1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Building and testing Libera EPICS
Cc: [email protected], tech talk <[email protected]>
Date: Wed, 22 Nov 2006 11:54:31 +0000 (GMT)
On Tue, 21 Nov 2006, Andrew Johnson wrote:
        export LD_LIBRARY_PATH="$LD_LIBRARY_PATH:$EPICS_BASE/lib"
        export PATH="$PATH:$EPICS_BASE/bin"
Both of the above are incorrect, all EPICS install directories have an architecture component as well; you need to use these instead:
 export LD_LIBRARY_PATH="$LD_LIBRARY_PATH:$EPICS_BASE/lib/$EPICS_HOST_ARCH"
 export PATH="$PATH:$EPICS_BASE/bin/$EPICS_HOST_ARCH"
Hmm. This does of course depend on how EPICS has been installed on the target system, and I suspect that I may have broken the rules in my definition of how EPICS is installed on the Libera electron beam position monitor (this is the environment Yan Ying Bing is using).
If you install EPICS as I instruct Libera users:
	1. build EPICS
	2. run install-epics on the host
	3. run libera-install-epics on the target
then the following files are installed on the *target*:
	/opt/epics/lib	<- copy of $EPICS_BASE/lib/linux-arm/*.so
	/opt/epics/bin	<- only $EPICS_BASE/bin/linux-arm/caRepeater
This is a bit non-standard, but I hope not too confusing. Of course, if this has been done, then we need
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/opt/epics/lib
export PATH=$PATH:/opt/epics/bin
I hope this configuration is not too deviant!
Re: Building and testing Libera EPICS Andrew Johnson
RE: Building and testing Libera EPICS éæç
Prev: Re: Building and testing Libera EPICS Andrew Johnson
Next: RE: Motion control failure at APS - Not a Problem for Hytec 8601 / 8909 Darrell Nineham
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Building and testing Libera EPICS Andrew Johnson
