ../../../templates/makeBaseApp/top/iocBoot/Makefile
mkdir ../../../templates/makeBaseApp/top/iocBoot
Installing ../../../templates/makeBaseApp/top/iocBoot/nfsCommands@vxWorks
Installing ../../../templates/makeBaseApp/top/iocBoot/nfsCommands@RTEMS
Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@Common
mkdir ../../../templates/makeBaseApp/top/iocBoot/ioc
Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@vxWorks
Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Common
Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Cross
Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@vxWorks
Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@RTEMS
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/makeBaseApp/O.linux-x86'
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/makeBaseApp/O.linux-arm'
Installing script ../../../bin/linux-arm/makeBaseApp.pl
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/makeBaseApp/O.linux-arm'
make[2]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/makeBaseApp'
make -C makeBaseExt install
make[2]: Entering directory `/usr/local/epics/base-3.14.8.2/src/makeBaseExt'
mkdir O.Common
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/makeBaseExt/O.linux-x86'
Installing script ../../../bin/linux-x86/makeBaseExt.pl
Installing ../../../templates/makeBaseExt/top/Makefile
mkdir ../../../templates/makeBaseExt
mkdir ../../../templates/makeBaseExt/top
Installing ../../../templates/makeBaseExt/top/README
Installing ../../../templates/makeBaseExt/top/configure/CONFIG
mkdir ../../../templates/makeBaseExt/top/configure
Installing ../../../templates/makeBaseExt/top/configure/CONFIG_EXTENSIONS
Installing ../../../templates/makeBaseExt/top/configure/Makefile
Installing ../../../templates/makeBaseExt/top/configure/RELEASE
Installing ../../../templates/makeBaseExt/top/configure/RULES
Installing ../../../templates/makeBaseExt/top/configure/RULES_DIRS
Installing ../../../templates/makeBaseExt/top/configure/RULES_TOP
Installing ../../../templates/makeBaseExt/top/configure/RULES_PYTHON
Installing ../../../templates/makeBaseExt/top/configure/RULES_IDL
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG.linux-x86.linux-386
mkdir ../../../templates/makeBaseExt/top/configure/os
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc.aix-ppc
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc-gnu.aix-ppc-gnu
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.Common.Common
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.cygwin-x86.cygwin-x86
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppc.darwin-ppc
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.hpux-parisc-gnu.hpux-parisc-gnu
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.hpux-parisc.hpux-parisc
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-borland.linux-x86-borland
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-athlon
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-x86
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.osf-alpha.osf-alpha
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-gnu.solaris-sparc-gnu
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc.solaris-sparc
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-gnu.solaris-x86-gnu
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86.solaris-x86
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-borland.win32-x86-borland
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86.win32-x86
Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG.win32-x86-borland.win32-x86-borland
Installing ../../../templates/makeBaseExt/top/src/Makefile
mkdir ../../../templates/makeBaseExt/top/src
Installing ../../../templates/makeBaseExt/top/exampleExt/Makefile
mkdir ../../../templates/makeBaseExt/top/exampleExt
Installing ../../../templates/makeBaseExt/top/exampleExt/caExample.c
Installing ../../../templates/makeBaseExt/top/exampleExt/RELEASE_NOTES.HTM
Installing ../../../templates/makeBaseExt/top/simpleExt/Makefile
mkdir ../../../templates/makeBaseExt/top/simpleExt
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/makeBaseExt/O.linux-x86'
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/makeBaseExt/O.linux-arm'
Installing script ../../../bin/linux-arm/makeBaseExt.pl
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/makeBaseExt/O.linux-arm'
make[2]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/makeBaseExt'
make -C libCom install
make[2]: Entering directory `/usr/local/epics/base-3.14.8.2/src/libCom'
mkdir O.Common
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/libCom/O.linux-x86'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/libCom/O.linux-x86'
perl ../../../src/libCom/misc/makeEpicsVersion.pl ../../../configure/CONFIG_BASE_VERSION ../O.Common
Building epicsVersion.h from ../../../configure/CONFIG_BASE_VERSION
Found EPICS Version 3.14.8.2
Installing generated generic include file ../../../include/epicsVersion.h
Installing generic include file ../../../include/bucketLib.h
Installing generic include file ../../../include/epicsRingPointer.h
Installing generic include file ../../../include/epicsRingBytes.h
Installing generic include file ../../../include/postfix.h
Installing generic include file ../../../include/cvtFast.h
Installing generic include file ../../../include/epicsAlgorithm.h
Installing generic include file ../../../include/epicsExcept.h
Installing generic include file ../../../include/epicsMemory.h
Installing generic include file ../../../include/resourceLib.h
Installing generic include file ../../../include/tsDLList.h
Installing generic include file ../../../include/tsSLList.h
Installing generic include file ../../../include/tsMinMax.h
Installing generic include file ../../../include/tsBTree.h
Installing generic include file ../../../include/tsFreeList.h
Installing generic include file ../../../include/epicsSingleton.h
Installing generic include file ../../../include/epicsGuard.h
Installing generic include file ../../../include/epicsOnce.h
Installing generic include file ../../../include/dbmf.h
Installing generic include file ../../../include/ellLib.h
Installing generic include file ../../../include/envDefs.h
Installing generic include file ../../../include/epicsPrint.h
Installing generic include file ../../../include/errMdef.h
Installing generic include file ../../../include/errSymTbl.h
Installing generic include file ../../../include/errlog.h
Installing generic include file ../../../include/error.h
Installing generic include file ../../../include/fdManager.h
Installing generic include file ../../../include/fdmgr.h
Installing generic include file ../../../include/freeList.h
Installing generic include file ../../../include/gpHash.h
Installing generic include file ../../../include/iocLog.h
Installing generic include file ../../../include/logClient.h
Installing generic include file ../../../include/macLib.h
Installing generic include file ../../../include/adjustment.h
Installing generic include file ../../../include/cantProceed.h
Installing generic include file ../../../include/dbDefs.h
Installing generic include file ../../../include/epicsConvert.h
Installing generic include file ../../../include/epicsExit.h
Installing generic include file ../../../include/epicsStdlib.h
Installing generic include file ../../../include/epicsString.h
Installing generic include file ../../../include/epicsTypes.h
Installing generic include file ../../../include/gsd_sync_defs.h
Installing generic include file ../../../include/shareLib.h
Installing generic include file ../../../include/epicsExport.h
Installing generic include file ../../../include/unixFileName.h
Installing generic include file ../../../include/locationException.h
Installing generic include file ../../../include/ipAddrToAsciiAsynchronous.h
Installing generic include file ../../../include/compilerDependencies.h
Installing generic include file ../../../include/os/Linux/osiFileName.h
mkdir ../../../include/os
mkdir ../../../include/os/Linux
Installing generic include file ../../../include/osiSock.h
Installing generic include file ../../../include/os/Linux/osdSock.h
Installing generic include file ../../../include/epicsInterrupt.h
Installing os dependent include file ../../../include/os/Linux/osdInterrupt.h
Installing generic include file ../../../include/epicsMutex.h
Installing os dependent include file ../../../include/os/Linux/osdMutex.h
Installing generic include file ../../../include/epicsEvent.h
Installing os dependent include file ../../../include/os/Linux/osdEvent.h
Installing os dependent include file ../../../include/os/Linux/epicsMath.h
Installing os dependent include file ../../../include/os/Linux/osdMessageQueue.h
Installing os dependent include file ../../../include/os/Linux/osdStrtod.h
Installing generic include file ../../../include/epicsAssert.h
Installing generic include file ../../../include/epicsFindSymbol.h
Installing generic include file ../../../include/osiPoolStatus.h
Installing os dependent include file ../../../include/os/Linux/osdPoolStatus.h
Installing os dependent include file ../../../include/os/Linux/osdThread.h
Installing generic include file ../../../include/epicsThread.h
Installing generic include file ../../../include/epicsTime.h
Installing generic include file ../../../include/os/Linux/osdTime.h
Installing generic include file ../../../include/epicsSignal.h
Installing generic include file ../../../include/osiProcess.h
Installing generic include file ../../../include/os/Linux/osiUnistd.h
Installing os dependent include file ../../../include/os/Linux/osiWireFormat.h
Installing os dependent include file ../../../include/os/Linux/epicsReadline.h
Installing generic include file ../../../include/epicsMessageQueue.h
Installing generic include file ../../../include/epicsStdio.h
Installing generic include file ../../../include/epicsStdioRedirect.h
Installing os dependent include file ../../../include/os/Linux/epicsGetopt.h
Installing generic include file ../../../include/devLib.h
Installing os dependent include file ../../../include/os/Linux/osdVME.h
Installing generic include file ../../../include/taskwd.h
Installing generic include file ../../../include/epicsTimer.h
Installing generic include file ../../../include/tsDefs.h
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/bucketLib/bucketLib.c
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/ring/epicsRingPointer.cpp
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/ring/epicsRingBytes.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/calc/postfix.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/calc/calcPerform.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/cvtFast/cvtFast.c
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/cxxTemplates/resourceLib.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/cxxTemplates/epicsOnce.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/cxxTemplates/epicsSingletonMutex.cpp
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/dbmf/dbmf.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/ellLib/ellLib.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/env/envSubr.c
perl ../../../src/libCom/env/bldEnvData.pl ../../../configure
Generating envData.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         envData.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/error/errlog.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/error/errSymLib.c
perl ../../../src/libCom/error/makeStatTbl.pl  ../../../src/libCom/osi/devLib.h ../../../src/as/asLib.h ../../../src/db/dbAccessDefs.h ../../../src/dbStatic/devSup.h ../../../src/dbStatic/drvSup.h ../../../src/dbStatic/recSup.h ../../../src/dbStatic/dbStaticLib.h ../../../src/libCom/error/errMdef.h ../../../src/cas/generic/casdef.h ../../../src/gdd/gddAppFuncTable.h
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         errSymTbl.c
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/fdmgr/fdmgr.cpp
../../../src/libCom/fdmgr/fdManager.h:39: warning: 'class fdRegId' has virtual functions but non-virtual destructor
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/fdmgr/fdManager.cpp
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/freeList/freeListLib.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/gpHash/gpHashLib.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/logClient/iocLog.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/logClient/logClient.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/macLib/macCore.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/macLib/macEnv.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/macLib/macUtil.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/misc/aToIPAddr.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/misc/adjustment.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/misc/cantProceed.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/misc/epicsConvert.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/misc/epicsExit.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/misc/epicsStdlib.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/misc/epicsString.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/misc/truncateFile.c
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/osi/epicsThread.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/osi/epicsMutex.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/osi/epicsEvent.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/osi/epicsTime.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/osi/epicsMessageQueue.cpp
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/osi/os/posix/osdSock.c
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/osi/os/posix/osdSockAddrReuse.cpp
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/osi/osiSock.c
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/osi/os/posix/systemCallIntMech.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/osi/os/default/epicsSocketConvertErrnoToString.cpp
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/osi/os/default/osdAssert.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/osi/os/default/osdFindSymbol.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/osi/os/default/osdInterrupt.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/osi/os/default/osdPoolStatus.c
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/osi/os/posix/osdSignal.cpp
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/osi/os/default/osdEnv.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall   -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_READLINE       -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/osi/os/default/epicsReadline.c
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/osi/os/posix/epicsTempFile.cpp
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/osi/epicsStdio.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/osi/os/posix/osdStdio.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500     -DDONT_USE_POSIX_THREAD_PRIORITY_SCHEDULING   -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/osi/os/posix/osdThread.c
../../../src/libCom/osi/os/posix/osdThread.c:151: warning: 'getOssPriorityValue' defined but not used
../../../src/libCom/osi/os/posix/osdThread.c:426: warning: 'nonEPICSthreadCleanup' defined but not used
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/osi/os/posix/osdMutex.c
../../../src/libCom/osi/os/posix/osdMutex.c:51: warning: 'condWait' defined but not used
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/osi/os/posix/osdEvent.c
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/osi/os/posix/osdTime.cpp
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/osi/os/posix/osdProcess.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/osi/os/default/osdNetIntf.c
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/osi/os/default/osdMessageQueue.cpp
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/taskwd/taskwd.c
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/timer/epicsTimer.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/timer/timer.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/timer/timerQueue.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/timer/timerQueueActive.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/timer/timerQueueActiveMgr.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/timer/timerQueuePassive.cpp
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include         ../../../src/libCom/tsDefs/tsDefs.c
/usr/bin/ar -rc   libCom.a       bucketLib.o epicsRingPointer.o epicsRingBytes.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsOnce.o epicsSingletonMutex.o dbmf.o ellLib.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdMutex.o osdEvent.o osdTime.o osdProcess.o osdNetIntf.o osdMessageQueue.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o tsDefs.o
/usr/bin/ranlib libCom.a
Installing library ../../../lib/linux-x86/libCom.a
mkdir ../../../lib
mkdir ../../../lib/linux-x86
/usr/bin/ranlib ../../../lib/linux-x86/libCom.a
/usr/bin/g++ -o libCom.so -shared -fPIC          -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86         bucketLib.o epicsRingPointer.o epicsRingBytes.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsOnce.o epicsSingletonMutex.o dbmf.o ellLib.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdMutex.o osdEvent.o osdTime.o osdProcess.o osdNetIntf.o osdMessageQueue.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o tsDefs.o     -lpthread   -lreadline -lcurses -lm -lrt -lgcc
Installing shared library ../../../lib/linux-x86/libCom.so
Installing html ../../../html//freeList/freeList.html
mkdir ../../../html
mkdir ../../../html/freeList
Installing html ../../../html//gpHash/gpHash.html
mkdir ../../../html/gpHash
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/libCom/O.linux-x86'
make -C O.linux-arm -f ../Makefile TOP=../../.. T_A=linux-arm install
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/libCom/O.linux-arm'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/libCom/O.linux-arm'
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/bucketLib/bucketLib.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/ring/epicsRingPointer.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/ring/epicsRingBytes.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/calc/postfix.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/calc/calcPerform.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/cvtFast/cvtFast.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/cxxTemplates/resourceLib.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/cxxTemplates/epicsOnce.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/cxxTemplates/epicsSingletonMutex.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/dbmf/dbmf.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/ellLib/ellLib.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/env/envSubr.c
perl ../../../src/libCom/env/bldEnvData.pl ../../../configure
Generating envData.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  envData.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/error/errlog.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/error/errSymLib.c
perl ../../../src/libCom/error/makeStatTbl.pl  ../../../src/libCom/osi/devLib.h ../../../src/as/asLib.h ../../../src/db/dbAccessDefs.h ../../../src/dbStatic/devSup.h ../../../src/dbStatic/drvSup.h ../../../src/dbStatic/recSup.h ../../../src/dbStatic/dbStaticLib.h ../../../src/libCom/error/errMdef.h ../../../src/cas/generic/casdef.h ../../../src/gdd/gddAppFuncTable.h
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  errSymTbl.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/fdmgr/fdmgr.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/fdmgr/fdManager.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/freeList/freeListLib.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/gpHash/gpHashLib.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/logClient/iocLog.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/logClient/logClient.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/macLib/macCore.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/macLib/macEnv.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/macLib/macUtil.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/misc/aToIPAddr.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/misc/adjustment.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/misc/cantProceed.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/misc/epicsConvert.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/misc/epicsExit.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/misc/epicsStdlib.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/misc/epicsString.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/misc/truncateFile.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/osi/epicsThread.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/osi/epicsMutex.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/osi/epicsEvent.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/osi/epicsTime.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/osi/epicsMessageQueue.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/osi/os/posix/osdSock.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/osi/os/posix/osdSockAddrReuse.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/osi/osiSock.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/osi/os/posix/systemCallIntMech.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/osi/os/default/epicsSocketConvertErrnoToString.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/osi/os/default/osdAssert.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/osi/os/default/osdFindSymbol.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/osi/os/default/osdInterrupt.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/osi/os/default/osdPoolStatus.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/osi/os/posix/osdSignal.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/osi/os/default/osdEnv.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall   -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_EPICS       -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/osi/os/default/epicsReadline.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/osi/os/posix/epicsTempFile.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/osi/epicsStdio.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/osi/os/posix/osdStdio.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500     -DDONT_USE_POSIX_THREAD_PRIORITY_SCHEDULING   -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/osi/os/posix/osdThread.c
../../../src/libCom/osi/os/posix/osdThread.c:151: warning: `getOssPriorityValue' defined but not used
../../../src/libCom/osi/os/posix/osdThread.c:426: warning: `nonEPICSthreadCleanup' defined but not used
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/osi/os/posix/osdMutex.c
../../../src/libCom/osi/os/posix/osdMutex.c:51: warning: `condWait' defined but not used
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/osi/os/posix/osdEvent.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/osi/os/posix/osdTime.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/osi/os/posix/osdProcess.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/osi/os/default/osdNetIntf.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/osi/os/default/osdMessageQueue.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/taskwd/taskwd.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/timer/epicsTimer.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/timer/timer.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/timer/timerQueue.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/timer/timerQueueActive.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/timer/timerQueueActiveMgr.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/timer/timerQueuePassive.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../src/libCom/tsDefs/tsDefs.c
/usr/local/armlinux/3.3.3/bin/arm-linux-ar -rc   libCom.a       bucketLib.o epicsRingPointer.o epicsRingBytes.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsOnce.o epicsSingletonMutex.o dbmf.o ellLib.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdMutex.o osdEvent.o osdTime.o osdProcess.o osdNetIntf.o osdMessageQueue.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o tsDefs.o
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib libCom.a
Installing library ../../../lib/linux-arm/libCom.a
mkdir ../../../lib/linux-arm
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib ../../../lib/linux-arm/libCom.a
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o libCom.so -shared -fPIC         -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm         bucketLib.o epicsRingPointer.o epicsRingBytes.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsOnce.o epicsSingletonMutex.o dbmf.o ellLib.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdMutex.o osdEvent.o osdTime.o osdProcess.o osdNetIntf.o osdMessageQueue.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o tsDefs.o     -lpthread    -lm -lrt -lgcc
Installing shared library ../../../lib/linux-arm/libCom.so
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/libCom/O.linux-arm'
make[2]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/libCom'
make -C toolsComm install
make[2]: Entering directory `/usr/local/epics/base-3.14.8.2/src/toolsComm'
make -C antelope install
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/toolsComm/antelope'
perl ../../../configure/tools/makeMakefile.pl O.linux-x86 ../../../..
perl ../../../configure/tools/makeMakefile.pl O.linux-arm ../../../..
mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../../../.. T_A=linux-x86 install
make[4]: Entering directory `/usr/local/epics/base-3.14.8.2/src/toolsComm/antelope/O.linux-x86'
make[4]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/toolsComm/antelope/O.linux-x86'
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -w    -D_NO_PROTO      -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../closure.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -w    -D_NO_PROTO      -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../error.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -w    -D_NO_PROTO      -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../lalr.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -w    -D_NO_PROTO      -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../lr0.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -w    -D_NO_PROTO      -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../main.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -w    -D_NO_PROTO      -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../mkpar.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -w    -D_NO_PROTO      -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../output.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -w    -D_NO_PROTO      -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../reader.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -w    -D_NO_PROTO      -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../skeleton.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -w    -D_NO_PROTO      -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../symtab.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -w    -D_NO_PROTO      -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../verbose.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -w    -D_NO_PROTO      -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../warshall.c
/usr/bin/g++ -o antelope  -L../../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86         closure.o error.o lalr.o lr0.o main.o mkpar.o output.o reader.o skeleton.o symtab.o verbose.o warshall.o   -lCom
Installing binary ../../../../bin/linux-x86/antelope
make -C O.linux-arm -f ../Makefile TOP=../../../.. T_A=linux-arm install
make[4]: Entering directory `/usr/local/epics/base-3.14.8.2/src/toolsComm/antelope/O.linux-arm'
make[4]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/toolsComm/antelope/O.linux-arm'
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall    -D_NO_PROTO       -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../closure.c
../closure.c:21: warning: return type defaults to `int'
../closure.c: In function `set_EFF':
../closure.c:48: warning: implicit declaration of function `reflexive_transitive_closure'
../closure.c:53: warning: control reaches end of non-void function
../closure.c: At top level:
../closure.c:57: warning: return type defaults to `int'
../closure.c: In function `set_first_derives':
../closure.c:108: warning: control reaches end of non-void function
../closure.c:62: warning: `cword' might be used uninitialized in this function
../closure.c:112: warning: return type defaults to `int'
../closure.c: In function `closure':
../closure.c:177: warning: control reaches end of non-void function
../closure.c:182: warning: return type defaults to `int'
../closure.c: In function `finalize_closure':
../closure.c:186: warning: control reaches end of non-void function
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall    -D_NO_PROTO       -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../error.c
../error.c:16: warning: return type defaults to `int'
../error.c: In function `fatal':
../error.c:19: warning: implicit declaration of function `done'
../error.c: At top level:
../error.c:24: warning: return type defaults to `int'
../error.c:31: warning: return type defaults to `int'
../error.c:39: warning: return type defaults to `int'
../error.c:47: warning: return type defaults to `int'
../error.c:75: warning: return type defaults to `int'
../error.c:87: warning: return type defaults to `int'
../error.c:99: warning: return type defaults to `int'
../error.c:111: warning: return type defaults to `int'
../error.c:123: warning: return type defaults to `int'
../error.c:135: warning: return type defaults to `int'
../error.c:145: warning: return type defaults to `int'
../error.c:157: warning: return type defaults to `int'
../error.c:167: warning: return type defaults to `int'
../error.c:176: warning: return type defaults to `int'
../error.c:185: warning: return type defaults to `int'
../error.c:193: warning: return type defaults to `int'
../error.c:201: warning: return type defaults to `int'
../error.c:209: warning: return type defaults to `int'
../error.c:218: warning: return type defaults to `int'
../error.c:225: warning: return type defaults to `int'
../error.c:233: warning: return type defaults to `int'
../error.c:242: warning: return type defaults to `int'
../error.c:249: warning: return type defaults to `int'
../error.c:261: warning: return type defaults to `int'
../error.c:270: warning: return type defaults to `int'
../error.c:282: warning: return type defaults to `int'
../error.c:290: warning: return type defaults to `int'
../error.c:300: warning: return type defaults to `int'
../error.c:309: warning: return type defaults to `int'
../error.c:316: warning: return type defaults to `int'
../error.c:324: warning: return type defaults to `int'
../error.c:20: warning: control reaches end of non-void function
../error.c: In function `no_space':
../error.c:27: warning: control reaches end of non-void function
../error.c: In function `open_error':
../error.c:35: warning: control reaches end of non-void function
../error.c: In function `unexpected_EOF':
../error.c:43: warning: control reaches end of non-void function
../error.c: In function `syntax_error':
../error.c:83: warning: control reaches end of non-void function
../error.c: In function `unterminated_comment':
../error.c:95: warning: control reaches end of non-void function
../error.c: In function `unterminated_string':
../error.c:107: warning: control reaches end of non-void function
../error.c: In function `unterminated_text':
../error.c:119: warning: control reaches end of non-void function
../error.c: In function `unterminated_union':
../error.c:131: warning: control reaches end of non-void function
../error.c: In function `over_unionized':
../error.c:141: warning: control reaches end of non-void function
../error.c: In function `illegal_tag':
../error.c:153: warning: control reaches end of non-void function
../error.c: In function `illegal_character':
../error.c:163: warning: control reaches end of non-void function
../error.c: In function `used_reserved':
../error.c:172: warning: control reaches end of non-void function
../error.c: In function `tokenized_start':
../error.c:181: warning: control reaches end of non-void function
../error.c: In function `retyped_warning':
../error.c:189: warning: control reaches end of non-void function
../error.c: In function `reprec_warning':
../error.c:197: warning: control reaches end of non-void function
../error.c: In function `revalued_warning':
../error.c:205: warning: control reaches end of non-void function
../error.c: In function `terminal_start':
../error.c:214: warning: control reaches end of non-void function
../error.c: In function `restarted_warning':
../error.c:221: warning: control reaches end of non-void function
../error.c: In function `no_grammar':
../error.c:229: warning: control reaches end of non-void function
../error.c: In function `terminal_lhs':
../error.c:238: warning: control reaches end of non-void function
../error.c: In function `prec_redeclared':
../error.c:245: warning: control reaches end of non-void function
../error.c: In function `unterminated_action':
../error.c:257: warning: control reaches end of non-void function
../error.c: In function `dollar_warning':
../error.c:266: warning: control reaches end of non-void function
../error.c: In function `dollar_error':
../error.c:278: warning: control reaches end of non-void function
../error.c: In function `untyped_lhs':
../error.c:286: warning: control reaches end of non-void function
../error.c: In function `untyped_rhs':
../error.c:296: warning: control reaches end of non-void function
../error.c: In function `unknown_rhs':
../error.c:305: warning: control reaches end of non-void function
../error.c: In function `default_action_warning':
../error.c:312: warning: control reaches end of non-void function
../error.c: In function `undefined_goal':
../error.c:320: warning: control reaches end of non-void function
../error.c: In function `undefined_symbol_warning':
../error.c:327: warning: control reaches end of non-void function
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall    -D_NO_PROTO       -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../lalr.c
../lalr.c:47: warning: return type defaults to `int'
../lalr.c: In function `lalr':
../lalr.c:50: warning: implicit declaration of function `set_state_table'
../lalr.c:51: warning: implicit declaration of function `set_accessing_symbol'
../lalr.c:52: warning: implicit declaration of function `set_shift_table'
../lalr.c:53: warning: implicit declaration of function `set_reduction_table'
../lalr.c:54: warning: implicit declaration of function `set_maxrhs'
../lalr.c:55: warning: implicit declaration of function `initialize_LA'
../lalr.c:56: warning: implicit declaration of function `set_goto_map'
../lalr.c:57: warning: implicit declaration of function `initialize_F'
../lalr.c:58: warning: implicit declaration of function `build_relations'
../lalr.c:59: warning: implicit declaration of function `compute_FOLLOWS'
../lalr.c:60: warning: implicit declaration of function `compute_lookaheads'
../lalr.c: At top level:
../lalr.c:66: warning: return type defaults to `int'
../lalr.c:77: warning: return type defaults to `int'
../lalr.c:88: warning: return type defaults to `int'
../lalr.c:99: warning: return type defaults to `int'
../lalr.c:110: warning: return type defaults to `int'
../lalr.c:138: warning: return type defaults to `int'
../lalr.c: In function `initialize_LA':
../lalr.c:171: warning: control reaches end of non-void function
../lalr.c:175: warning: return type defaults to `int'
../lalr.c: In function `set_goto_map':
../lalr.c:197: warning: implicit declaration of function `fatal'
../lalr.c:237: warning: control reaches end of non-void function
../lalr.c:273: warning: return type defaults to `int'
../lalr.c: In function `initialize_F':
../lalr.c:335: warning: implicit declaration of function `digraph'
../lalr.c:345: warning: control reaches end of non-void function
../lalr.c:350: warning: return type defaults to `int'
../lalr.c: In function `build_relations':
../lalr.c:400: warning: implicit declaration of function `add_lookback_edge'
../lalr.c:438: warning: control reaches end of non-void function
../lalr.c:442: warning: return type defaults to `int'
../lalr.c:527: warning: return type defaults to `int'
../lalr.c:533: warning: return type defaults to `int'
../lalr.c: In function `compute_lookaheads':
../lalr.c:563: warning: control reaches end of non-void function
../lalr.c:567: warning: return type defaults to `int'
../lalr.c: In function `digraph':
../lalr.c:584: warning: implicit declaration of function `traverse'
../lalr.c:594: warning: return type defaults to `int'
../lalr.c: In function `traverse':
../lalr.c:647: warning: control reaches end of non-void function
../lalr.c:61: warning: control reaches end of non-void function
../lalr.c: In function `set_state_table':
../lalr.c:72: warning: control reaches end of non-void function
../lalr.c: In function `set_accessing_symbol':
../lalr.c:83: warning: control reaches end of non-void function
../lalr.c: In function `set_shift_table':
../lalr.c:94: warning: control reaches end of non-void function
../lalr.c: In function `set_reduction_table':
../lalr.c:105: warning: control reaches end of non-void function
../lalr.c: In function `set_maxrhs':
../lalr.c:133: warning: control reaches end of non-void function
../lalr.c: In function `add_lookback_edge':
../lalr.c:464: warning: control reaches end of non-void function
../lalr.c: In function `compute_FOLLOWS':
../lalr.c:529: warning: control reaches end of non-void function
../lalr.c:589: warning: control reaches end of non-void function
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall    -D_NO_PROTO       -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../lr0.c
../lr0.c:43: warning: return type defaults to `int'
../lr0.c: In function `allocate_itemsets':
../lr0.c:81: warning: control reaches end of non-void function
../lr0.c: At top level:
../lr0.c:85: warning: return type defaults to `int'
../lr0.c:94: warning: return type defaults to `int'
../lr0.c:123: warning: return type defaults to `int'
../lr0.c:136: warning: return type defaults to `int'
../lr0.c: In function `generate_states':
../lr0.c:140: warning: implicit declaration of function `set_first_derives'
../lr0.c:141: warning: implicit declaration of function `initialize_states'
../lr0.c:145: warning: implicit declaration of function `closure'
../lr0.c:146: warning: implicit declaration of function `save_reductions'
../lr0.c:147: warning: implicit declaration of function `new_itemsets'
../lr0.c:151: warning: implicit declaration of function `save_shifts'
../lr0.c:156: warning: implicit declaration of function `finalize_closure'
../lr0.c:228: warning: return type defaults to `int'
../lr0.c: In function `initialize_states':
../lr0.c:238: warning: implicit declaration of function `no_space'
../lr0.c:255: warning: return type defaults to `int'
../lr0.c: In function `new_itemsets':
../lr0.c:286: warning: control reaches end of non-void function
../lr0.c: In function `new_state':
../lr0.c:305: warning: implicit declaration of function `fatal'
../lr0.c:332: warning: return type defaults to `int'
../lr0.c: In function `show_cores':
../lr0.c:361: warning: control reaches end of non-void function
../lr0.c:367: warning: return type defaults to `int'
../lr0.c:377: warning: return type defaults to `int'
../lr0.c:388: warning: return type defaults to `int'
../lr0.c:406: warning: return type defaults to `int'
../lr0.c:440: warning: return type defaults to `int'
../lr0.c: In function `save_reductions':
../lr0.c:485: warning: control reaches end of non-void function
../lr0.c:489: warning: return type defaults to `int'
../lr0.c:519: warning: return type defaults to `int'
../lr0.c:548: warning: return type defaults to `int'
../lr0.c: In function `set_nullable':
../lr0.c:593: warning: control reaches end of non-void function
../lr0.c:597: warning: return type defaults to `int'
../lr0.c:603: warning: return type defaults to `int'
../lr0.c: In function `allocate_storage':
../lr0.c:90: warning: control reaches end of non-void function
../lr0.c: In function `append_states':
../lr0.c:119: warning: control reaches end of non-void function
../lr0.c: In function `free_storage':
../lr0.c:131: warning: control reaches end of non-void function
../lr0.c:158: warning: control reaches end of non-void function
../lr0.c:251: warning: control reaches end of non-void function
../lr0.c: In function `show_ritems':
../lr0.c:372: warning: control reaches end of non-void function
../lr0.c: In function `show_rrhs':
../lr0.c:382: warning: control reaches end of non-void function
../lr0.c: In function `show_shifts':
../lr0.c:402: warning: control reaches end of non-void function
../lr0.c: In function `save_shifts':
../lr0.c:435: warning: control reaches end of non-void function
../lr0.c: In function `set_derives':
../lr0.c:516: warning: control reaches end of non-void function
../lr0.c: In function `free_derives':
../lr0.c:522: warning: control reaches end of non-void function
../lr0.c: In function `free_nullable':
../lr0.c:599: warning: control reaches end of non-void function
../lr0.c: In function `lr0':
../lr0.c:607: warning: control reaches end of non-void function
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall    -D_NO_PROTO       -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../main.c
../main.c:72: warning: return type defaults to `int'
../main.c: In function `done':
../main.c:77: warning: implicit declaration of function `exit'
../main.c: At top level:
../main.c:88: warning: return type defaults to `int'
../main.c:105: warning: return type defaults to `int'
../main.c:112: warning: return type defaults to `int'
../main.c: In function `allocate':
../main.c:228: warning: implicit declaration of function `no_space'
../main.c:238: warning: return type defaults to `int'
../main.c: In function `create_file_names':
../main.c:241: warning: implicit declaration of function `strlen'
../main.c:277: warning: control reaches end of non-void function
../main.c:281: warning: return type defaults to `int'
../main.c: In function `open_files':
../main.c:288: warning: implicit declaration of function `open_error'
../main.c:328: warning: control reaches end of non-void function
../main.c: In function `main':
../main.c:339: warning: implicit declaration of function `reader'
../main.c:340: warning: implicit declaration of function `lr0'
../main.c:341: warning: implicit declaration of function `lalr'
../main.c:342: warning: implicit declaration of function `make_parser'
../main.c:343: warning: implicit declaration of function `verbose'
../main.c:344: warning: implicit declaration of function `output'
../main.c: In function `set_signals':
../main.c:101: warning: control reaches end of non-void function
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall    -D_NO_PROTO       -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../mkpar.c
../mkpar.c:33: warning: return type defaults to `int'
../mkpar.c: In function `make_parser':
../mkpar.c:40: warning: implicit declaration of function `find_final_state'
../mkpar.c:41: warning: implicit declaration of function `remove_conflicts'
../mkpar.c:42: warning: implicit declaration of function `unused_rules'
../mkpar.c:43: warning: implicit declaration of function `total_conflicts'
../mkpar.c:44: warning: implicit declaration of function `defreds'
../mkpar.c: At top level:
../mkpar.c:163: warning: return type defaults to `int'
../mkpar.c:180: warning: return type defaults to `int'
../mkpar.c: In function `unused_rules':
../mkpar.c:185: warning: implicit declaration of function `no_space'
../mkpar.c:203: warning: suggest explicit braces to avoid ambiguous `else'
../mkpar.c:208: warning: control reaches end of non-void function
../mkpar.c:212: warning: return type defaults to `int'
../mkpar.c: In function `remove_conflicts':
../mkpar.c:283: warning: control reaches end of non-void function
../mkpar.c:215: warning: `pref' might be used uninitialized in this function
../mkpar.c:287: warning: return type defaults to `int'
../mkpar.c:336: warning: return type defaults to `int'
../mkpar.c:345: warning: return type defaults to `int'
../mkpar.c:358: warning: return type defaults to `int'
../mkpar.c:45: warning: control reaches end of non-void function
../mkpar.c: In function `find_final_state':
../mkpar.c:176: warning: control reaches end of non-void function
../mkpar.c: In function `total_conflicts':
../mkpar.c:303: warning: control reaches end of non-void function
../mkpar.c: In function `defreds':
../mkpar.c:342: warning: control reaches end of non-void function
../mkpar.c: In function `free_action_row':
../mkpar.c:355: warning: control reaches end of non-void function
../mkpar.c: In function `free_parser':
../mkpar.c:365: warning: control reaches end of non-void function
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall    -D_NO_PROTO       -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../output.c
../output.c:30: warning: return type defaults to `int'
../output.c: In function `output':
../output.c:31: warning: implicit declaration of function `free_itemsets'
../output.c:32: warning: implicit declaration of function `free_shifts'
../output.c:33: warning: implicit declaration of function `free_reductions'
../output.c:34: warning: implicit declaration of function `output_prefix'
../output.c:35: warning: implicit declaration of function `output_stored_text'
../output.c:36: warning: implicit declaration of function `output_defines'
../output.c:37: warning: implicit declaration of function `output_rule_data'
../output.c:38: warning: implicit declaration of function `output_yydefred'
../output.c:39: warning: implicit declaration of function `output_actions'
../output.c:40: warning: implicit declaration of function `free_parser'
../output.c:41: warning: implicit declaration of function `output_debug'
../output.c:42: warning: implicit declaration of function `output_stype'
../output.c:43: warning: implicit declaration of function `write_section'
../output.c:45: warning: implicit declaration of function `output_trailing_text'
../output.c:47: warning: implicit declaration of function `output_semantic_actions'
../output.c: At top level:
../output.c:53: warning: return type defaults to `int'
../output.c: In function `output_prefix':
../output.c:109: warning: control reaches end of non-void function
../output.c:113: warning: return type defaults to `int'
../output.c: In function `output_rule_data':
../output.c:156: warning: control reaches end of non-void function
../output.c:160: warning: return type defaults to `int'
../output.c:187: warning: return type defaults to `int'
../output.c: In function `output_actions':
../output.c:195: warning: implicit declaration of function `token_actions'
../output.c:201: warning: implicit declaration of function `goto_actions'
../output.c:206: warning: implicit declaration of function `sort_actions'
../output.c:207: warning: implicit declaration of function `pack_table'
../output.c:208: warning: implicit declaration of function `output_base'
../output.c:209: warning: implicit declaration of function `output_table'
../output.c:210: warning: implicit declaration of function `output_check'
../output.c:215: warning: return type defaults to `int'
../output.c: In function `token_actions':
../output.c:296: warning: control reaches end of non-void function
../output.c:299: warning: return type defaults to `int'
../output.c: In function `goto_actions':
../output.c:304: warning: implicit declaration of function `default_goto'
../output.c:306: warning: implicit declaration of function `save_column'
../output.c:328: warning: control reaches end of non-void function
../output.c:368: warning: return type defaults to `int'
../output.c:411: warning: return type defaults to `int'
../output.c: In function `sort_actions':
../output.c:442: warning: control reaches end of non-void function
../output.c:446: warning: return type defaults to `int'
../output.c: In function `pack_table':
../output.c:466: warning: implicit declaration of function `matching_vector'
../output.c:469: warning: implicit declaration of function `pack_vector'
../output.c:488: warning: control reaches end of non-void function
../output.c: In function `pack_vector':
../output.c:582: warning: implicit declaration of function `fatal'
../output.c:587: warning: implicit declaration of function `no_space'
../output.c:627: warning: return type defaults to `int'
../output.c: In function `output_base':
../output.c:688: warning: control reaches end of non-void function
../output.c:693: warning: return type defaults to `int'
../output.c:725: warning: return type defaults to `int'
../output.c: In function `is_C_identifier':
../output.c:777: warning: suggest parentheses around assignment used as truth value
../output.c:787: warning: return type defaults to `int'
../output.c: In function `output_defines':
../output.c:814: warning: suggest parentheses around assignment used as truth value
../output.c:833: warning: control reaches end of non-void function
../output.c:837: warning: return type defaults to `int'
../output.c:863: warning: return type defaults to `int'
../output.c: In function `output_debug':
../output.c:899: warning: suggest parentheses around assignment used as truth value
../output.c:991: warning: implicit declaration of function `strlen'
../output.c:1073: warning: control reaches end of non-void function
../output.c:1077: warning: return type defaults to `int'
../output.c:1087: warning: return type defaults to `int'
../output.c:1146: warning: return type defaults to `int'
../output.c:1182: warning: return type defaults to `int'
../output.c:1195: warning: return type defaults to `int'
../output.c:1209: warning: return type defaults to `int'
../output.c:49: warning: control reaches end of non-void function
../output.c: In function `output_yydefred':
../output.c:183: warning: control reaches end of non-void function
../output.c:211: warning: control reaches end of non-void function
../output.c: In function `output_table':
../output.c:720: warning: control reaches end of non-void function
../output.c: In function `output_check':
../output.c:750: warning: control reaches end of non-void function
../output.c: In function `output_stype':
../output.c:1083: warning: control reaches end of non-void function
../output.c: In function `free_itemsets':
../output.c:1191: warning: control reaches end of non-void function
../output.c: In function `free_shifts':
../output.c:1204: warning: control reaches end of non-void function
../output.c: In function `free_reductions':
../output.c:1218: warning: control reaches end of non-void function
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall    -D_NO_PROTO       -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../reader.c
../reader.c:47: warning: return type defaults to `int'
../reader.c: In function `cachec':
../reader.c:54: warning: implicit declaration of function `no_space'
../reader.c: At top level:
../reader.c:62: warning: return type defaults to `int'
../reader.c:126: warning: return type defaults to `int'
../reader.c: In function `skip_comment':
../reader.c:146: warning: implicit declaration of function `unterminated_comment'
../reader.c: In function `keyword':
../reader.c:242: warning: implicit declaration of function `strcmp'
../reader.c:275: warning: implicit declaration of function `syntax_error'
../reader.c:277: warning: control reaches end of non-void function
../reader.c:281: warning: return type defaults to `int'
../reader.c: In function `copy_ident':
../reader.c:286: warning: implicit declaration of function `unexpected_EOF'
../reader.c:310: warning: return type defaults to `int'
../reader.c: In function `copy_text':
../reader.c:323: warning: implicit declaration of function `unterminated_text'
../reader.c:359: warning: implicit declaration of function `unterminated_string'
../reader.c:441: warning: return type defaults to `int'
../reader.c: In function `copy_union':
../reader.c:449: warning: implicit declaration of function `over_unionized'
../reader.c:468: warning: implicit declaration of function `unterminated_union'
../reader.c: In function `get_literal':
../reader.c:639: warning: implicit declaration of function `illegal_character'
../reader.c: In function `get_name':
../reader.c:765: warning: implicit declaration of function `used_reserved'
../reader.c: In function `get_tag':
../reader.c:799: warning: implicit declaration of function `illegal_tag'
../reader.c:837: warning: return type defaults to `int'
../reader.c: In function `declare_tokens':
../reader.c:864: warning: implicit declaration of function `tokenized_start'
../reader.c:870: warning: implicit declaration of function `retyped_warning'
../reader.c:877: warning: implicit declaration of function `reprec_warning'
../reader.c:889: warning: implicit declaration of function `revalued_warning'
../reader.c:899: warning: return type defaults to `int'
../reader.c:927: warning: return type defaults to `int'
../reader.c: In function `declare_start':
../reader.c:937: warning: implicit declaration of function `terminal_start'
../reader.c:939: warning: implicit declaration of function `restarted_warning'
../reader.c:945: warning: return type defaults to `int'
../reader.c:994: warning: return type defaults to `int'
../reader.c: In function `initialize_grammar':
../reader.c:1021: warning: control reaches end of non-void function
../reader.c:1025: warning: return type defaults to `int'
../reader.c:1033: warning: return type defaults to `int'
../reader.c:1045: warning: return type defaults to `int'
../reader.c: In function `advance_to_start':
../reader.c:1059: warning: implicit declaration of function `no_grammar'
../reader.c:1089: warning: implicit declaration of function `start_rule'
../reader.c:1091: warning: control reaches end of non-void function
../reader.c:1095: warning: return type defaults to `int'
../reader.c: In function `start_rule':
../reader.c:1099: warning: implicit declaration of function `terminal_lhs'
../reader.c:1110: warning: return type defaults to `int'
../reader.c: In function `end_rule':
../reader.c:1117: warning: implicit declaration of function `default_action_warning'
../reader.c:1129: warning: return type defaults to `int'
../reader.c: In function `insert_empty_rule':
../reader.c:1144: warning: suggest parentheses around assignment used as truth value
../reader.c:1158: warning: return type defaults to `int'
../reader.c:1189: warning: return type defaults to `int'
../reader.c: In function `copy_action':
../reader.c:1236: warning: implicit declaration of function `dollar_warning'
../reader.c:1250: warning: implicit declaration of function `dollar_error'
../reader.c:1257: warning: implicit declaration of function `untyped_lhs'
../reader.c:1272: warning: implicit declaration of function `unknown_rhs'
../reader.c:1274: warning: implicit declaration of function `untyped_rhs'
../reader.c:1312: warning: implicit declaration of function `unterminated_action'
../reader.c: In function `mark_symbol':
../reader.c:1447: warning: implicit declaration of function `prec_redeclared'
../reader.c:1415: warning: `bp' might be used uninitialized in this function
../reader.c:1456: warning: return type defaults to `int'
../reader.c: In function `read_grammar':
../reader.c:1485: warning: control reaches end of non-void function
../reader.c:1489: warning: return type defaults to `int'
../reader.c:1505: warning: return type defaults to `int'
../reader.c: In function `pack_names':
../reader.c:1511: warning: implicit declaration of function `strlen'
../reader.c:1522: warning: suggest parentheses around assignment used as truth value
../reader.c:1530: warning: return type defaults to `int'
../reader.c: In function `check_symbols':
../reader.c:1534: warning: implicit declaration of function `undefined_goal'
../reader.c:1540: warning: implicit declaration of function `undefined_symbol_warning'
../reader.c:1548: warning: return type defaults to `int'
../reader.c: In function `pack_symbols':
../reader.c:1668: warning: control reaches end of non-void function
../reader.c:1672: warning: return type defaults to `int'
../reader.c: In function `pack_grammar':
../reader.c:1727: warning: control reaches end of non-void function
../reader.c:1731: warning: return type defaults to `int'
../reader.c: In function `print_grammar':
../reader.c:1733: warning: `spacing' might be used uninitialized in this function
../reader.c:1768: warning: return type defaults to `int'
../reader.c: In function `reader':
../reader.c:1769: warning: implicit declaration of function `write_section'
../reader.c:1770: warning: implicit declaration of function `create_symbol_table'
../reader.c:1773: warning: implicit declaration of function `free_symbol_table'
../reader.c:1779: warning: implicit declaration of function `free_symbols'
../reader.c:58: warning: control reaches end of non-void function
../reader.c:941: warning: control reaches end of non-void function
../reader.c: In function `expand_items':
../reader.c:1029: warning: control reaches end of non-void function
../reader.c: In function `expand_rules':
../reader.c:1041: warning: control reaches end of non-void function
../reader.c:1106: warning: control reaches end of non-void function
../reader.c:1125: warning: control reaches end of non-void function
../reader.c:1154: warning: control reaches end of non-void function
../reader.c: In function `add_symbol':
../reader.c:1185: warning: control reaches end of non-void function
../reader.c:1526: warning: control reaches end of non-void function
../reader.c:1544: warning: control reaches end of non-void function
../reader.c:1781: warning: control reaches end of non-void function
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall    -D_NO_PROTO       -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../skeleton.c
../skeleton.c:298: warning: return type defaults to `int'
../skeleton.c: In function `write_section':
../skeleton.c:306: warning: suggest parentheses around assignment used as truth value
../skeleton.c:309: warning: suggest parentheses around assignment used as truth value
../skeleton.c:316: warning: control reaches end of non-void function
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall    -D_NO_PROTO       -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../symtab.c
../symtab.c: In function `hash':
../symtab.c:34: warning: suggest parentheses around assignment used as truth value
../symtab.c: In function `make_bucket':
../symtab.c:49: warning: implicit declaration of function `no_space'
../symtab.c:52: warning: implicit declaration of function `strlen'
../symtab.c: In function `lookup':
../symtab.c:79: warning: implicit declaration of function `strcmp'
../symtab.c: At top level:
../symtab.c:93: warning: return type defaults to `int'
../symtab.c:113: warning: return type defaults to `int'
../symtab.c:120: warning: return type defaults to `int'
../symtab.c: In function `create_symbol_table':
../symtab.c:109: warning: control reaches end of non-void function
../symtab.c: In function `free_symbol_table':
../symtab.c:116: warning: control reaches end of non-void function
../symtab.c: In function `free_symbols':
../symtab.c:128: warning: control reaches end of non-void function
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall    -D_NO_PROTO       -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../verbose.c
../verbose.c:17: warning: return type defaults to `int'
../verbose.c: In function `verbose':
../verbose.c:23: warning: implicit declaration of function `no_space'
../verbose.c:26: warning: implicit declaration of function `print_state'
../verbose.c:30: warning: implicit declaration of function `log_unused'
../verbose.c:32: warning: implicit declaration of function `log_conflicts'
../verbose.c: At top level:
../verbose.c:42: warning: return type defaults to `int'
../verbose.c:61: warning: return type defaults to `int'
../verbose.c:89: warning: return type defaults to `int'
../verbose.c: In function `print_state':
../verbose.c:94: warning: implicit declaration of function `print_conflicts'
../verbose.c:96: warning: implicit declaration of function `print_core'
../verbose.c:97: warning: implicit declaration of function `print_nulls'
../verbose.c:98: warning: implicit declaration of function `print_actions'
../verbose.c:103: warning: return type defaults to `int'
../verbose.c: In function `print_conflicts':
../verbose.c:147: warning: control reaches end of non-void function
../verbose.c:105: warning: `act' might be used uninitialized in this function
../verbose.c:105: warning: `number' might be used uninitialized in this function
../verbose.c:151: warning: return type defaults to `int'
../verbose.c: In function `print_core':
../verbose.c:183: warning: control reaches end of non-void function
../verbose.c:187: warning: return type defaults to `int'
../verbose.c: In function `print_nulls':
../verbose.c:227: warning: control reaches end of non-void function
../verbose.c:231: warning: return type defaults to `int'
../verbose.c: In function `print_actions':
../verbose.c:243: warning: implicit declaration of function `print_shifts'
../verbose.c:244: warning: implicit declaration of function `print_reductions'
../verbose.c:252: warning: implicit declaration of function `print_gotos'
../verbose.c:258: warning: return type defaults to `int'
../verbose.c:283: warning: return type defaults to `int'
../verbose.c: In function `print_reductions':
../verbose.c:317: warning: control reaches end of non-void function
../verbose.c:321: warning: return type defaults to `int'
../verbose.c: In function `log_unused':
../verbose.c:57: warning: control reaches end of non-void function
../verbose.c: In function `log_conflicts':
../verbose.c:85: warning: control reaches end of non-void function
../verbose.c:99: warning: control reaches end of non-void function
../verbose.c:254: warning: control reaches end of non-void function
../verbose.c: In function `print_shifts':
../verbose.c:279: warning: control reaches end of non-void function
../verbose.c: In function `print_gotos':
../verbose.c:338: warning: control reaches end of non-void function
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall    -D_NO_PROTO       -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../warshall.c
../warshall.c:13: warning: return type defaults to `int'
../warshall.c: In function `transitive_closure':
../warshall.c:62: warning: control reaches end of non-void function
../warshall.c: At top level:
../warshall.c:65: warning: return type defaults to `int'
../warshall.c: In function `reflexive_transitive_closure':
../warshall.c:91: warning: control reaches end of non-void function
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o antelope  -L../../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../../lib/linux-arm         closure.o error.o lalr.o lr0.o main.o mkpar.o output.o reader.o skeleton.o symtab.o verbose.o warshall.o   -lCom
Installing binary ../../../../bin/linux-arm/antelope
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/toolsComm/antelope'
make -C flex install
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/toolsComm/flex'
mkdir O.Common
make[4]: Entering directory `/usr/local/epics/base-3.14.8.2/src/toolsComm/flex/O.linux-x86'
make[4]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/toolsComm/flex/O.linux-x86'
Installing generic include file ../../../../include/flex.skel.static
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500      -DDEFAULT_SKELETON_FILE="\"include/flex.skel.static\"" -DUSG  -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -w          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../ccl.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500      -DDEFAULT_SKELETON_FILE="\"include/flex.skel.static\"" -DUSG  -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -w          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../dfa.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500      -DDEFAULT_SKELETON_FILE="\"include/flex.skel.static\"" -DUSG  -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -w          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../ecs.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500      -DDEFAULT_SKELETON_FILE="\"include/flex.skel.static\"" -DUSG  -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -w          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../gen.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500      -DDEFAULT_SKELETON_FILE="\"include/flex.skel.static\"" -DUSG  -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -w          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../misc.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500      -DDEFAULT_SKELETON_FILE="\"include/flex.skel.static\"" -DUSG  -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -w          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../nfa.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500      -DDEFAULT_SKELETON_FILE="\"include/flex.skel.static\"" -DUSG  -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -w          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../sym.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500      -DDEFAULT_SKELETON_FILE="\"include/flex.skel.static\"" -DUSG  -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -w          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../tblcmp.c
rm -f parse.c y.tab.c
rm -f parse.h y.tab.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/antelope -l -d ../parse.y
mv y.tab.c parse.c
mv y.tab.h parse.h
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500      -DDEFAULT_SKELETON_FILE="\"include/flex.skel.static\"" -DUSG  -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -w          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         parse.c
/usr/bin/g++ -o e_flex  -L../../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86         ccl.o dfa.o ecs.o gen.o misc.o nfa.o sym.o tblcmp.o parse.o   -lCom
Installing binary ../../../../bin/linux-x86/e_flex
make[4]: Entering directory `/usr/local/epics/base-3.14.8.2/src/toolsComm/flex/O.linux-arm'
make[4]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/toolsComm/flex/O.linux-arm'
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500      -DDEFAULT_SKELETON_FILE="\"include/flex.skel.static\"" -DUSG  -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../ccl.c
../ccl.c:39: warning: `rcsid' defined but not used
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500      -DDEFAULT_SKELETON_FILE="\"include/flex.skel.static\"" -DUSG  -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dfa.c
../dfa.c: In function `dump_associated_rules':
../dfa.c:175: warning: type defaults to `int' in declaration of `rule_num'
../dfa.c: In function `dump_transitions':
../dfa.c:227: warning: implicit declaration of function `abs'
../dfa.c: In function `ntod':
../dfa.c:425: warning: `num_full_table_rows' might be used uninitialized in this function
../dfa.c: At top level:
../dfa.c:39: warning: `rcsid' defined but not used
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500      -DDEFAULT_SKELETON_FILE="\"include/flex.skel.static\"" -DUSG  -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../ecs.c
../ecs.c:39: warning: `rcsid' defined but not used
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500      -DDEFAULT_SKELETON_FILE="\"include/flex.skel.static\"" -DUSG  -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../gen.c
../gen.c: In function `genecs':
../gen.c:251: warning: implicit declaration of function `abs'
../gen.c: At top level:
../gen.c:39: warning: `rcsid' defined but not used
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500      -DDEFAULT_SKELETON_FILE="\"include/flex.skel.static\"" -DUSG  -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../misc.c
../misc.c: In function `reallocate_array':
../misc.c:784: warning: implicit declaration of function `realloc'
../misc.c: At top level:
../misc.c:39: warning: `rcsid' defined but not used
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500      -DDEFAULT_SKELETON_FILE="\"include/flex.skel.static\"" -DUSG  -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../nfa.c
../nfa.c:39: warning: `rcsid' defined but not used
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500      -DDEFAULT_SKELETON_FILE="\"include/flex.skel.static\"" -DUSG  -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../sym.c
../sym.c:39: warning: `rcsid' defined but not used
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500      -DDEFAULT_SKELETON_FILE="\"include/flex.skel.static\"" -DUSG  -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../tblcmp.c
../tblcmp.c:39: warning: `rcsid' defined but not used
mv y.tab.c parse.c
mv y.tab.h parse.h
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500      -DDEFAULT_SKELETON_FILE="\"include/flex.skel.static\"" -DUSG  -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  parse.c
In file included from parse.c:351:
scan.l: In function `flexscan':
scan.l:190: warning: suggest parentheses around && within ||
scan.l:496: warning: implicit declaration of function `exit'
scan.l:734: warning: `indented_code' might be used uninitialized in this function
scan.l:734: warning: `checking_used' might be used uninitialized in this function
scan.l:734: warning: `new_xlation' might be used uninitialized in this function
In file included from parse.c:352:
../yylex.c: In function `yylex':
../yylex.c:193: warning: implicit declaration of function `isprint'
In file included from parse.c:353:
../main.c:185: warning: control reaches end of non-void function
../main.c: In function `readin':
../main.c:704: warning: implicit declaration of function `abs'
parse.c: At top level:
parse.c:40: warning: `rcsid' defined but not used
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o e_flex  -L../../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../../lib/linux-arm         ccl.o dfa.o ecs.o gen.o misc.o nfa.o sym.o tblcmp.o parse.o   -lCom
Installing binary ../../../../bin/linux-arm/e_flex
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/toolsComm/flex'
make[2]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/toolsComm'
make -C ca install
make[2]: Entering directory `/usr/local/epics/base-3.14.8.2/src/ca'
perl ../../configure/tools/makeMakefile.pl O.linux-x86 ../../..
perl ../../configure/tools/makeMakefile.pl O.linux-arm ../../..
mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/ca/O.linux-x86'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/ca/O.linux-x86'
Installing generic include file ../../../include/cadef.h
Installing generic include file ../../../include/caerr.h
Installing generic include file ../../../include/caeventmask.h
Installing generic include file ../../../include/caProto.h
Installing generic include file ../../../include/db_access.h
Installing generic include file ../../../include/addrList.h
Installing generic include file ../../../include/cacIO.h
Installing generic include file ../../../include/caDiagnostics.h
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../include/os/Linux -I../../../include         ../catime.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../include/os/Linux -I../../../include         ../acctst.c
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../include/os/Linux -I../../../include         ../caConnTest.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../include/os/Linux -I../../../include         ../casw.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../include/os/Linux -I../../../include         ../caEventRate.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../cac.cpp
../nciu.h:124: warning: 'class privateInterfaceForIO' has virtual functions but non-virtual destructor
../comBuf.h:48: warning: 'class wireSendAdapter' has virtual functions but non-virtual destructor
../comBuf.h:67: warning: 'class wireRecvAdapter' has virtual functions but non-virtual destructor
../cac.h:60: warning: 'class cacRecycle' has virtual functions but non-virtual destructor
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../cacChannel.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../cacChannelNotify.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../cacContextNotify.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../cacReadNotify.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../cacWriteNotify.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../cacStateNotify.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../access.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../iocinf.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../convert.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../test_event.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../repeater.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../searchTimer.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../disconnectGovernorTimer.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../repeaterSubscribeTimer.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../baseNMIU.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../nciu.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../netiiu.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../udpiiu.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../tcpiiu.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../noopiiu.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../netReadNotifyIO.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../netWriteNotifyIO.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../netSubscription.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../tcpSendWatchdog.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../tcpRecvWatchdog.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../bhe.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../ca_client_context.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../oldChannelNotify.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../oldSubscription.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../getCallback.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../getCopy.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../putCallback.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../syncgrp.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../CASG.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../syncGroupNotify.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../syncGroupReadNotify.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../syncGroupWriteNotify.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../localHostName.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../comQueRecv.cpp
../comQueRecv.cpp: In member function 'epicsUInt8 comQueRecv::popUInt8()':
../comQueRecv.cpp:181: warning: 'tmp' may be used uninitialized in this function
../comQueRecv.cpp: In member function 'bool comQueRecv::popOldMsgHeader(caHdrLargeArray&)':
../comQueRecv.cpp:241: warning: 'smallPostsize' may be used uninitialized in this function
../comQueRecv.cpp:245: warning: 'smallCount' may be used uninitialized in this function
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../comQueSend.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../comBuf.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../hostNameCache.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../msgForMultiplyDefinedPV.cpp
/usr/bin/ar -rc   libca.a       cac.o cacChannel.o cacChannelNotify.o cacContextNotify.o cacReadNotify.o cacWriteNotify.o cacStateNotify.o access.o iocinf.o convert.o test_event.o repeater.o searchTimer.o disconnectGovernorTimer.o repeaterSubscribeTimer.o baseNMIU.o nciu.o netiiu.o udpiiu.o tcpiiu.o noopiiu.o netReadNotifyIO.o netWriteNotifyIO.o netSubscription.o tcpSendWatchdog.o tcpRecvWatchdog.o bhe.o ca_client_context.o oldChannelNotify.o oldSubscription.o getCallback.o getCopy.o putCallback.o syncgrp.o CASG.o syncGroupNotify.o syncGroupReadNotify.o syncGroupWriteNotify.o localHostName.o comQueRecv.o comQueSend.o comBuf.o hostNameCache.o msgForMultiplyDefinedPV.o
/usr/bin/ranlib libca.a
Installing library ../../../lib/linux-x86/libca.a
/usr/bin/ranlib ../../../lib/linux-x86/libca.a
/usr/bin/g++ -o libca.so -shared -fPIC -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86         cac.o cacChannel.o cacChannelNotify.o cacContextNotify.o cacReadNotify.o cacWriteNotify.o cacStateNotify.o access.o iocinf.o convert.o test_event.o repeater.o searchTimer.o disconnectGovernorTimer.o repeaterSubscribeTimer.o baseNMIU.o nciu.o netiiu.o udpiiu.o tcpiiu.o noopiiu.o netReadNotifyIO.o netWriteNotifyIO.o netSubscription.o tcpSendWatchdog.o tcpRecvWatchdog.o bhe.o ca_client_context.o oldChannelNotify.o oldSubscription.o getCallback.o getCopy.o putCallback.o syncgrp.o CASG.o syncGroupNotify.o syncGroupReadNotify.o syncGroupWriteNotify.o localHostName.o comQueRecv.o comQueSend.o comBuf.o hostNameCache.o msgForMultiplyDefinedPV.o   -lCom  -lpthread   -lreadline -lcurses -lm -lrt -lgcc
Installing shared library ../../../lib/linux-x86/libca.so
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../include/os/Linux -I../../../include         ../caRepeater.cpp
/usr/bin/g++ -o caRepeater  -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        caRepeater.o    -lca -lCom
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../include/os/Linux -I../../../include         ../catimeMain.c
/usr/bin/g++ -o catime  -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        catimeMain.o catime.o    -lca -lCom
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../include/os/Linux -I../../../include         ../acctstMain.c
/usr/bin/g++ -o acctst  -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        acctstMain.o acctst.o    -lca -lCom
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../include/os/Linux -I../../../include         ../caConnTestMain.cpp
/usr/bin/g++ -o caConnTest  -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        caConnTestMain.o caConnTest.o    -lca -lCom
/usr/bin/g++ -o casw  -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        casw.o    -lca -lCom
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../include/os/Linux -I../../../include         ../caEventRateMain.cpp
/usr/bin/g++ -o caEventRate  -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        caEventRateMain.o caEventRate.o    -lca -lCom
Installing binary ../../../bin/linux-x86/caRepeater
Installing binary ../../../bin/linux-x86/catime
Installing binary ../../../bin/linux-x86/acctst
Installing binary ../../../bin/linux-x86/caConnTest
Installing binary ../../../bin/linux-x86/casw
Installing binary ../../../bin/linux-x86/caEventRate
Installing binary ../../../bin/linux-x86/catime.o
Installing binary ../../../bin/linux-x86/acctst.o
Installing binary ../../../bin/linux-x86/caConnTest.o
Installing binary ../../../bin/linux-x86/casw.o
Installing binary ../../../bin/linux-x86/caEventRate.o
Installing html ../../../html//CAref.html
make -C O.linux-arm -f ../Makefile TOP=../../.. T_A=linux-arm install
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/ca/O.linux-arm'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/ca/O.linux-arm'
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../catime.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../acctst.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../caConnTest.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../casw.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../caEventRate.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../cac.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../cacChannel.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../cacChannelNotify.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../cacContextNotify.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../cacReadNotify.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../cacWriteNotify.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../cacStateNotify.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../access.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../iocinf.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../convert.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../test_event.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../repeater.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../searchTimer.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../disconnectGovernorTimer.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../repeaterSubscribeTimer.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../baseNMIU.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../nciu.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../netiiu.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../udpiiu.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../tcpiiu.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../noopiiu.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../netReadNotifyIO.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../netWriteNotifyIO.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../netSubscription.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../tcpSendWatchdog.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../tcpRecvWatchdog.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../bhe.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../ca_client_context.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../oldChannelNotify.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../oldSubscription.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../getCallback.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../getCopy.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../putCallback.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../syncgrp.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../CASG.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../syncGroupNotify.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../syncGroupReadNotify.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../syncGroupWriteNotify.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../localHostName.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../comQueRecv.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../comQueSend.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../comBuf.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../hostNameCache.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../msgForMultiplyDefinedPV.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-ar -rc   libca.a       cac.o cacChannel.o cacChannelNotify.o cacContextNotify.o cacReadNotify.o cacWriteNotify.o cacStateNotify.o access.o iocinf.o convert.o test_event.o repeater.o searchTimer.o disconnectGovernorTimer.o repeaterSubscribeTimer.o baseNMIU.o nciu.o netiiu.o udpiiu.o tcpiiu.o noopiiu.o netReadNotifyIO.o netWriteNotifyIO.o netSubscription.o tcpSendWatchdog.o tcpRecvWatchdog.o bhe.o ca_client_context.o oldChannelNotify.o oldSubscription.o getCallback.o getCopy.o putCallback.o syncgrp.o CASG.o syncGroupNotify.o syncGroupReadNotify.o syncGroupWriteNotify.o localHostName.o comQueRecv.o comQueSend.o comBuf.o hostNameCache.o msgForMultiplyDefinedPV.o
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib libca.a
Installing library ../../../lib/linux-arm/libca.a
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib ../../../lib/linux-arm/libca.a
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o libca.so -shared -fPIC -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm         cac.o cacChannel.o cacChannelNotify.o cacContextNotify.o cacReadNotify.o cacWriteNotify.o cacStateNotify.o access.o iocinf.o convert.o test_event.o repeater.o searchTimer.o disconnectGovernorTimer.o repeaterSubscribeTimer.o baseNMIU.o nciu.o netiiu.o udpiiu.o tcpiiu.o noopiiu.o netReadNotifyIO.o netWriteNotifyIO.o netSubscription.o tcpSendWatchdog.o tcpRecvWatchdog.o bhe.o ca_client_context.o oldChannelNotify.o oldSubscription.o getCallback.o getCopy.o putCallback.o syncgrp.o CASG.o syncGroupNotify.o syncGroupReadNotify.o syncGroupWriteNotify.o localHostName.o comQueRecv.o comQueSend.o comBuf.o hostNameCache.o msgForMultiplyDefinedPV.o   -lCom  -lpthread    -lm -lrt -lgcc
Installing shared library ../../../lib/linux-arm/libca.so
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../caRepeater.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o caRepeater  -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm        caRepeater.o    -lca -lCom
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../catimeMain.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o catime  -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm        catimeMain.o catime.o    -lca -lCom
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../acctstMain.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o acctst  -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm        acctstMain.o acctst.o    -lca -lCom
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../caConnTestMain.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o caConnTest  -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm        caConnTestMain.o caConnTest.o    -lca -lCom
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o casw  -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm        casw.o    -lca -lCom
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../caEventRateMain.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o caEventRate  -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm        caEventRateMain.o caEventRate.o    -lca -lCom
Installing binary ../../../bin/linux-arm/caRepeater
Installing binary ../../../bin/linux-arm/catime
Installing binary ../../../bin/linux-arm/acctst
Installing binary ../../../bin/linux-arm/caConnTest
Installing binary ../../../bin/linux-arm/casw
Installing binary ../../../bin/linux-arm/caEventRate
Installing binary ../../../bin/linux-arm/catime.o
Installing binary ../../../bin/linux-arm/acctst.o
Installing binary ../../../bin/linux-arm/caConnTest.o
Installing binary ../../../bin/linux-arm/casw.o
Installing binary ../../../bin/linux-arm/caEventRate.o
make[2]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/ca'
make -C dbStatic install
make[2]: Entering directory `/usr/local/epics/base-3.14.8.2/src/dbStatic'
mkdir O.Common
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/dbStatic/O.linux-x86'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/dbStatic/O.linux-x86'
Installing generic include file ../../../include/alarm.h
Installing generic include file ../../../include/alarmString.h
Installing generic include file ../../../include/dbBase.h
Installing generic include file ../../../include/dbFldTypes.h
Installing generic include file ../../../include/dbStaticLib.h
Installing generic include file ../../../include/dbStaticPvt.h
Installing generic include file ../../../include/link.h
Installing generic include file ../../../include/special.h
Installing generic include file ../../../include/guigroup.h
Installing generic include file ../../../include/devSup.h
Installing generic include file ../../../include/drvSup.h
Installing generic include file ../../../include/recSup.h
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbStaticLib.c
/usr/local/epics/base-3.14.8.2/bin/linux-x86/e_flex -S/usr/local/epics/base-3.14.8.2/include/flex.skel.static -8 ../dbLex.l
mv lex.yy.c dbLex.c
rm -f dbYacc.c y.tab.c
/usr/local/epics/base-3.14.8.2/bin/linux-x86/antelope  ../dbYacc.y
mv y.tab.c dbYacc.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         dbYacc.c
In file included from ../dbYacc.y:245:
../dbLex.l: In function 'yylex':
../dbLex.l:46: warning: pointer targets in passing argument 1 of 'strlen' differ in signedness
../dbLex.l:47: warning: pointer targets in passing argument 2 of 'strcpy' differ in signedness
../dbLex.l:52: warning: pointer targets in passing argument 1 of 'strlen' differ in signedness
../dbLex.l:53: warning: pointer targets in passing argument 2 of 'strcpy' differ in signedness
../dbLex.l:59: warning: pointer targets in passing argument 1 of 'strlen' differ in signedness
../dbLex.l:60: warning: pointer targets in passing argument 2 of 'strcpy' differ in signedness
../dbLex.l:65: warning: pointer targets in passing argument 1 of 'strlen' differ in signedness
../dbLex.l:67: warning: pointer targets in passing argument 2 of '__builtin_strncpy' differ in signedness
../dbLex.l:73: warning: pointer targets in passing argument 1 of 'strlen' differ in signedness
../dbLex.l:74: warning: pointer targets in passing argument 2 of 'strcpy' differ in signedness
../dbLex.l:94: warning: pointer targets in passing argument 2 of 'yyunput' differ in signedness
../dbLex.l: In function 'yy_get_next_buffer':
../dbLex.l:266: warning: pointer targets in passing argument 1 of 'db_yyinput' differ in signedness
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbPvdLib.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbStaticNoRun.c
/usr/bin/ar -rc   libdbStaticHost.a      dbStaticNoRun.o dbStaticLib.o dbYacc.o dbPvdLib.o
/usr/bin/ranlib libdbStaticHost.a
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbStaticRun.c
/usr/bin/ar -rc   libdbStaticIoc.a      dbStaticRun.o dbStaticLib.o dbYacc.o dbPvdLib.o
/usr/bin/ranlib libdbStaticIoc.a
Installing library ../../../lib/linux-x86/libdbStaticHost.a
/usr/bin/ranlib ../../../lib/linux-x86/libdbStaticHost.a
Installing library ../../../lib/linux-x86/libdbStaticIoc.a
/usr/bin/ranlib ../../../lib/linux-x86/libdbStaticIoc.a
/usr/bin/g++ -o libdbStaticHost.so -shared -fPIC -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        dbStaticNoRun.o dbStaticLib.o dbYacc.o dbPvdLib.o   -lCom  -lpthread   -lreadline -lcurses -lm -lrt -lgcc
/usr/bin/g++ -o libdbStaticIoc.so -shared -fPIC -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        dbStaticRun.o dbStaticLib.o dbYacc.o dbPvdLib.o   -lCom  -lpthread   -lreadline -lcurses -lm -lrt -lgcc
Installing shared library ../../../lib/linux-x86/libdbStaticHost.so
Installing shared library ../../../lib/linux-x86/libdbStaticIoc.so
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbReadTest.c
/usr/bin/g++ -o dbReadTest  -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        dbReadTest.o    -ldbStaticHost -lCom
Installing binary ../../../bin/linux-x86/dbReadTest
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbExpand.c
/usr/bin/g++ -o dbExpand  -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        dbExpand.o    -ldbStaticHost -lCom
Installing binary ../../../bin/linux-x86/dbExpand
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbToMenuH.c
/usr/bin/g++ -o dbToMenuH  -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        dbToMenuH.o    -ldbStaticHost -lCom
Installing binary ../../../bin/linux-x86/dbToMenuH
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbToRecordtypeH.c
/usr/bin/g++ -o dbToRecordtypeH  -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        dbToRecordtypeH.o    -ldbStaticHost -lCom
Installing binary ../../../bin/linux-x86/dbToRecordtypeH
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/dbStatic/O.linux-arm'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/dbStatic/O.linux-arm'
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbStaticLib.c
mv lex.yy.c dbLex.c
mv y.tab.c dbYacc.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  dbYacc.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbPvdLib.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbStaticNoRun.c
/usr/local/armlinux/3.3.3/bin/arm-linux-ar -rc   libdbStaticHost.a      dbStaticNoRun.o dbStaticLib.o dbYacc.o dbPvdLib.o
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib libdbStaticHost.a
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbStaticRun.c
/usr/local/armlinux/3.3.3/bin/arm-linux-ar -rc   libdbStaticIoc.a      dbStaticRun.o dbStaticLib.o dbYacc.o dbPvdLib.o
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib libdbStaticIoc.a
Installing library ../../../lib/linux-arm/libdbStaticHost.a
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib ../../../lib/linux-arm/libdbStaticHost.a
Installing library ../../../lib/linux-arm/libdbStaticIoc.a
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib ../../../lib/linux-arm/libdbStaticIoc.a
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o libdbStaticHost.so -shared -fPIC -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm        dbStaticNoRun.o dbStaticLib.o dbYacc.o dbPvdLib.o   -lCom  -lpthread    -lm -lrt -lgcc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o libdbStaticIoc.so -shared -fPIC -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm        dbStaticRun.o dbStaticLib.o dbYacc.o dbPvdLib.o   -lCom  -lpthread    -lm -lrt -lgcc
Installing shared library ../../../lib/linux-arm/libdbStaticHost.so
Installing shared library ../../../lib/linux-arm/libdbStaticIoc.so
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbReadTest.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o dbReadTest  -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm        dbReadTest.o    -ldbStaticHost -lCom
Installing binary ../../../bin/linux-arm/dbReadTest
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbExpand.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o dbExpand  -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm        dbExpand.o    -ldbStaticHost -lCom
Installing binary ../../../bin/linux-arm/dbExpand
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbToMenuH.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o dbToMenuH  -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm        dbToMenuH.o    -ldbStaticHost -lCom
Installing binary ../../../bin/linux-arm/dbToMenuH
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbToRecordtypeH.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o dbToRecordtypeH  -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm        dbToRecordtypeH.o    -ldbStaticHost -lCom
Installing binary ../../../bin/linux-arm/dbToRecordtypeH
make[2]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/dbStatic'
make -C registry install
make[2]: Entering directory `/usr/local/epics/base-3.14.8.2/src/registry'
mkdir O.Common
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/registry/O.linux-x86'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/registry/O.linux-x86'
Installing generic include file ../../../include/registry.h
Installing generic include file ../../../include/registryRecordType.h
Installing generic include file ../../../include/registryDeviceSupport.h
Installing generic include file ../../../include/registryDriverSupport.h
Installing generic include file ../../../include/registryFunction.h
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../registry.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../registryRecordType.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../registryDeviceSupport.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../registryDriverSupport.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../registryFunction.c
/usr/bin/ar -rc   libregistryIoc.a       registry.o registryRecordType.o registryDeviceSupport.o registryDriverSupport.o registryFunction.o
/usr/bin/ranlib libregistryIoc.a
Installing library ../../../lib/linux-x86/libregistryIoc.a
/usr/bin/ranlib ../../../lib/linux-x86/libregistryIoc.a
/usr/bin/g++ -o libregistryIoc.so -shared -fPIC -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86         registry.o registryRecordType.o registryDeviceSupport.o registryDriverSupport.o registryFunction.o   -lCom  -lpthread   -lreadline -lcurses -lm -lrt -lgcc
Installing shared library ../../../lib/linux-x86/libregistryIoc.so
Installing script ../../../bin/linux-x86/registerRecordDeviceDriver.pl
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/registry/O.linux-arm'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/registry/O.linux-arm'
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../registry.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../registryRecordType.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../registryDeviceSupport.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../registryDriverSupport.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../registryFunction.c
/usr/local/armlinux/3.3.3/bin/arm-linux-ar -rc   libregistryIoc.a       registry.o registryRecordType.o registryDeviceSupport.o registryDriverSupport.o registryFunction.o
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib libregistryIoc.a
Installing library ../../../lib/linux-arm/libregistryIoc.a
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib ../../../lib/linux-arm/libregistryIoc.a
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o libregistryIoc.so -shared -fPIC -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm         registry.o registryRecordType.o registryDeviceSupport.o registryDriverSupport.o registryFunction.o   -lCom  -lpthread    -lm -lrt -lgcc
Installing shared library ../../../lib/linux-arm/libregistryIoc.so
Installing script ../../../bin/linux-arm/registerRecordDeviceDriver.pl
make[2]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/registry'
make -C bpt install
make[2]: Entering directory `/usr/local/epics/base-3.14.8.2/src/bpt'
mkdir O.Common
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/bpt/O.linux-x86'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/bpt/O.linux-x86'
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../include/os/Linux -I../../../include         ../makeBpt.c
/usr/bin/g++ -o makeBpt  -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        makeBpt.o    -lCom
Installing binary ../../../bin/linux-x86/makeBpt
/usr/local/epics/base-3.14.8.2/bin/linux-x86/makeBpt ../bptTypeJdegC.data ../O.Common/bptTypeJdegC.dbd
/usr/local/epics/base-3.14.8.2/bin/linux-x86/makeBpt ../bptTypeJdegF.data ../O.Common/bptTypeJdegF.dbd
/usr/local/epics/base-3.14.8.2/bin/linux-x86/makeBpt ../bptTypeKdegC.data ../O.Common/bptTypeKdegC.dbd
/usr/local/epics/base-3.14.8.2/bin/linux-x86/makeBpt ../bptTypeKdegF.data ../O.Common/bptTypeKdegF.dbd
Installing dbd file ../../../dbd/menuConvert.dbd
mkdir ../../../dbd
Installing dbd file ../../../dbd/bptTypeJdegC.dbd
Installing dbd file ../../../dbd/bptTypeJdegF.dbd
Installing dbd file ../../../dbd/bptTypeKdegC.dbd
Installing dbd file ../../../dbd/bptTypeKdegF.dbd
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToMenuH ../menuConvert.dbd ../O.Common/menuConvert.h
Installing generic include file ../../../include/cvtTable.h
Installing generated generic include file ../../../include/menuConvert.h
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/bpt/O.linux-arm'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/bpt/O.linux-arm'
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../makeBpt.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o makeBpt  -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm        makeBpt.o    -lCom
Installing binary ../../../bin/linux-arm/makeBpt
make[2]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/bpt'
make -C db install
make[2]: Entering directory `/usr/local/epics/base-3.14.8.2/src/db'
mkdir O.Common
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/db/O.linux-x86'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/db/O.linux-x86'
Installing dbd file ../../../dbd/dbCommon.dbd
Installing dbd file ../../../dbd/menuGlobal.dbd
Installing dbd file ../../../dbd/menuAlarmSevr.dbd
Installing dbd file ../../../dbd/menuAlarmStat.dbd
Installing dbd file ../../../dbd/menuArrType.dbd
Installing dbd file ../../../dbd/menuCompress.dbd
Installing dbd file ../../../dbd/menuFtype.dbd
Installing dbd file ../../../dbd/menuIvoa.dbd
Installing dbd file ../../../dbd/menuOmsl.dbd
Installing dbd file ../../../dbd/menuPriority.dbd
Installing dbd file ../../../dbd/menuScan.dbd
Installing dbd file ../../../dbd/menuYesNo.dbd
Installing dbd file ../../../dbd/menuSimm.dbd
rm -f ../O.Common/dbCommon.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToRecordtypeH -I .. ../dbCommonRecord.dbd ../O.Common/dbCommon.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToMenuH ../menuAlarmSevr.dbd ../O.Common/menuAlarmSevr.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToMenuH ../menuAlarmStat.dbd ../O.Common/menuAlarmStat.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToMenuH ../menuArrType.dbd ../O.Common/menuArrType.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToMenuH ../menuCompress.dbd ../O.Common/menuCompress.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToMenuH ../menuFtype.dbd ../O.Common/menuFtype.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToMenuH ../menuIvoa.dbd ../O.Common/menuIvoa.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToMenuH ../menuOmsl.dbd ../O.Common/menuOmsl.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToMenuH ../menuPriority.dbd ../O.Common/menuPriority.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToMenuH ../menuScan.dbd ../O.Common/menuScan.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToMenuH ../menuYesNo.dbd ../O.Common/menuYesNo.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToMenuH ../menuSimm.dbd ../O.Common/menuSimm.h
Installing generic include file ../../../include/callback.h
Installing generic include file ../../../include/dbAccess.h
Installing generic include file ../../../include/dbAccessDefs.h
Installing generic include file ../../../include/dbCa.h
Installing generic include file ../../../include/dbAddr.h
Installing generic include file ../../../include/dbBkpt.h
Installing generic include file ../../../include/dbConvert.h
Installing generic include file ../../../include/dbConvertFast.h
Installing generic include file ../../../include/dbEvent.h
Installing generic include file ../../../include/dbLock.h
Installing generic include file ../../../include/dbNotify.h
Installing generic include file ../../../include/dbScan.h
Installing generic include file ../../../include/dbTest.h
Installing generic include file ../../../include/dbCaTest.h
Installing generic include file ../../../include/db_test.h
Installing generic include file ../../../include/db_field_log.h
Installing generic include file ../../../include/initHooks.h
Installing generic include file ../../../include/recGbl.h
Installing generic include file ../../../include/db_access_routines.h
Installing generic include file ../../../include/db_convert.h
Installing generated generic include file ../../../include/dbCommon.h
Installing generated generic include file ../../../include/menuAlarmSevr.h
Installing generated generic include file ../../../include/menuAlarmStat.h
Installing generated generic include file ../../../include/menuArrType.h
Installing generated generic include file ../../../include/menuCompress.h
Installing generated generic include file ../../../include/menuFtype.h
Installing generated generic include file ../../../include/menuIvoa.h
Installing generated generic include file ../../../include/menuOmsl.h
Installing generated generic include file ../../../include/menuPriority.h
Installing generated generic include file ../../../include/menuScan.h
Installing generated generic include file ../../../include/menuYesNo.h
Installing generated generic include file ../../../include/menuSimm.h
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbLock.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbAccess.c
../dbAccess.c: In function 'dbGetField':
../dbAccess.c:924: warning: dereferencing type-punned pointer will break strict-aliasing rules
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbBkpt.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbConvert.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbFastLinkConv.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbNotify.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbScan.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbEvent.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbTest.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../db_access.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../db_test.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../recGbl.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../callback.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbCa.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbCaTest.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../initHooks.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../cvtBpt.c
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbContext.cpp
../dbCAC.h:66: warning: 'class dbBaseIO' has virtual functions but non-virtual destructor
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbChannelIO.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbSubscriptionIO.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbPutNotifyBlocker.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbContextReadNotifyCache.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../templateInstances.cpp
/usr/bin/ar -rc   libdbIoc.a       dbLock.o dbAccess.o dbBkpt.o dbConvert.o dbFastLinkConv.o dbNotify.o dbScan.o dbEvent.o dbTest.o db_access.o db_test.o recGbl.o callback.o dbCa.o dbCaTest.o initHooks.o cvtBpt.o dbContext.o dbChannelIO.o dbSubscriptionIO.o dbPutNotifyBlocker.o dbContextReadNotifyCache.o templateInstances.o
/usr/bin/ranlib libdbIoc.a
Installing library ../../../lib/linux-x86/libdbIoc.a
/usr/bin/ranlib ../../../lib/linux-x86/libdbIoc.a
/usr/bin/g++ -o libdbIoc.so -shared -fPIC -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86         dbLock.o dbAccess.o dbBkpt.o dbConvert.o dbFastLinkConv.o dbNotify.o dbScan.o dbEvent.o dbTest.o db_access.o db_test.o recGbl.o callback.o dbCa.o dbCaTest.o initHooks.o cvtBpt.o dbContext.o dbChannelIO.o dbSubscriptionIO.o dbPutNotifyBlocker.o dbContextReadNotifyCache.o templateInstances.o   -ldbStaticIoc -lca -lCom  -lpthread   -lreadline -lcurses -lm -lrt -lgcc
Installing shared library ../../../lib/linux-x86/libdbIoc.so
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/db/O.linux-arm'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/db/O.linux-arm'
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbLock.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbAccess.c
../dbAccess.c: In function `dbGetField':
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbBkpt.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbConvert.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbFastLinkConv.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbNotify.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbScan.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbEvent.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbTest.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../db_access.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../db_test.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../recGbl.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../callback.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbCa.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbCaTest.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../initHooks.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../cvtBpt.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbContext.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbChannelIO.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbSubscriptionIO.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbPutNotifyBlocker.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbContextReadNotifyCache.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../templateInstances.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-ar -rc   libdbIoc.a       dbLock.o dbAccess.o dbBkpt.o dbConvert.o dbFastLinkConv.o dbNotify.o dbScan.o dbEvent.o dbTest.o db_access.o db_test.o recGbl.o callback.o dbCa.o dbCaTest.o initHooks.o cvtBpt.o dbContext.o dbChannelIO.o dbSubscriptionIO.o dbPutNotifyBlocker.o dbContextReadNotifyCache.o templateInstances.o
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib libdbIoc.a
Installing library ../../../lib/linux-arm/libdbIoc.a
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib ../../../lib/linux-arm/libdbIoc.a
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o libdbIoc.so -shared -fPIC -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm         dbLock.o dbAccess.o dbBkpt.o dbConvert.o dbFastLinkConv.o dbNotify.o dbScan.o dbEvent.o dbTest.o db_access.o db_test.o recGbl.o callback.o dbCa.o dbCaTest.o initHooks.o cvtBpt.o dbContext.o dbChannelIO.o dbSubscriptionIO.o dbPutNotifyBlocker.o dbContextReadNotifyCache.o templateInstances.o   -ldbStaticIoc -lca -lCom  -lpthread    -lm -lrt -lgcc
Installing shared library ../../../lib/linux-arm/libdbIoc.so
make[2]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/db'
make -C db/test install
make[2]: Entering directory `/usr/local/epics/base-3.14.8.2/src/db/test'
perl ../../../configure/tools/makeMakefile.pl O.linux-x86 ../../../..
perl ../../../configure/tools/makeMakefile.pl O.linux-arm ../../../..
mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../../../.. T_A=linux-x86 install
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/db/test/O.linux-x86'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/db/test/O.linux-x86'
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../callbackTestMain.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../callbackTest.c
/usr/bin/g++ -o callbackTestHost  -L../../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        callbackTestMain.o callbackTest.o    -ldbIoc -ldbStaticHost -lca -lCom
Installing binary ../../../../bin/linux-x86/callbackTestHost
make -C O.linux-arm -f ../Makefile TOP=../../../.. T_A=linux-arm install
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/db/test/O.linux-arm'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/db/test/O.linux-arm'
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../callbackTestMain.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../callbackTest.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o callbackTestHost  -L../../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../../lib/linux-arm        callbackTestMain.o callbackTest.o    -ldbIoc -ldbStaticHost -lca -lCom
Installing binary ../../../../bin/linux-arm/callbackTestHost
make[2]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/db/test'
make -C as install
make[2]: Entering directory `/usr/local/epics/base-3.14.8.2/src/as'
perl ../../configure/tools/makeMakefile.pl O.linux-x86 ../../..
perl ../../configure/tools/makeMakefile.pl O.linux-arm ../../..
mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/as/O.linux-x86'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/as/O.linux-x86'
Installing generic include file ../../../include/asLib.h
Installing generic include file ../../../include/asDbLib.h
Installing generic include file ../../../include/asCa.h
Installing generic include file ../../../include/asTrapWrite.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/e_flex -S/usr/local/epics/base-3.14.8.2/include/flex.skel.static -8 ../asLib_lex.l
mv lex.yy.c asLib_lex.c
rm -f asLib.c y.tab.c
/usr/local/epics/base-3.14.8.2/bin/linux-x86/antelope  ../asLib.y
mv y.tab.c asLib.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         asLib.c
In file included from ../asLib.y:211:
../asLib_lex.l: In function 'yylex':
../asLib_lex.l:44: warning: pointer targets in passing argument 1 of 'sscanf' differ in signedness
../asLib_lex.l:49: warning: pointer targets in passing argument 1 of 'strlen' differ in signedness
../asLib_lex.l:50: warning: pointer targets in passing argument 2 of 'strcpy' differ in signedness
../asLib_lex.l:55: warning: pointer targets in passing argument 1 of 'strlen' differ in signedness
../asLib_lex.l:57: warning: pointer targets in passing argument 2 of 'strcpy' differ in signedness
../asLib_lex.l:78: warning: pointer targets in passing argument 2 of 'yyunput' differ in signedness
../asLib_lex.l: In function 'yy_get_next_buffer':
../asLib_lex.l:250: warning: pointer targets in passing argument 1 of '*my_yyinput' differ in signedness
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../asTrapWrite.c
/usr/bin/ar -rc   libasHost.a       asLib.o asTrapWrite.o
/usr/bin/ranlib libasHost.a
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../asDbLib.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../asCa.c
/usr/bin/ar -rc   libasIoc.a      asDbLib.o asCa.o asLib.o asTrapWrite.o
/usr/bin/ranlib libasIoc.a
Installing library ../../../lib/linux-x86/libasHost.a
/usr/bin/ranlib ../../../lib/linux-x86/libasHost.a
Installing library ../../../lib/linux-x86/libasIoc.a
/usr/bin/ranlib ../../../lib/linux-x86/libasIoc.a
/usr/bin/g++ -o libasHost.so -shared -fPIC -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86         asLib.o asTrapWrite.o   -ldbStaticHost -lca -lCom  -lpthread   -lreadline -lcurses -lm -lrt -lgcc
/usr/bin/g++ -o libasIoc.so -shared -fPIC -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        asDbLib.o asCa.o asLib.o asTrapWrite.o   -ldbIoc -ldbStaticIoc -lca -lCom  -lpthread   -lreadline -lcurses -lm -lrt -lgcc
Installing shared library ../../../lib/linux-x86/libasHost.so
Installing shared library ../../../lib/linux-x86/libasIoc.so
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../include/os/Linux -I../../../include         ../ascheck.c
/usr/bin/g++ -o ascheck  -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        ascheck.o    -lasHost -ldbStaticHost -lCom
Installing binary ../../../bin/linux-x86/ascheck
make -C O.linux-arm -f ../Makefile TOP=../../.. T_A=linux-arm install
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/as/O.linux-arm'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/as/O.linux-arm'
mv y.tab.c asLib.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  asLib.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../asTrapWrite.c
/usr/local/armlinux/3.3.3/bin/arm-linux-ar -rc   libasHost.a       asLib.o asTrapWrite.o
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib libasHost.a
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../asDbLib.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../asCa.c
/usr/local/armlinux/3.3.3/bin/arm-linux-ar -rc   libasIoc.a      asDbLib.o asCa.o asLib.o asTrapWrite.o
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib libasIoc.a
Installing library ../../../lib/linux-arm/libasHost.a
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib ../../../lib/linux-arm/libasHost.a
Installing library ../../../lib/linux-arm/libasIoc.a
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib ../../../lib/linux-arm/libasIoc.a
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o libasHost.so -shared -fPIC -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm         asLib.o asTrapWrite.o   -ldbStaticHost -lca -lCom  -lpthread    -lm -lrt -lgcc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o libasIoc.so -shared -fPIC -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm        asDbLib.o asCa.o asLib.o asTrapWrite.o   -ldbIoc -ldbStaticIoc -lca -lCom  -lpthread    -lm -lrt -lgcc
Installing shared library ../../../lib/linux-arm/libasHost.so
Installing shared library ../../../lib/linux-arm/libasIoc.so
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../ascheck.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o ascheck  -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm        ascheck.o    -lasHost -ldbStaticHost -lCom
Installing binary ../../../bin/linux-arm/ascheck
make[2]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/as'
make -C util install
make[2]: Entering directory `/usr/local/epics/base-3.14.8.2/src/util'
mkdir O.Common
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/util/O.linux-x86'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/util/O.linux-x86'
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../include/os/Linux -I../../../include         ../ca_test_main.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../include/os/Linux -I../../../include         ../ca_test.c
/usr/bin/g++ -o ca_test  -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        ca_test_main.o ca_test.o    -lca -lCom
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../include/os/Linux -I../../../include         ../iocLogServer.c
/usr/bin/g++ -o iocLogServer  -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        iocLogServer.o    -lca -lCom
Installing binary ../../../bin/linux-x86/ca_test
Installing binary ../../../bin/linux-x86/iocLogServer
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/util/O.linux-arm'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/util/O.linux-arm'
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../ca_test_main.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../ca_test.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o ca_test  -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm        ca_test_main.o ca_test.o    -lca -lCom
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../iocLogServer.c
../iocLogServer.c: In function `seekLatestLine':
../iocLogServer.c:304: warning: comparison is always true due to limited range of data type
../iocLogServer.c:308: warning: comparison is always false due to limited range of data type
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o iocLogServer  -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm        iocLogServer.o    -lca -lCom
Installing binary ../../../bin/linux-arm/ca_test
Installing binary ../../../bin/linux-arm/iocLogServer
make[2]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/util'
make -C dbtools install
make[2]: Entering directory `/usr/local/epics/base-3.14.8.2/src/dbtools'
mkdir O.Common
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/dbtools/O.linux-x86'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/dbtools/O.linux-x86'
Installing generic include file ../../../include/dbLoadTemplate.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/e_flex -S/usr/local/epics/base-3.14.8.2/include/flex.skel.static -8 ../dbLoadTemplate_lex.l
mv lex.yy.c dbLoadTemplate_lex.c
rm -f dbLoadTemplate.c y.tab.c
/usr/local/epics/base-3.14.8.2/bin/linux-x86/antelope  ../dbLoadTemplate.y
mv y.tab.c dbLoadTemplate.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         dbLoadTemplate.c
In file included from ../dbLoadTemplate.y:242:
../dbLoadTemplate_lex.l: In function 'yylex':
../dbLoadTemplate_lex.l:20: warning: pointer targets in passing argument 1 of 'strlen' differ in signedness
../dbLoadTemplate_lex.l:21: warning: pointer targets in passing argument 2 of 'strcpy' differ in signedness
../dbLoadTemplate_lex.l:26: warning: pointer targets in passing argument 1 of 'strlen' differ in signedness
../dbLoadTemplate_lex.l:27: warning: pointer targets in passing argument 2 of 'strcpy' differ in signedness
y.tab.c: At top level:
../dbLoadTemplate.y:30: warning: 'macHandle' defined but not used
../dbLoadTemplate_lex.l:322: warning: 'yyunput' defined but not used
../dbLoadTemplate_lex.l:453: warning: 'yy_switch_to_buffer' defined but not used
/usr/bin/ar -rc   libdbtoolsIoc.a       dbLoadTemplate.o
/usr/bin/ranlib libdbtoolsIoc.a
Installing library ../../../lib/linux-x86/libdbtoolsIoc.a
/usr/bin/ranlib ../../../lib/linux-x86/libdbtoolsIoc.a
/usr/bin/g++ -o libdbtoolsIoc.so -shared -fPIC -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86         dbLoadTemplate.o   -ldbIoc -lCom  -lpthread   -lreadline -lcurses -lm -lrt -lgcc
Installing shared library ../../../lib/linux-x86/libdbtoolsIoc.so
Installing html ../../../html//dbLoadTemplate.html
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/dbtools/O.linux-arm'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/dbtools/O.linux-arm'
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  dbLoadTemplate.c
../dbLoadTemplate.y:30: warning: `macHandle' defined but not used
../dbLoadTemplate_lex.l:322: warning: `yyunput' defined but not used
../dbLoadTemplate_lex.l:453: warning: `yy_switch_to_buffer' defined but not used
/usr/local/armlinux/3.3.3/bin/arm-linux-ar -rc   libdbtoolsIoc.a       dbLoadTemplate.o
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib libdbtoolsIoc.a
Installing library ../../../lib/linux-arm/libdbtoolsIoc.a
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib ../../../lib/linux-arm/libdbtoolsIoc.a
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o libdbtoolsIoc.so -shared -fPIC -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm         dbLoadTemplate.o   -ldbIoc -lCom  -lpthread    -lm -lrt -lgcc
Installing shared library ../../../lib/linux-arm/libdbtoolsIoc.so
make[2]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/dbtools'
make -C catools install
make[2]: Entering directory `/usr/local/epics/base-3.14.8.2/src/catools'
mkdir O.Common
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/catools/O.linux-x86'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/catools/O.linux-x86'
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../tool_lib.c
/usr/bin/ar -rc   libcatools.a      tool_lib.o
/usr/bin/ranlib libcatools.a
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../include/os/Linux -I../../../include         ../caget.c
/usr/bin/g++ -o caget  -L../../../lib/linux-x86/ -L./         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        caget.o    -lcatools -lca -lCom  -lpthread   -lreadline -lcurses -lm -lrt -lgcc
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../include/os/Linux -I../../../include         ../camonitor.c
/usr/bin/g++ -o camonitor  -L../../../lib/linux-x86/ -L./         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        camonitor.o    -lcatools -lca -lCom  -lpthread   -lreadline -lcurses -lm -lrt -lgcc
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../include/os/Linux -I../../../include         ../cainfo.c
/usr/bin/g++ -o cainfo  -L../../../lib/linux-x86/ -L./         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        cainfo.o    -lcatools -lca -lCom  -lpthread   -lreadline -lcurses -lm -lrt -lgcc
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../include/os/Linux -I../../../include         ../caput.c
/usr/bin/g++ -o caput  -L../../../lib/linux-x86/ -L./         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        caput.o    -lcatools -lca -lCom  -lpthread   -lreadline -lcurses -lm -lrt -lgcc
Installing binary ../../../bin/linux-x86/caget
Installing binary ../../../bin/linux-x86/camonitor
Installing binary ../../../bin/linux-x86/cainfo
Installing binary ../../../bin/linux-x86/caput
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/catools/O.linux-arm'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/catools/O.linux-arm'
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../tool_lib.c
/usr/local/armlinux/3.3.3/bin/arm-linux-ar -rc   libcatools.a      tool_lib.o
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib libcatools.a
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../caget.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o caget  -L../../../lib/linux-arm/ -L./        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm        caget.o    -lcatools -lca -lCom  -lpthread    -lm -lrt -lgcc
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../camonitor.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o camonitor  -L../../../lib/linux-arm/ -L./        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm        camonitor.o    -lcatools -lca -lCom  -lpthread    -lm -lrt -lgcc
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../cainfo.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o cainfo  -L../../../lib/linux-arm/ -L./        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm        cainfo.o    -lcatools -lca -lCom  -lpthread    -lm -lrt -lgcc
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../caput.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o caput  -L../../../lib/linux-arm/ -L./        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm        caput.o    -lcatools -lca -lCom  -lpthread    -lm -lrt -lgcc
Installing binary ../../../bin/linux-arm/caget
Installing binary ../../../bin/linux-arm/camonitor
Installing binary ../../../bin/linux-arm/cainfo
Installing binary ../../../bin/linux-arm/caput
make[2]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/catools'
make -C rsrv install
make[2]: Entering directory `/usr/local/epics/base-3.14.8.2/src/rsrv'
mkdir O.Common
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/rsrv/O.linux-x86'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/rsrv/O.linux-x86'
Installing generic include file ../../../include/rsrv.h
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include     -I../../ca    ../caserverio.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include     -I../../ca    ../caservertask.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include     -I../../ca    ../camsgtask.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include     -I../../ca    ../camessage.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include     -I../../ca    ../cast_server.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include     -I../../ca    ../online_notify.c
/usr/bin/ar -rc   librsrvIoc.a       caserverio.o caservertask.o camsgtask.o camessage.o cast_server.o online_notify.o
/usr/bin/ranlib librsrvIoc.a
Installing library ../../../lib/linux-x86/librsrvIoc.a
/usr/bin/ranlib ../../../lib/linux-x86/librsrvIoc.a
/usr/bin/g++ -o librsrvIoc.so -shared -fPIC -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86         caserverio.o caservertask.o camsgtask.o camessage.o cast_server.o online_notify.o   -lasIoc -ldbIoc -lca -lCom  -lpthread   -lreadline -lcurses -lm -lrt -lgcc
Installing shared library ../../../lib/linux-x86/librsrvIoc.so
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/rsrv/O.linux-arm'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/rsrv/O.linux-arm'
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include     -I../../ca  -I/usr/local/armlinux/3.3.3/arm-linux/include  ../caserverio.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include     -I../../ca  -I/usr/local/armlinux/3.3.3/arm-linux/include  ../caservertask.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include     -I../../ca  -I/usr/local/armlinux/3.3.3/arm-linux/include  ../camsgtask.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include     -I../../ca  -I/usr/local/armlinux/3.3.3/arm-linux/include  ../camessage.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include     -I../../ca  -I/usr/local/armlinux/3.3.3/arm-linux/include  ../cast_server.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include     -I../../ca  -I/usr/local/armlinux/3.3.3/arm-linux/include  ../online_notify.c
/usr/local/armlinux/3.3.3/bin/arm-linux-ar -rc   librsrvIoc.a       caserverio.o caservertask.o camsgtask.o camessage.o cast_server.o online_notify.o
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib librsrvIoc.a
Installing library ../../../lib/linux-arm/librsrvIoc.a
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib ../../../lib/linux-arm/librsrvIoc.a
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o librsrvIoc.so -shared -fPIC -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm         caserverio.o caservertask.o camsgtask.o camessage.o cast_server.o online_notify.o   -lasIoc -ldbIoc -lca -lCom  -lpthread    -lm -lrt -lgcc
Installing shared library ../../../lib/linux-arm/librsrvIoc.so
make[2]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/rsrv'
make -C rec install
make[2]: Entering directory `/usr/local/epics/base-3.14.8.2/src/rec'
mkdir O.Common
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/rec/O.linux-x86'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/rec/O.linux-x86'
Installing dbd file ../../../dbd/aaiRecord.dbd
Installing dbd file ../../../dbd/aaoRecord.dbd
Installing dbd file ../../../dbd/aiRecord.dbd
Installing dbd file ../../../dbd/aoRecord.dbd
Installing dbd file ../../../dbd/biRecord.dbd
Installing dbd file ../../../dbd/boRecord.dbd
Installing dbd file ../../../dbd/calcRecord.dbd
Installing dbd file ../../../dbd/calcoutRecord.dbd
Installing dbd file ../../../dbd/compressRecord.dbd
Installing dbd file ../../../dbd/dfanoutRecord.dbd
Installing dbd file ../../../dbd/eventRecord.dbd
Installing dbd file ../../../dbd/fanoutRecord.dbd
Installing dbd file ../../../dbd/histogramRecord.dbd
Installing dbd file ../../../dbd/longinRecord.dbd
Installing dbd file ../../../dbd/longoutRecord.dbd
Installing dbd file ../../../dbd/mbbiRecord.dbd
Installing dbd file ../../../dbd/mbbiDirectRecord.dbd
Installing dbd file ../../../dbd/mbboRecord.dbd
Installing dbd file ../../../dbd/mbboDirectRecord.dbd
Installing dbd file ../../../dbd/permissiveRecord.dbd
Installing dbd file ../../../dbd/selRecord.dbd
Installing dbd file ../../../dbd/seqRecord.dbd
Installing dbd file ../../../dbd/stateRecord.dbd
Installing dbd file ../../../dbd/stringinRecord.dbd
Installing dbd file ../../../dbd/stringoutRecord.dbd
Installing dbd file ../../../dbd/subRecord.dbd
Installing dbd file ../../../dbd/subArrayRecord.dbd
Installing dbd file ../../../dbd/waveformRecord.dbd
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../../dbd   ../aaiRecord.dbd ../O.Common/aaiRecord.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../../dbd   ../aaoRecord.dbd ../O.Common/aaoRecord.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../../dbd   ../aiRecord.dbd ../O.Common/aiRecord.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../../dbd   ../aoRecord.dbd ../O.Common/aoRecord.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../../dbd   ../biRecord.dbd ../O.Common/biRecord.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../../dbd   ../boRecord.dbd ../O.Common/boRecord.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../../dbd   ../calcRecord.dbd ../O.Common/calcRecord.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../../dbd   ../calcoutRecord.dbd ../O.Common/calcoutRecord.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../../dbd   ../compressRecord.dbd ../O.Common/compressRecord.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../../dbd   ../dfanoutRecord.dbd ../O.Common/dfanoutRecord.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../../dbd   ../eventRecord.dbd ../O.Common/eventRecord.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../../dbd   ../fanoutRecord.dbd ../O.Common/fanoutRecord.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../../dbd   ../histogramRecord.dbd ../O.Common/histogramRecord.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../../dbd   ../longinRecord.dbd ../O.Common/longinRecord.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../../dbd   ../longoutRecord.dbd ../O.Common/longoutRecord.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../../dbd   ../mbbiRecord.dbd ../O.Common/mbbiRecord.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../../dbd   ../mbbiDirectRecord.dbd ../O.Common/mbbiDirectRecord.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../../dbd   ../mbboRecord.dbd ../O.Common/mbboRecord.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../../dbd   ../mbboDirectRecord.dbd ../O.Common/mbboDirectRecord.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../../dbd   ../permissiveRecord.dbd ../O.Common/permissiveRecord.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../../dbd   ../selRecord.dbd ../O.Common/selRecord.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../../dbd   ../seqRecord.dbd ../O.Common/seqRecord.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../../dbd   ../stateRecord.dbd ../O.Common/stateRecord.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../../dbd   ../stringinRecord.dbd ../O.Common/stringinRecord.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../../dbd   ../stringoutRecord.dbd ../O.Common/stringoutRecord.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../../dbd   ../subRecord.dbd ../O.Common/subRecord.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../../dbd   ../subArrayRecord.dbd ../O.Common/subArrayRecord.h
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbToRecordtypeH  -I . -I .. -I ../../../dbd   ../waveformRecord.dbd ../O.Common/waveformRecord.h
Installing generated generic include file ../../../include/aaiRecord.h
Installing generated generic include file ../../../include/aaoRecord.h
Installing generated generic include file ../../../include/aiRecord.h
Installing generated generic include file ../../../include/aoRecord.h
Installing generated generic include file ../../../include/biRecord.h
Installing generated generic include file ../../../include/boRecord.h
Installing generated generic include file ../../../include/calcRecord.h
Installing generated generic include file ../../../include/calcoutRecord.h
Installing generated generic include file ../../../include/compressRecord.h
Installing generated generic include file ../../../include/dfanoutRecord.h
Installing generated generic include file ../../../include/eventRecord.h
Installing generated generic include file ../../../include/fanoutRecord.h
Installing generated generic include file ../../../include/histogramRecord.h
Installing generated generic include file ../../../include/longinRecord.h
Installing generated generic include file ../../../include/longoutRecord.h
Installing generated generic include file ../../../include/mbbiRecord.h
Installing generated generic include file ../../../include/mbbiDirectRecord.h
Installing generated generic include file ../../../include/mbboRecord.h
Installing generated generic include file ../../../include/mbboDirectRecord.h
Installing generated generic include file ../../../include/permissiveRecord.h
Installing generated generic include file ../../../include/selRecord.h
Installing generated generic include file ../../../include/seqRecord.h
Installing generated generic include file ../../../include/stateRecord.h
Installing generated generic include file ../../../include/stringinRecord.h
Installing generated generic include file ../../../include/stringoutRecord.h
Installing generated generic include file ../../../include/subRecord.h
Installing generated generic include file ../../../include/subArrayRecord.h
Installing generated generic include file ../../../include/waveformRecord.h
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../aaiRecord.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../aaoRecord.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../aiRecord.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../aoRecord.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../biRecord.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../boRecord.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../calcRecord.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../calcoutRecord.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../compressRecord.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../dfanoutRecord.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../eventRecord.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../fanoutRecord.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../histogramRecord.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../longinRecord.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../longoutRecord.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../mbbiRecord.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../mbbiDirectRecord.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../mbboRecord.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../mbboDirectRecord.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../permissiveRecord.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../selRecord.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../seqRecord.c
../seqRecord.c: In function 'process':
../seqRecord.c:185: warning: passing argument 1 of 'asyncFinish' from incompatible pointer type
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../stateRecord.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../stringinRecord.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../stringoutRecord.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../subRecord.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../subArrayRecord.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../waveformRecord.c
/usr/bin/ar -rc   librecIoc.a       aaiRecord.o aaoRecord.o aiRecord.o aoRecord.o biRecord.o boRecord.o calcRecord.o calcoutRecord.o compressRecord.o dfanoutRecord.o eventRecord.o fanoutRecord.o histogramRecord.o longinRecord.o longoutRecord.o mbbiRecord.o mbbiDirectRecord.o mbboRecord.o mbboDirectRecord.o permissiveRecord.o selRecord.o seqRecord.o stateRecord.o stringinRecord.o stringoutRecord.o subRecord.o subArrayRecord.o waveformRecord.o
/usr/bin/ranlib librecIoc.a
Installing library ../../../lib/linux-x86/librecIoc.a
/usr/bin/ranlib ../../../lib/linux-x86/librecIoc.a
/usr/bin/g++ -o librecIoc.so -shared -fPIC -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86         aaiRecord.o aaoRecord.o aiRecord.o aoRecord.o biRecord.o boRecord.o calcRecord.o calcoutRecord.o compressRecord.o dfanoutRecord.o eventRecord.o fanoutRecord.o histogramRecord.o longinRecord.o longoutRecord.o mbbiRecord.o mbbiDirectRecord.o mbboRecord.o mbboDirectRecord.o permissiveRecord.o selRecord.o seqRecord.o stateRecord.o stringinRecord.o stringoutRecord.o subRecord.o subArrayRecord.o waveformRecord.o   -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom  -lpthread   -lreadline -lcurses -lm -lrt -lgcc
Installing shared library ../../../lib/linux-x86/librecIoc.so
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/rec/O.linux-arm'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/rec/O.linux-arm'
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../aaiRecord.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../aaoRecord.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../aiRecord.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../aoRecord.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../biRecord.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../boRecord.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../calcRecord.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../calcoutRecord.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../compressRecord.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dfanoutRecord.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../eventRecord.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../fanoutRecord.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../histogramRecord.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../longinRecord.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../longoutRecord.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../mbbiRecord.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../mbbiDirectRecord.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../mbboRecord.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../mbboDirectRecord.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../permissiveRecord.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../selRecord.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../seqRecord.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../stateRecord.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../stringinRecord.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../stringoutRecord.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../subRecord.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../subArrayRecord.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../waveformRecord.c
/usr/local/armlinux/3.3.3/bin/arm-linux-ar -rc   librecIoc.a       aaiRecord.o aaoRecord.o aiRecord.o aoRecord.o biRecord.o boRecord.o calcRecord.o calcoutRecord.o compressRecord.o dfanoutRecord.o eventRecord.o fanoutRecord.o histogramRecord.o longinRecord.o longoutRecord.o mbbiRecord.o mbbiDirectRecord.o mbboRecord.o mbboDirectRecord.o permissiveRecord.o selRecord.o seqRecord.o stateRecord.o stringinRecord.o stringoutRecord.o subRecord.o subArrayRecord.o waveformRecord.o
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib librecIoc.a
Installing library ../../../lib/linux-arm/librecIoc.a
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib ../../../lib/linux-arm/librecIoc.a
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o librecIoc.so -shared -fPIC -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm         aaiRecord.o aaoRecord.o aiRecord.o aoRecord.o biRecord.o boRecord.o calcRecord.o calcoutRecord.o compressRecord.o dfanoutRecord.o eventRecord.o fanoutRecord.o histogramRecord.o longinRecord.o longoutRecord.o mbbiRecord.o mbbiDirectRecord.o mbboRecord.o mbboDirectRecord.o permissiveRecord.o selRecord.o seqRecord.o stateRecord.o stringinRecord.o stringoutRecord.o subRecord.o subArrayRecord.o waveformRecord.o   -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom  -lpthread    -lm -lrt -lgcc
Installing shared library ../../../lib/linux-arm/librecIoc.so
make[2]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/rec'
make -C dev install
make[2]: Entering directory `/usr/local/epics/base-3.14.8.2/src/dev'
make -C softDev install
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/dev/softDev'
mkdir O.Common
make[4]: Entering directory `/usr/local/epics/base-3.14.8.2/src/dev/softDev/O.linux-x86'
make[4]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/dev/softDev/O.linux-x86'
Installing dbd file ../../../../dbd/devSoft.dbd
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devAiSoft.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devAiSoftRaw.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devAoSoft.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devAoSoftRaw.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devBiSoft.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devBiSoftRaw.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devBoSoft.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devBoSoftRaw.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devCalcoutSoft.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devEventSoft.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devHistogramSoft.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devLiSoft.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devLoSoft.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devMbbiDirectSoft.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devMbbiDirectSoftRaw.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devMbbiSoft.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devMbbiSoftRaw.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devMbboDirectSoft.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devMbboDirectSoftRaw.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devMbboSoft.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devMbboSoftRaw.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devSASoft.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devSiSoft.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devSoSoft.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devWfSoft.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devAoSoftCallback.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devBoSoftCallback.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devCalcoutSoftCallback.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devLoSoftCallback.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devMbboSoftCallback.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devMbboDirectSoftCallback.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devSoSoftCallback.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devTimestampSI.c
/usr/bin/ar -rc   libsoftDevIoc.a       devAiSoft.o devAiSoftRaw.o devAoSoft.o devAoSoftRaw.o devBiSoft.o devBiSoftRaw.o devBoSoft.o devBoSoftRaw.o devCalcoutSoft.o devEventSoft.o devHistogramSoft.o devLiSoft.o devLoSoft.o devMbbiDirectSoft.o devMbbiDirectSoftRaw.o devMbbiSoft.o devMbbiSoftRaw.o devMbboDirectSoft.o devMbboDirectSoftRaw.o devMbboSoft.o devMbboSoftRaw.o devSASoft.o devSiSoft.o devSoSoft.o devWfSoft.o devAoSoftCallback.o devBoSoftCallback.o devCalcoutSoftCallback.o devLoSoftCallback.o devMbboSoftCallback.o devMbboDirectSoftCallback.o devSoSoftCallback.o devTimestampSI.o
/usr/bin/ranlib libsoftDevIoc.a
Installing library ../../../../lib/linux-x86/libsoftDevIoc.a
/usr/bin/ranlib ../../../../lib/linux-x86/libsoftDevIoc.a
/usr/bin/g++ -o libsoftDevIoc.so -shared -fPIC -L../../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86         devAiSoft.o devAiSoftRaw.o devAoSoft.o devAoSoftRaw.o devBiSoft.o devBiSoftRaw.o devBoSoft.o devBoSoftRaw.o devCalcoutSoft.o devEventSoft.o devHistogramSoft.o devLiSoft.o devLoSoft.o devMbbiDirectSoft.o devMbbiDirectSoftRaw.o devMbbiSoft.o devMbbiSoftRaw.o devMbboDirectSoft.o devMbboDirectSoftRaw.o devMbboSoft.o devMbboSoftRaw.o devSASoft.o devSiSoft.o devSoSoft.o devWfSoft.o devAoSoftCallback.o devBoSoftCallback.o devCalcoutSoftCallback.o devLoSoftCallback.o devMbboSoftCallback.o devMbboDirectSoftCallback.o devSoSoftCallback.o devTimestampSI.o   -lrecIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom  -lpthread   -lreadline -lcurses -lm -lrt -lgcc
Installing shared library ../../../../lib/linux-x86/libsoftDevIoc.so
make -C O.linux-arm -f ../Makefile TOP=../../../.. T_A=linux-arm install
make[4]: Entering directory `/usr/local/epics/base-3.14.8.2/src/dev/softDev/O.linux-arm'
make[4]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/dev/softDev/O.linux-arm'
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devAiSoft.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devAiSoftRaw.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devAoSoft.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devAoSoftRaw.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devBiSoft.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devBiSoftRaw.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devBoSoft.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devBoSoftRaw.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devCalcoutSoft.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devEventSoft.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devHistogramSoft.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devLiSoft.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devLoSoft.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devMbbiDirectSoft.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devMbbiDirectSoftRaw.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devMbbiSoft.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devMbbiSoftRaw.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devMbboDirectSoft.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devMbboDirectSoftRaw.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devMbboSoft.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devMbboSoftRaw.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devSASoft.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devSiSoft.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devSoSoft.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devWfSoft.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devAoSoftCallback.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devBoSoftCallback.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devCalcoutSoftCallback.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devLoSoftCallback.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devMbboSoftCallback.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devMbboDirectSoftCallback.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devSoSoftCallback.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devTimestampSI.c
/usr/local/armlinux/3.3.3/bin/arm-linux-ar -rc   libsoftDevIoc.a       devAiSoft.o devAiSoftRaw.o devAoSoft.o devAoSoftRaw.o devBiSoft.o devBiSoftRaw.o devBoSoft.o devBoSoftRaw.o devCalcoutSoft.o devEventSoft.o devHistogramSoft.o devLiSoft.o devLoSoft.o devMbbiDirectSoft.o devMbbiDirectSoftRaw.o devMbbiSoft.o devMbbiSoftRaw.o devMbboDirectSoft.o devMbboDirectSoftRaw.o devMbboSoft.o devMbboSoftRaw.o devSASoft.o devSiSoft.o devSoSoft.o devWfSoft.o devAoSoftCallback.o devBoSoftCallback.o devCalcoutSoftCallback.o devLoSoftCallback.o devMbboSoftCallback.o devMbboDirectSoftCallback.o devSoSoftCallback.o devTimestampSI.o
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib libsoftDevIoc.a
Installing library ../../../../lib/linux-arm/libsoftDevIoc.a
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib ../../../../lib/linux-arm/libsoftDevIoc.a
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o libsoftDevIoc.so -shared -fPIC -L../../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../../lib/linux-arm         devAiSoft.o devAiSoftRaw.o devAoSoft.o devAoSoftRaw.o devBiSoft.o devBiSoftRaw.o devBoSoft.o devBoSoftRaw.o devCalcoutSoft.o devEventSoft.o devHistogramSoft.o devLiSoft.o devLoSoft.o devMbbiDirectSoft.o devMbbiDirectSoftRaw.o devMbbiSoft.o devMbbiSoftRaw.o devMbboDirectSoft.o devMbboDirectSoftRaw.o devMbboSoft.o devMbboSoftRaw.o devSASoft.o devSiSoft.o devSoSoft.o devWfSoft.o devAoSoftCallback.o devBoSoftCallback.o devCalcoutSoftCallback.o devLoSoftCallback.o devMbboSoftCallback.o devMbboDirectSoftCallback.o devSoSoftCallback.o devTimestampSI.o   -lrecIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom  -lpthread    -lm -lrt -lgcc
Installing shared library ../../../../lib/linux-arm/libsoftDevIoc.so
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/dev/softDev'
make -C testDev install
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/dev/testDev'
perl ../../../configure/tools/makeMakefile.pl O.linux-x86 ../../../..
perl ../../../configure/tools/makeMakefile.pl O.linux-arm ../../../..
mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../../../.. T_A=linux-x86 install
make[4]: Entering directory `/usr/local/epics/base-3.14.8.2/src/dev/testDev/O.linux-x86'
make[4]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/dev/testDev/O.linux-x86'
Installing dbd file ../../../../dbd/devTestAsyn.dbd
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devAiTestAsyn.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devAoTestAsyn.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devBiTestAsyn.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devBoTestAsyn.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devEventTestIoEvent.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devHistogramTestAsyn.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devLoTestAsyn.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devMbbiTestAsyn.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devMbboTestAsyn.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devMbboDirectTestAsyn.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devSiTestAsyn.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devSoTestAsyn.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../devWfTestAsyn.c
/usr/bin/ar -rc   libtestDevIoc.a       devAiTestAsyn.o devAoTestAsyn.o devBiTestAsyn.o devBoTestAsyn.o devEventTestIoEvent.o devHistogramTestAsyn.o devLoTestAsyn.o devMbbiTestAsyn.o devMbboTestAsyn.o devMbboDirectTestAsyn.o devSiTestAsyn.o devSoTestAsyn.o devWfTestAsyn.o
/usr/bin/ranlib libtestDevIoc.a
Installing library ../../../../lib/linux-x86/libtestDevIoc.a
/usr/bin/ranlib ../../../../lib/linux-x86/libtestDevIoc.a
/usr/bin/g++ -o libtestDevIoc.so -shared -fPIC -L../../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86         devAiTestAsyn.o devAoTestAsyn.o devBiTestAsyn.o devBoTestAsyn.o devEventTestIoEvent.o devHistogramTestAsyn.o devLoTestAsyn.o devMbbiTestAsyn.o devMbboTestAsyn.o devMbboDirectTestAsyn.o devSiTestAsyn.o devSoTestAsyn.o devWfTestAsyn.o   -lrecIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom  -lpthread   -lreadline -lcurses -lm -lrt -lgcc
Installing shared library ../../../../lib/linux-x86/libtestDevIoc.so
make[4]: Entering directory `/usr/local/epics/base-3.14.8.2/src/dev/testDev/O.linux-arm'
make[4]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/dev/testDev/O.linux-arm'
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devAiTestAsyn.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devAoTestAsyn.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devBiTestAsyn.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devBoTestAsyn.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devEventTestIoEvent.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devHistogramTestAsyn.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devLoTestAsyn.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devMbbiTestAsyn.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devMbboTestAsyn.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devMbboDirectTestAsyn.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devSiTestAsyn.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devSoTestAsyn.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../devWfTestAsyn.c
/usr/local/armlinux/3.3.3/bin/arm-linux-ar -rc   libtestDevIoc.a       devAiTestAsyn.o devAoTestAsyn.o devBiTestAsyn.o devBoTestAsyn.o devEventTestIoEvent.o devHistogramTestAsyn.o devLoTestAsyn.o devMbbiTestAsyn.o devMbboTestAsyn.o devMbboDirectTestAsyn.o devSiTestAsyn.o devSoTestAsyn.o devWfTestAsyn.o
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib libtestDevIoc.a
Installing library ../../../../lib/linux-arm/libtestDevIoc.a
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib ../../../../lib/linux-arm/libtestDevIoc.a
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o libtestDevIoc.so -shared -fPIC -L../../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../../lib/linux-arm         devAiTestAsyn.o devAoTestAsyn.o devBiTestAsyn.o devBoTestAsyn.o devEventTestIoEvent.o devHistogramTestAsyn.o devLoTestAsyn.o devMbbiTestAsyn.o devMbboTestAsyn.o devMbboDirectTestAsyn.o devSiTestAsyn.o devSoTestAsyn.o devWfTestAsyn.o   -lrecIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom  -lpthread    -lm -lrt -lgcc
Installing shared library ../../../../lib/linux-arm/libtestDevIoc.so
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/dev/testDev'
make[2]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/dev'
make -C misc install
make[2]: Entering directory `/usr/local/epics/base-3.14.8.2/src/misc'
perl ../../configure/tools/makeMakefile.pl O.linux-x86 ../../..
perl ../../configure/tools/makeMakefile.pl O.linux-arm ../../..
mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/misc/O.linux-x86'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/misc/O.linux-x86'
Installing dbd file ../../../dbd/base.dbd
Installing generic include file ../../../include/epicsRelease.h
Installing generic include file ../../../include/iocInit.h
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../epicsRelease.c
../epicsRelease.c:21: warning: 'id' defined but not used
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../iocInit.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../asSubRecordFunctions.c
/usr/bin/ar -rc   libmiscIoc.a       epicsRelease.o iocInit.o asSubRecordFunctions.o
/usr/bin/ranlib libmiscIoc.a
Installing library ../../../lib/linux-x86/libmiscIoc.a
/usr/bin/ranlib ../../../lib/linux-x86/libmiscIoc.a
/usr/bin/g++ -o libmiscIoc.so -shared -fPIC -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86         epicsRelease.o iocInit.o asSubRecordFunctions.o   -lrsrvIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom  -lpthread   -lreadline -lcurses -lm -lrt -lgcc
Installing shared library ../../../lib/linux-x86/libmiscIoc.so
make -C O.linux-arm -f ../Makefile TOP=../../.. T_A=linux-arm install
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/misc/O.linux-arm'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/misc/O.linux-arm'
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsRelease.c
../epicsRelease.c:21: warning: `id' defined but not used
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../iocInit.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../asSubRecordFunctions.c
/usr/local/armlinux/3.3.3/bin/arm-linux-ar -rc   libmiscIoc.a       epicsRelease.o iocInit.o asSubRecordFunctions.o
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib libmiscIoc.a
Installing library ../../../lib/linux-arm/libmiscIoc.a
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib ../../../lib/linux-arm/libmiscIoc.a
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o libmiscIoc.so -shared -fPIC -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm         epicsRelease.o iocInit.o asSubRecordFunctions.o   -lrsrvIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom  -lpthread    -lm -lrt -lgcc
Installing shared library ../../../lib/linux-arm/libmiscIoc.so
make[2]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/misc'
make -C iocsh install
make[2]: Entering directory `/usr/local/epics/base-3.14.8.2/src/iocsh'
mkdir O.Common
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/iocsh/O.linux-x86'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/iocsh/O.linux-x86'
Installing generic include file ../../../include/iocsh.h
Installing generic include file ../../../include/osiRegister.h
Installing generic include file ../../../include/iocUtilRegister.h
Installing generic include file ../../../include/dbStaticRegister.h
Installing generic include file ../../../include/dbTestRegister.h
Installing generic include file ../../../include/dbBkptRegister.h
Installing generic include file ../../../include/dbCaTestRegister.h
Installing generic include file ../../../include/caTestRegister.h
Installing generic include file ../../../include/dbAccessRegister.h
Installing generic include file ../../../include/iocshRegisterCommon.h
Installing generic include file ../../../include/asTestRegister.h
Installing generic include file ../../../include/envRegister.h
Installing generic include file ../../../include/iocCoreLimitsRegister.h
Installing generic include file ../../../include/registryCommon.h
Installing generic include file ../../../include/registryRegister.h
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../iocsh.cpp
../iocsh.cpp:898: warning: 'void commentCallFunc(const iocshArgBuf*)' defined but not used
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../osiRegister.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbStaticRegister.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbTestRegister.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbBkptRegister.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbCaTestRegister.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../caTestRegister.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbAccessRegister.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../iocshRegisterCommon.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../asTestRegister.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../envRegister.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../iocUtil.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../iocCoreLimitsRegister.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../systemCommandRegister.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../registryCommon.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../registryRegister.c
/usr/bin/ar -rc   libiocsh.a       iocsh.o osiRegister.o dbStaticRegister.o dbTestRegister.o dbBkptRegister.o dbCaTestRegister.o caTestRegister.o dbAccessRegister.o iocshRegisterCommon.o asTestRegister.o envRegister.o iocUtil.o iocCoreLimitsRegister.o systemCommandRegister.o registryCommon.o registryRegister.o
/usr/bin/ranlib libiocsh.a
Installing library ../../../lib/linux-x86/libiocsh.a
/usr/bin/ranlib ../../../lib/linux-x86/libiocsh.a
/usr/bin/g++ -o libiocsh.so -shared -fPIC -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86         iocsh.o osiRegister.o dbStaticRegister.o dbTestRegister.o dbBkptRegister.o dbCaTestRegister.o caTestRegister.o dbAccessRegister.o iocshRegisterCommon.o asTestRegister.o envRegister.o iocUtil.o iocCoreLimitsRegister.o systemCommandRegister.o registryCommon.o registryRegister.o   -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lCom  -lpthread   -lreadline -lcurses -lm -lrt -lgcc
Installing shared library ../../../lib/linux-x86/libiocsh.so
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/iocsh/O.linux-arm'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/iocsh/O.linux-arm'
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../iocsh.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../osiRegister.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbStaticRegister.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbTestRegister.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbBkptRegister.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbCaTestRegister.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../caTestRegister.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbAccessRegister.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../iocshRegisterCommon.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../asTestRegister.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../envRegister.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../iocUtil.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../iocCoreLimitsRegister.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../systemCommandRegister.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../registryCommon.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../registryRegister.c
/usr/local/armlinux/3.3.3/bin/arm-linux-ar -rc   libiocsh.a       iocsh.o osiRegister.o dbStaticRegister.o dbTestRegister.o dbBkptRegister.o dbCaTestRegister.o caTestRegister.o dbAccessRegister.o iocshRegisterCommon.o asTestRegister.o envRegister.o iocUtil.o iocCoreLimitsRegister.o systemCommandRegister.o registryCommon.o registryRegister.o
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib libiocsh.a
Installing library ../../../lib/linux-arm/libiocsh.a
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib ../../../lib/linux-arm/libiocsh.a
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o libiocsh.so -shared -fPIC -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm         iocsh.o osiRegister.o dbStaticRegister.o dbTestRegister.o dbBkptRegister.o dbCaTestRegister.o caTestRegister.o dbAccessRegister.o iocshRegisterCommon.o asTestRegister.o envRegister.o iocUtil.o iocCoreLimitsRegister.o systemCommandRegister.o registryCommon.o registryRegister.o   -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lCom  -lpthread    -lm -lrt -lgcc
Installing shared library ../../../lib/linux-arm/libiocsh.so
make[2]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/iocsh'
make -C vxWorks install
make[2]: Entering directory `/usr/local/epics/base-3.14.8.2/src/vxWorks'
mkdir O.Common
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/vxWorks/O.linux-x86'
make[3]: Nothing to be done for `install'.
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/vxWorks/O.linux-x86'
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/vxWorks/O.linux-arm'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/vxWorks/O.linux-arm'
make[2]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/vxWorks'
make -C RTEMS install
make[2]: Entering directory `/usr/local/epics/base-3.14.8.2/src/RTEMS'
make -C base install
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/RTEMS/base'
mkdir O.Common
make[4]: Entering directory `/usr/local/epics/base-3.14.8.2/src/RTEMS/base/O.linux-x86'
make[4]: Nothing to be done for `install'.
make[4]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/RTEMS/base/O.linux-x86'
make[4]: Entering directory `/usr/local/epics/base-3.14.8.2/src/RTEMS/base/O.linux-arm'
make[4]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/RTEMS/base/O.linux-arm'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/RTEMS/base'
make[2]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/RTEMS'
make -C softIoc install
make[2]: Entering directory `/usr/local/epics/base-3.14.8.2/src/softIoc'
mkdir O.Common
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/softIoc/O.linux-x86'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/softIoc/O.linux-x86'
perl ../../../configure/tools/makeIncludeDbd.pl base.dbd ../O.Common/softIocInclude.dbd
Expanding dbd
/usr/local/epics/base-3.14.8.2/bin/linux-x86/dbExpand  -I . -I .. -I ../../../dbd  -o ../O.Common/softIoc.dbd ../O.Common/softIocInclude.dbd
Installing dbd file ../../../dbd/softIoc.dbd
perl /usr/local/epics/base-3.14.8.2/bin/linux-x86/registerRecordDeviceDriver.pl ../O.Common/softIoc.dbd softIoc_registerRecordDeviceDriver > temp.cpp
mv temp.cpp softIoc_registerRecordDeviceDriver.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall     -DEPICS_BASE=/usr/local/epics/base-3.14.8.2      -g  -I. -I.. -I../../../include/os/Linux -I../../../include         softIoc_registerRecordDeviceDriver.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall     -DEPICS_BASE=/usr/local/epics/base-3.14.8.2      -g  -I. -I.. -I../../../include/os/Linux -I../../../include         ../softMain.cpp
/usr/bin/g++ -o softIoc  -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        softIoc_registerRecordDeviceDriver.o softMain.o    -lrecIoc -lsoftDevIoc -liocsh -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom
Installing binary ../../../bin/linux-x86/softIoc
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/softIoc/O.linux-arm'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/softIoc/O.linux-arm'
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall     -DEPICS_BASE=/usr/local/epics/base-3.14.8.2       -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  softIoc_registerRecordDeviceDriver.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall     -DEPICS_BASE=/usr/local/epics/base-3.14.8.2       -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../softMain.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o softIoc  -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm        softIoc_registerRecordDeviceDriver.o softMain.o    -lrecIoc -lsoftDevIoc -liocsh -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom
Installing binary ../../../bin/linux-arm/softIoc
make[2]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/softIoc'
make -C libCom/test install
make[2]: Entering directory `/usr/local/epics/base-3.14.8.2/src/libCom/test'
mkdir O.Common
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/libCom/test/O.linux-x86'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/libCom/test/O.linux-x86'
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsAlgorithmTest.cpp
/usr/bin/g++ -o epicsAlgorithmTest  -L../../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        epicsAlgorithmTest.o    -lCom
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsMathTestMain.cpp
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsMathTest.c
/usr/bin/g++ -o epicsMathTestHost  -L../../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        epicsMathTestMain.o epicsMathTest.o    -lCom
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsStdioTestMain.cpp
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsStdioTest.c
/usr/bin/g++ -o epicsStdioTestHost  -L../../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        epicsStdioTestMain.o epicsStdioTest.o    -lCom
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsStringTestMain.cpp
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsStringTest.c
/usr/bin/g++ -o epicsStringTestHost  -L../../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        epicsStringTestMain.o epicsStringTest.o    -lCom
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsTimeTestMain.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsTimeTest.cpp
/usr/bin/g++ -o epicsTimeTestHost  -L../../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        epicsTimeTestMain.o epicsTimeTest.o    -lCom
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsThreadTestMain.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsThreadTest.cpp
/usr/bin/g++ -o epicsThreadTestHost  -L../../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        epicsThreadTestMain.o epicsThreadTest.o    -lCom
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsThreadPriorityTestMain.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsThreadPriorityTest.cpp
/usr/bin/g++ -o epicsThreadPriorityTestHost  -L../../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        epicsThreadPriorityTestMain.o epicsThreadPriorityTest.o    -lCom
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsThreadPrivateTestMain.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsThreadPrivateTest.cpp
/usr/bin/g++ -o epicsThreadPrivateTestHost  -L../../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        epicsThreadPrivateTestMain.o epicsThreadPrivateTest.o    -lCom
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsMaxThreadsMain.cpp
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsMaxThreads.c
/usr/bin/g++ -o epicsMaxThreadsHost  -L../../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        epicsMaxThreadsMain.o epicsMaxThreads.o    -lCom
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsOkToBlockTestMain.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsOkToBlockTest.cpp
/usr/bin/g++ -o epicsOkToBlockTestHost  -L../../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        epicsOkToBlockTestMain.o epicsOkToBlockTest.o    -lCom
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsExitTestMain.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsExitTest.c
/usr/bin/g++ -o epicsExitTestHost  -L../../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        epicsExitTestMain.o epicsExitTest.o    -lCom
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsTimerTestMain.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsTimerTest.cpp
/usr/bin/g++ -o epicsTimerTestHost  -L../../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        epicsTimerTestMain.o epicsTimerTest.o    -lCom
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsTimerExampleMain.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsTimerExample.cpp
/usr/bin/g++ -o epicsTimerExampleHost  -L../../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        epicsTimerExampleMain.o epicsTimerExample.o    -lCom
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../ringPointerTestMain.cpp
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../ringPointerTest.c
/usr/bin/g++ -o ringPointerTestHost  -L../../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        ringPointerTestMain.o ringPointerTest.o    -lCom
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsEventTestMain.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsEventTest.cpp
/usr/bin/g++ -o epicsEventTestHost  -L../../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        epicsEventTestMain.o epicsEventTest.o    -lCom
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsMutexTestMain.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsMutexTest.cpp
/usr/bin/g++ -o epicsMutexTestHost  -L../../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        epicsMutexTestMain.o epicsMutexTest.o    -lCom
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsExceptionTestMain.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsExceptionTest.cpp
/usr/bin/g++ -o epicsExceptionTestHost  -L../../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        epicsExceptionTestMain.o epicsExceptionTest.o    -lCom
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsMessageQueueTestMain.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../epicsMessageQueueTest.cpp
/usr/bin/g++ -o epicsMessageQueueTestHost  -L../../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        epicsMessageQueueTestMain.o epicsMessageQueueTest.o    -lCom
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../macEnvExpandTestMain.cpp
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../macEnvExpandTest.c
/usr/bin/g++ -o macEnvExpandTestHost  -L../../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        macEnvExpandTestMain.o macEnvExpandTest.o    -lCom
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../blockingSockTestMain.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../include/os/Linux -I../../../../include         ../blockingSockTest.cpp
../blockingSockTest.cpp:16: warning: 'class circuit' has virtual functions but non-virtual destructor
../blockingSockTest.cpp:33: warning: 'class serverCircuit' has virtual functions but non-virtual destructor
../blockingSockTest.cpp:40: warning: 'class clientCircuit' has virtual functions but non-virtual destructor
/usr/bin/g++ -o blockingSockTestHost  -L../../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        blockingSockTestMain.o blockingSockTest.o    -lCom
Installing binary ../../../../bin/linux-x86/epicsAlgorithmTest
Installing binary ../../../../bin/linux-x86/epicsMathTestHost
Installing binary ../../../../bin/linux-x86/epicsStdioTestHost
Installing binary ../../../../bin/linux-x86/epicsStringTestHost
Installing binary ../../../../bin/linux-x86/epicsTimeTestHost
Installing binary ../../../../bin/linux-x86/epicsThreadTestHost
Installing binary ../../../../bin/linux-x86/epicsThreadPriorityTestHost
Installing binary ../../../../bin/linux-x86/epicsThreadPrivateTestHost
Installing binary ../../../../bin/linux-x86/epicsMaxThreadsHost
Installing binary ../../../../bin/linux-x86/epicsOkToBlockTestHost
Installing binary ../../../../bin/linux-x86/epicsExitTestHost
Installing binary ../../../../bin/linux-x86/epicsTimerTestHost
Installing binary ../../../../bin/linux-x86/epicsTimerExampleHost
Installing binary ../../../../bin/linux-x86/ringPointerTestHost
Installing binary ../../../../bin/linux-x86/epicsEventTestHost
Installing binary ../../../../bin/linux-x86/epicsMutexTestHost
Installing binary ../../../../bin/linux-x86/epicsExceptionTestHost
Installing binary ../../../../bin/linux-x86/epicsMessageQueueTestHost
Installing binary ../../../../bin/linux-x86/macEnvExpandTestHost
Installing binary ../../../../bin/linux-x86/blockingSockTestHost
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/libCom/test/O.linux-arm'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/libCom/test/O.linux-arm'
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsAlgorithmTest.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o epicsAlgorithmTest  -L../../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../../lib/linux-arm        epicsAlgorithmTest.o    -lCom
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsMathTestMain.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsMathTest.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o epicsMathTestHost  -L../../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../../lib/linux-arm        epicsMathTestMain.o epicsMathTest.o    -lCom
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsStdioTestMain.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsStdioTest.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o epicsStdioTestHost  -L../../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../../lib/linux-arm        epicsStdioTestMain.o epicsStdioTest.o    -lCom
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsStringTestMain.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsStringTest.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o epicsStringTestHost  -L../../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../../lib/linux-arm        epicsStringTestMain.o epicsStringTest.o    -lCom
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsTimeTestMain.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsTimeTest.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o epicsTimeTestHost  -L../../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../../lib/linux-arm        epicsTimeTestMain.o epicsTimeTest.o    -lCom
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsThreadTestMain.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsThreadTest.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o epicsThreadTestHost  -L../../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../../lib/linux-arm        epicsThreadTestMain.o epicsThreadTest.o    -lCom
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsThreadPriorityTestMain.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsThreadPriorityTest.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o epicsThreadPriorityTestHost  -L../../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../../lib/linux-arm        epicsThreadPriorityTestMain.o epicsThreadPriorityTest.o    -lCom
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsThreadPrivateTestMain.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsThreadPrivateTest.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o epicsThreadPrivateTestHost  -L../../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../../lib/linux-arm        epicsThreadPrivateTestMain.o epicsThreadPrivateTest.o    -lCom
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsMaxThreadsMain.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsMaxThreads.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o epicsMaxThreadsHost  -L../../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../../lib/linux-arm        epicsMaxThreadsMain.o epicsMaxThreads.o    -lCom
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsOkToBlockTestMain.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsOkToBlockTest.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o epicsOkToBlockTestHost  -L../../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../../lib/linux-arm        epicsOkToBlockTestMain.o epicsOkToBlockTest.o    -lCom
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsExitTestMain.c
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsExitTest.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o epicsExitTestHost  -L../../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../../lib/linux-arm        epicsExitTestMain.o epicsExitTest.o    -lCom
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsTimerTestMain.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsTimerTest.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o epicsTimerTestHost  -L../../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../../lib/linux-arm        epicsTimerTestMain.o epicsTimerTest.o    -lCom
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsTimerExampleMain.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsTimerExample.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o epicsTimerExampleHost  -L../../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../../lib/linux-arm        epicsTimerExampleMain.o epicsTimerExample.o    -lCom
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../ringPointerTestMain.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../ringPointerTest.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o ringPointerTestHost  -L../../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../../lib/linux-arm        ringPointerTestMain.o ringPointerTest.o    -lCom
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsEventTestMain.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsEventTest.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o epicsEventTestHost  -L../../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../../lib/linux-arm        epicsEventTestMain.o epicsEventTest.o    -lCom
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsMutexTestMain.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsMutexTest.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o epicsMutexTestHost  -L../../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../../lib/linux-arm        epicsMutexTestMain.o epicsMutexTest.o    -lCom
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsExceptionTestMain.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsExceptionTest.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o epicsExceptionTestHost  -L../../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../../lib/linux-arm        epicsExceptionTestMain.o epicsExceptionTest.o    -lCom
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsMessageQueueTestMain.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../epicsMessageQueueTest.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o epicsMessageQueueTestHost  -L../../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../../lib/linux-arm        epicsMessageQueueTestMain.o epicsMessageQueueTest.o    -lCom
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../macEnvExpandTestMain.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../macEnvExpandTest.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o macEnvExpandTestHost  -L../../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../../lib/linux-arm        macEnvExpandTestMain.o macEnvExpandTest.o    -lCom
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../blockingSockTestMain.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../blockingSockTest.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o blockingSockTestHost  -L../../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../../lib/linux-arm        blockingSockTestMain.o blockingSockTest.o    -lCom
Installing binary ../../../../bin/linux-arm/epicsAlgorithmTest
Installing binary ../../../../bin/linux-arm/epicsMathTestHost
Installing binary ../../../../bin/linux-arm/epicsStdioTestHost
Installing binary ../../../../bin/linux-arm/epicsStringTestHost
Installing binary ../../../../bin/linux-arm/epicsTimeTestHost
Installing binary ../../../../bin/linux-arm/epicsThreadTestHost
Installing binary ../../../../bin/linux-arm/epicsThreadPriorityTestHost
Installing binary ../../../../bin/linux-arm/epicsThreadPrivateTestHost
Installing binary ../../../../bin/linux-arm/epicsMaxThreadsHost
Installing binary ../../../../bin/linux-arm/epicsOkToBlockTestHost
Installing binary ../../../../bin/linux-arm/epicsExitTestHost
Installing binary ../../../../bin/linux-arm/epicsTimerTestHost
Installing binary ../../../../bin/linux-arm/epicsTimerExampleHost
Installing binary ../../../../bin/linux-arm/ringPointerTestHost
Installing binary ../../../../bin/linux-arm/epicsEventTestHost
Installing binary ../../../../bin/linux-arm/epicsMutexTestHost
Installing binary ../../../../bin/linux-arm/epicsExceptionTestHost
Installing binary ../../../../bin/linux-arm/epicsMessageQueueTestHost
Installing binary ../../../../bin/linux-arm/macEnvExpandTestHost
Installing binary ../../../../bin/linux-arm/blockingSockTestHost
make[2]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/libCom/test'
make -C gdd install
make[2]: Entering directory `/usr/local/epics/base-3.14.8.2/src/gdd'
mkdir O.Common
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/gdd/O.linux-x86'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/gdd/O.linux-x86'
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../include/os/Linux -I../../../include         ../genApps.cc
../gddUtils.h:85: warning: 'class gddDestructor' has virtual functions but non-virtual destructor
../gddAppTable.h:65: warning: 'class gddApplicationTypeDestructor' has virtual functions but non-virtual destructor
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../gdd.cc
../gdd.cc:35: warning: 'class gddFlattenDestructor' has virtual functions but non-virtual destructor
../gdd.cc:43: warning: 'class gddContainerCleaner' has virtual functions but non-virtual destructor
../gdd.cc:66: warning: 'class gddAitUint8Destructor' has virtual functions but non-virtual destructor
../gdd.cc:73: warning: 'class gddAitStringDestructor' has virtual functions but non-virtual destructor
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../gddTest.cc
../gddTest.cc:320: warning: 'class gddAtomicDestr' has virtual functions but non-virtual destructor
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../gddAppTable.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../gddNewDel.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../gddAppDefs.cc
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../aitTypes.c
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../include/os/Linux -I../../../include         ../aitGen.c
/usr/bin/g++ -o aitGen  -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        aitTypes.o aitGen.o    -lCom
Installing binary ../../../bin/linux-x86/aitGen
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../aitConvert.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../aitHelpers.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../gddArray.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../gddContainer.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../gddErrorCodes.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../gddUtils.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../gddEnumStringTable.cc
/usr/bin/g++ -o genApps  -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        genApps.o gdd.o gddTest.o gddAppTable.o gddNewDel.o gddAppDefs.o aitTypes.o aitConvert.o aitHelpers.o gddArray.o gddContainer.o gddErrorCodes.o gddUtils.o gddEnumStringTable.o    -lCom
Installing binary ../../../bin/linux-x86/genApps
../../../bin/linux-x86/genApps ../O.Common/gddApps.h
Installing generic include file ../../../include/gdd.h
Installing generic include file ../../../include/gddI.h
Installing generic include file ../../../include/gddContainer.h
Installing generic include file ../../../include/gddContainerI.h
Installing generic include file ../../../include/gddArray.h
Installing generic include file ../../../include/gddArrayI.h
Installing generic include file ../../../include/gddScalar.h
Installing generic include file ../../../include/gddScalarI.h
Installing generic include file ../../../include/gddSemaphore.h
Installing generic include file ../../../include/gddNewDel.h
Installing generic include file ../../../include/gddUtils.h
Installing generic include file ../../../include/gddUtilsI.h
Installing generic include file ../../../include/gddErrorCodes.h
Installing generic include file ../../../include/aitTypes.h
Installing generic include file ../../../include/aitConvert.h
Installing generic include file ../../../include/aitHelpers.h
Installing generic include file ../../../include/dbMapper.h
Installing generic include file ../../../include/gddAppTable.h
Installing generic include file ../../../include/gddAppFuncTable.h
Installing generic include file ../../../include/smartGDDPointer.h
Installing generated generic include file ../../../include/gddApps.h
Installing generic include file ../../../include/gddEnumStringTable.h
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include         ../dbMapper.cc
../dbMapper.cc:116: warning: 'class dbMapperFixedStringDestructor' has virtual functions but non-virtual destructor
/usr/bin/ar -rc   libgdd.a      gdd.o gddTest.o gddAppTable.o gddNewDel.o gddAppDefs.o aitTypes.o aitConvert.o aitHelpers.o dbMapper.o gddArray.o gddContainer.o gddErrorCodes.o gddUtils.o gddEnumStringTable.o
/usr/bin/ranlib libgdd.a
Installing library ../../../lib/linux-x86/libgdd.a
/usr/bin/ranlib ../../../lib/linux-x86/libgdd.a
/usr/bin/g++ -o libgdd.so -shared -fPIC -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        gdd.o gddTest.o gddAppTable.o gddNewDel.o gddAppDefs.o aitTypes.o aitConvert.o aitHelpers.o dbMapper.o gddArray.o gddContainer.o gddErrorCodes.o gddUtils.o gddEnumStringTable.o    -lCom  -lpthread   -lreadline -lcurses -lm -lrt -lgcc
Installing shared library ../../../lib/linux-x86/libgdd.so
Installing html ../../../html//gdd.html
Installing html ../../../html//gddref.html
Installing html ../../../html//gddref2.html
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/gdd/O.linux-arm'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/gdd/O.linux-arm'
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../gdd.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../gddTest.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../gddAppTable.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../gddNewDel.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../gddAppDefs.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../aitTypes.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../aitConvert.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../aitHelpers.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../dbMapper.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../gddArray.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../gddContainer.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../gddErrorCodes.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../gddUtils.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../gddEnumStringTable.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-ar -rc   libgdd.a      gdd.o gddTest.o gddAppTable.o gddNewDel.o gddAppDefs.o aitTypes.o aitConvert.o aitHelpers.o dbMapper.o gddArray.o gddContainer.o gddErrorCodes.o gddUtils.o gddEnumStringTable.o
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib libgdd.a
Installing library ../../../lib/linux-arm/libgdd.a
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib ../../../lib/linux-arm/libgdd.a
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o libgdd.so -shared -fPIC -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm        gdd.o gddTest.o gddAppTable.o gddNewDel.o gddAppDefs.o aitTypes.o aitConvert.o aitHelpers.o dbMapper.o gddArray.o gddContainer.o gddErrorCodes.o gddUtils.o gddEnumStringTable.o    -lCom  -lpthread    -lm -lrt -lgcc
Installing shared library ../../../lib/linux-arm/libgdd.so
/usr/local/armlinux/3.3.3/bin/arm-linux-gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../aitGen.c
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o aitGen  -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm        aitTypes.o aitGen.o    -lCom
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../genApps.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o genApps  -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm        genApps.o gdd.o gddTest.o gddAppTable.o gddNewDel.o gddAppDefs.o aitTypes.o aitConvert.o aitHelpers.o gddArray.o gddContainer.o gddErrorCodes.o gddUtils.o gddEnumStringTable.o    -lCom
Installing binary ../../../bin/linux-arm/aitGen
Installing binary ../../../bin/linux-arm/genApps
make[2]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/gdd'
make -C cas install
make[2]: Entering directory `/usr/local/epics/base-3.14.8.2/src/cas'
make -C build install
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/cas/build'
perl ../../../configure/tools/makeMakefile.pl O.linux-x86 ../../../..
perl ../../../configure/tools/makeMakefile.pl O.linux-arm ../../../..
mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../../../.. T_A=linux-x86 install
make[4]: Entering directory `/usr/local/epics/base-3.14.8.2/src/cas/build/O.linux-x86'
make[4]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/cas/build/O.linux-x86'
Installing generic include file ../../../../include/casdef.h
Installing generic include file ../../../../include/casEventMask.h
Installing generic include file ../../../../include/caNetAddr.h
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/caServer.cc
../../../../include/gddUtils.h:85: warning: 'class gddDestructor' has virtual functions but non-virtual destructor
../../../../include/gddAppTable.h:65: warning: 'class gddApplicationTypeDestructor' has virtual functions but non-virtual destructor
../../../../include/fdManager.h:39: warning: 'class fdRegId' has virtual functions but non-virtual destructor
../../../../src/cas/generic/casMonitor.h:42: warning: 'class casMonitorCallbackInterface' has virtual functions but non-virtual destructor
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/caServerI.cc
../../../../src/cas/generic/inBuf.h:47: warning: 'class inBufClient' has virtual functions but non-virtual destructor
../../../../src/cas/generic/outBuf.h:48: warning: 'class outBufClient' has virtual functions but non-virtual destructor
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/casCoreClient.cc
../../../../src/cas/generic/chanIntfForPV.h:44: warning: 'class casChannelDestroyFromPV' has virtual functions but non-virtual destructor
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/casDGClient.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/casStrmClient.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/casPV.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/casPVI.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/casChannel.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/casChannelI.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/casAsyncIOI.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/casAsyncReadIO.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/casAsyncReadIOI.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/casAsyncWriteIO.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/casAsyncWriteIOI.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/casAsyncPVExistIO.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/casAsyncPVExistIOI.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/casAsyncPVAttachIO.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/casAsyncPVAttachIOI.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/casEventSys.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/casMonitor.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/casMonEvent.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/inBuf.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/outBuf.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/casCtx.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/casEventMask.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/st/ioBlocked.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/casBufferFactory.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/pvExistReturn.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/pvAttachReturn.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/caNetAddr.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/beaconTimer.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/beaconAnomalyGovernor.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/clientBufMemoryManager.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/chanIntfForPV.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/channelDestroyEvent.cpp
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/st/casIntfOS.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/st/casDGIntfOS.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/generic/st/casStreamOS.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/io/bsdSocket/caServerIO.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/io/bsdSocket/casIntfIO.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/io/bsdSocket/casDGIntfIO.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/io/bsdSocket/casStreamIO.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include         ../../../../src/cas/io/bsdSocket/ipIgnoreEntry.cpp
/usr/bin/ar -rc   libcas.a       caServer.o caServerI.o casCoreClient.o casDGClient.o casStrmClient.o casPV.o casPVI.o casChannel.o casChannelI.o casAsyncIOI.o casAsyncReadIO.o casAsyncReadIOI.o casAsyncWriteIO.o casAsyncWriteIOI.o casAsyncPVExistIO.o casAsyncPVExistIOI.o casAsyncPVAttachIO.o casAsyncPVAttachIOI.o casEventSys.o casMonitor.o casMonEvent.o inBuf.o outBuf.o casCtx.o casEventMask.o ioBlocked.o casBufferFactory.o pvExistReturn.o pvAttachReturn.o caNetAddr.o beaconTimer.o beaconAnomalyGovernor.o clientBufMemoryManager.o chanIntfForPV.o channelDestroyEvent.o casIntfOS.o casDGIntfOS.o casStreamOS.o caServerIO.o casIntfIO.o casDGIntfIO.o casStreamIO.o ipIgnoreEntry.o
/usr/bin/ranlib libcas.a
Installing library ../../../../lib/linux-x86/libcas.a
/usr/bin/ranlib ../../../../lib/linux-x86/libcas.a
/usr/bin/g++ -o libcas.so -shared -fPIC -L../../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86         caServer.o caServerI.o casCoreClient.o casDGClient.o casStrmClient.o casPV.o casPVI.o casChannel.o casChannelI.o casAsyncIOI.o casAsyncReadIO.o casAsyncReadIOI.o casAsyncWriteIO.o casAsyncWriteIOI.o casAsyncPVExistIO.o casAsyncPVExistIOI.o casAsyncPVAttachIO.o casAsyncPVAttachIOI.o casEventSys.o casMonitor.o casMonEvent.o inBuf.o outBuf.o casCtx.o casEventMask.o ioBlocked.o casBufferFactory.o pvExistReturn.o pvAttachReturn.o caNetAddr.o beaconTimer.o beaconAnomalyGovernor.o clientBufMemoryManager.o chanIntfForPV.o channelDestroyEvent.o casIntfOS.o casDGIntfOS.o casStreamOS.o caServerIO.o casIntfIO.o casDGIntfIO.o casStreamIO.o ipIgnoreEntry.o   -lca -lgdd -lCom  -lpthread   -lreadline -lcurses -lm -lrt -lgcc
Installing shared library ../../../../lib/linux-x86/libcas.so
make -C O.linux-arm -f ../Makefile TOP=../../../.. T_A=linux-arm install
make[4]: Entering directory `/usr/local/epics/base-3.14.8.2/src/cas/build/O.linux-arm'
make[4]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/cas/build/O.linux-arm'
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/caServer.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/caServerI.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/casCoreClient.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/casDGClient.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/casStrmClient.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/casPV.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/casPVI.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/casChannel.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/casChannelI.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/casAsyncIOI.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/casAsyncReadIO.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/casAsyncReadIOI.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/casAsyncWriteIO.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/casAsyncWriteIOI.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/casAsyncPVExistIO.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/casAsyncPVExistIOI.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/casAsyncPVAttachIO.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/casAsyncPVAttachIOI.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/casEventSys.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/casMonitor.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/casMonEvent.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/inBuf.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/outBuf.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/casCtx.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/casEventMask.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/st/ioBlocked.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/casBufferFactory.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/pvExistReturn.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/pvAttachReturn.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/caNetAddr.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/beaconTimer.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/beaconAnomalyGovernor.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/clientBufMemoryManager.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/chanIntfForPV.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/channelDestroyEvent.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/st/casIntfOS.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/st/casDGIntfOS.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/generic/st/casStreamOS.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/io/bsdSocket/caServerIO.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/io/bsdSocket/casIntfIO.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/io/bsdSocket/casDGIntfIO.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/io/bsdSocket/casStreamIO.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -fPIC -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/Linux -I../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../../src/cas/io/bsdSocket/ipIgnoreEntry.cpp
/usr/local/armlinux/3.3.3/bin/arm-linux-ar -rc   libcas.a       caServer.o caServerI.o casCoreClient.o casDGClient.o casStrmClient.o casPV.o casPVI.o casChannel.o casChannelI.o casAsyncIOI.o casAsyncReadIO.o casAsyncReadIOI.o casAsyncWriteIO.o casAsyncWriteIOI.o casAsyncPVExistIO.o casAsyncPVExistIOI.o casAsyncPVAttachIO.o casAsyncPVAttachIOI.o casEventSys.o casMonitor.o casMonEvent.o inBuf.o outBuf.o casCtx.o casEventMask.o ioBlocked.o casBufferFactory.o pvExistReturn.o pvAttachReturn.o caNetAddr.o beaconTimer.o beaconAnomalyGovernor.o clientBufMemoryManager.o chanIntfForPV.o channelDestroyEvent.o casIntfOS.o casDGIntfOS.o casStreamOS.o caServerIO.o casIntfIO.o casDGIntfIO.o casStreamIO.o ipIgnoreEntry.o
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib libcas.a
Installing library ../../../../lib/linux-arm/libcas.a
/usr/local/armlinux/3.3.3/bin/arm-linux-ranlib ../../../../lib/linux-arm/libcas.a
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o libcas.so -shared -fPIC -L../../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../../lib/linux-arm         caServer.o caServerI.o casCoreClient.o casDGClient.o casStrmClient.o casPV.o casPVI.o casChannel.o casChannelI.o casAsyncIOI.o casAsyncReadIO.o casAsyncReadIOI.o casAsyncWriteIO.o casAsyncWriteIOI.o casAsyncPVExistIO.o casAsyncPVExistIOI.o casAsyncPVAttachIO.o casAsyncPVAttachIOI.o casEventSys.o casMonitor.o casMonEvent.o inBuf.o outBuf.o casCtx.o casEventMask.o ioBlocked.o casBufferFactory.o pvExistReturn.o pvAttachReturn.o caNetAddr.o beaconTimer.o beaconAnomalyGovernor.o clientBufMemoryManager.o chanIntfForPV.o channelDestroyEvent.o casIntfOS.o casDGIntfOS.o casStreamOS.o caServerIO.o casIntfIO.o casDGIntfIO.o casStreamIO.o ipIgnoreEntry.o   -lca -lgdd -lCom  -lpthread    -lm -lrt -lgcc
Installing shared library ../../../../lib/linux-arm/libcas.so
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/cas/build'
make -C example install
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/cas/example'
make -C directoryService install
make[4]: Entering directory `/usr/local/epics/base-3.14.8.2/src/cas/example/directoryService'
perl ../../../../configure/tools/makeMakefile.pl O.linux-x86 ../../../../..
perl ../../../../configure/tools/makeMakefile.pl O.linux-arm ../../../../..
mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../../../../.. T_A=linux-x86 install
make[5]: Entering directory `/usr/local/epics/base-3.14.8.2/src/cas/example/directoryService/O.linux-x86'
make[5]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/cas/example/directoryService/O.linux-x86'
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../../include/os/Linux -I../../../../../include         ../main.cc
../../../../../include/gddUtils.h:85: warning: 'class gddDestructor' has virtual functions but non-virtual destructor
../../../../../include/fdManager.h:39: warning: 'class fdRegId' has virtual functions but non-virtual destructor
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../../../include/os/Linux -I../../../../../include         ../directoryServer.cc
/usr/bin/g++ -o caDirServ  -L../../../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86         main.o directoryServer.o   -lcas -lca -lgdd -lCom
Installing binary ../../../../../bin/linux-x86/caDirServ
make -C O.linux-arm -f ../Makefile TOP=../../../../.. T_A=linux-arm install
make[5]: Entering directory `/usr/local/epics/base-3.14.8.2/src/cas/example/directoryService/O.linux-arm'
make[5]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/cas/example/directoryService/O.linux-arm'
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../../include/os/Linux -I../../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../main.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../../../include/os/Linux -I../../../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../directoryServer.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o caDirServ  -L../../../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../../../lib/linux-arm         main.o directoryServer.o   -lcas -lca -lgdd -lCom
Installing binary ../../../../../bin/linux-arm/caDirServ
make[4]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/cas/example/directoryService'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/cas/example'
make[2]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/cas'
make -C excas install
make[2]: Entering directory `/usr/local/epics/base-3.14.8.2/src/excas'
perl ../../configure/tools/makeMakefile.pl O.linux-x86 ../../..
perl ../../configure/tools/makeMakefile.pl O.linux-arm ../../..
mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/excas/O.linux-x86'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/excas/O.linux-x86'
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../templates/makeBaseApp/top/caServerApp -I../../../include/os/Linux -I../../../include         ../../../templates/makeBaseApp/top/caServerApp/main.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../templates/makeBaseApp/top/caServerApp -I../../../include/os/Linux -I../../../include         ../../../templates/makeBaseApp/top/caServerApp/exServer.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../templates/makeBaseApp/top/caServerApp -I../../../include/os/Linux -I../../../include         ../../../templates/makeBaseApp/top/caServerApp/exPV.cc
../../../templates/makeBaseApp/top/caServerApp/exPV.cc:26: warning: 'class exFixedStringDestructor' has virtual functions but non-virtual destructor
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../templates/makeBaseApp/top/caServerApp -I../../../include/os/Linux -I../../../include         ../../../templates/makeBaseApp/top/caServerApp/exVectorPV.cc
../../../templates/makeBaseApp/top/caServerApp/exVectorPV.cc:33: warning: 'class exVecDestructor' has virtual functions but non-virtual destructor
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../templates/makeBaseApp/top/caServerApp -I../../../include/os/Linux -I../../../include         ../../../templates/makeBaseApp/top/caServerApp/exScalarPV.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../templates/makeBaseApp/top/caServerApp -I../../../include/os/Linux -I../../../include         ../../../templates/makeBaseApp/top/caServerApp/exAsyncPV.cc
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall          -g  -I. -I.. -I../../../templates/makeBaseApp/top/caServerApp -I../../../include/os/Linux -I../../../include         ../../../templates/makeBaseApp/top/caServerApp/exChannel.cc
/usr/bin/g++ -o excas  -L../../../lib/linux-x86/         -Wl,-rpath,/usr/local/epics/base-3.14.8.2/lib/linux-x86        main.o exServer.o exPV.o exVectorPV.o exScalarPV.o exAsyncPV.o exChannel.o    -lcas -lgdd -liocsh -lasHost -ldbStaticHost -lregistryIoc -lca -lCom
Installing binary ../../../bin/linux-x86/excas
make -C O.linux-arm -f ../Makefile TOP=../../.. T_A=linux-arm install
make[3]: Entering directory `/usr/local/epics/base-3.14.8.2/src/excas/O.linux-arm'
make[3]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/excas/O.linux-arm'
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../templates/makeBaseApp/top/caServerApp -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../templates/makeBaseApp/top/caServerApp/main.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../templates/makeBaseApp/top/caServerApp -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../templates/makeBaseApp/top/caServerApp/exServer.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../templates/makeBaseApp/top/caServerApp -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../templates/makeBaseApp/top/caServerApp/exPV.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../templates/makeBaseApp/top/caServerApp -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../templates/makeBaseApp/top/caServerApp/exVectorPV.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../templates/makeBaseApp/top/caServerApp -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../templates/makeBaseApp/top/caServerApp/exScalarPV.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../templates/makeBaseApp/top/caServerApp -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../templates/makeBaseApp/top/caServerApp/exAsyncPV.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500        -D_ARM_NWFP_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I.. -I../../../templates/makeBaseApp/top/caServerApp -I../../../include/os/Linux -I../../../include       -I/usr/local/armlinux/3.3.3/arm-linux/include  ../../../templates/makeBaseApp/top/caServerApp/exChannel.cc
/usr/local/armlinux/3.3.3/bin/arm-linux-g++ -o excas  -L../../../lib/linux-arm/        -L/usr/local/armlinux/3.3.3/arm-linux/lib -Wl,-rpath-link,../../../lib/linux-arm        main.o exServer.o exPV.o exVectorPV.o exScalarPV.o exAsyncPV.o exChannel.o    -lcas -lgdd -liocsh -lasHost -ldbStaticHost -lregistryIoc -lca -lCom
Installing binary ../../../bin/linux-arm/excas
make[2]: Leaving directory `/usr/local/epics/base-3.14.8.2/src/excas'
make[1]: Leaving directory `/usr/local/epics/base-3.14.8.2/src'
Error while cross-compiling EPICS for arm éæç
Re: Error while cross-compiling EPICS for arm Andrew Johnson
Prev: RE: Building and testing Libera EPICS éæç
Next: RE: Error while cross-compiling EPICS for arm Yingbing YAN
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Error while cross-compiling EPICS for arm Andrew Johnson
Next: RE: Error while cross-compiling EPICS for arm Mark Rivers
