1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Fedora Core 6 & EPICS R3.14.8.2
To: Benjamin Franksen <[email protected]>
Cc: [email protected]
Date: Sat, 25 Nov 2006 09:15:08 +0900
Benjamin Franksen wrote:
On Friday 24 November 2006 19:49, Billy Adams wrote:
     OpenMotif was not included in Fedora Core 6 released in Oct.
2006, as expected.  But all is not lost yet.  EPICS R3.14.8.2 can be
compiled and executed using Fedora Core 6.
I installed "ALL OPTIONS" when installing Fedora Core 6. Installation took a little less than 6 Gigabytes. The only thing
else needed is OpenMotif.
I took the following two RPM files from Fedora Core 5
installation CD4 and installed them on Fedora Core 6:
openmotif-2.3.0-0.1.9.2.i386.rpm
openmotif-devel-2.3.0-0.1.9.2.i386.rpm
     Next I compiled EPICS R3.14.8, then the facility code, and
executed the facility code.  It works!
FWIW, installing openmotif-2.3.0 (beta) from source (on an amd64 debian-testing) went absolutely straight forward for me. In contrast to older versions of OpenMotif, which had a strange build system, the latest versions needs only the usual './configure; make; make install' routine. (You might, however, need to install one or two additional devel packages from your distro.)
I compiled openmotif-2.3.0 on MacOSX 10.4.8/Intel and it was straight forward too.
Now I can run medm and edm on my MacBook with X11 from Apple.
To build edm on this environment, I needed to modify libCom/osi/epicsMutex.cpp. But I don't know if it is proper way to fix the problem I encountered.
To build EPICS and its extensions on Knoppix5, I also use openmotif-2.3.0.
Ben
Noboru Yamamoto
EPICS group/J-PARC contro group
KEK, JAPAN
Noboru
Fedora Core 6 & EPICS R3.14.8.2 Billy Adams
Re: Fedora Core 6 & EPICS R3.14.8.2 Benjamin Franksen
Prev: Re: Fedora Core 6 & EPICS R3.14.8.2 Benjamin Franksen
Next: Edm 1-11-0s GOURNAY Jean-Francois DAPNIA
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: vmivme5565 driver for epics 3.13 Lei Ge
