1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: libPV.so contains no edm components
To: [email protected]
Date: Tue, 5 Dec 2006 11:00:11 +0100
Hello John Sinclair, hello Jianguo Ding,
thank you very much for your help. After adding the lines manually to the file
edmObjects the Objects "Byte", "Textupdate", "RegTextupdate" and "Textentry"
are available, though
edm -show /home/LLRF/EPICS/extensions/lib/linux-386/libPV.so
gives the following output:
Edm component file is /home/LLRF/EPICS/extensions/src/edm/setup/edmObjects
Author name not registered
Library contains no edm components
Thanks
Dorothea Wehler
Quoting Jianguo DING <[email protected]>:
> I added following lines directly to extensions/src/edm/setup/edmObjects to
> avoid this problem.
> TextupdateClass
> /usr/local/epics/extensions/src/edm/pvFactory/O.linux-x86/libPV.so Monitors
> Textupdate
> RegTextupdateClass
> RegTextupdate
> TextentryClass
> /usr/local/epics/extensions/src/edm/pvFactory/O.linux-x86/libPV.so Controls
> Textentry
> ByteClass /usr/local/epics/extensions/src/edm/pvFactory/O.linux-x86/libPV.so
> Monitors Byte
> Jianguo DING
> From: "Dorothea Wehler" <[email protected]>
> To: <[email protected]>
> Sent: Monday, December 04, 2006 10:53 PM
> Subject: libPV.so contains no edm components
> > Hello,
> > I have installed  edm-1-11-0s on  Fedora Core 4 and SUSE 9.0 (EPICS
> > base-3.14.7). On Fedora Core 4 I had to remove the lines in
> > "fonts.list", which were marked by Dirk Kraemer in his e-mail from
> > 21.11.2006 to avoid a "Segmentation Fault" during startup of the program.
> > Now edm starts without error but on both operating systems there are no
> > edm-components loaded from libPV.so.
> > The command "$EDM -add $EDMBASE/pvFactory/O.$ODIR/libPV.so" in
> > "setup.sh" produces the message: "Library contains no edm components".
> > What might be the reason? The output during installation of the library
> > is attached: "Inst_pvFactory"
> > I`m especially interested in the edm object "Byte".
> > Thanks for any help
> > Dorothea Wehler
libPV.so contains no edm components Dorothea Wehler
Prev: libPV.so contains no edm components Dorothea Wehler
Next: wxPython timer and KEK CaPython314 cause core dump Zhong Ren
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
