Yan Yingbing wrote:
I am sure the EPICS libraries are on my path. I have set the environment
variables LD_LIBRARY_PATH and PATH from the very start.
export LD_LIBRARY_PATH="$LD_LIBRARY_PATH:$EPICS_BASE/lib"
export PATH="$PATH:$EPICS_BASE/bin"
I would normally expect to see an architecture part to your library and
command paths. So assuming the EPICS_HOST_ARCH environment variable is
set, "$EPICS_BASE/lib" would instead be
"$EPICS_BASE/lib/$EPICS_HOST_ARCH" and "$EPICS_BASE/bin" would instead
be "$EPICS_BASE/bin/$EPICS_HOST_ARCH".
-lewis
The error message is the same:
../../bin/linux-arm/myexample: relocation
error: ../../bin/linux-arm/myexample: undefined symbol:
pvar_func_asSub
- RE: Building and testing Libera EPICS éæç
Re: Segment fault for edm 1-11-0s Dirk Kraemer
Re: Building and testing Libera EPICS Andrew Johnson
<2006>
2025
2026
<2006>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
