I am sure the EPICS libraries are on my path. I have set the environment variables LD_LIBRARY_PATH and PATH from the very start. Both of the above are incorrect, all EPICS install directories have an architecture component as well; you need to use these instead: export LD_LIBRARY_PATH="$LD_LIBRARY_PATH:$EPICS_BASE/lib/$EPICS_HOST_ARCH" export PATH="$PATH:$EPICS_BASE/bin/$EPICS_HOST_ARCH" - Andrew -- There is considerable overlap between the intelligence of the smartest bears and the dumbest tourists -- Yosemite National Park Ranger
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
