1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: wxPython timer and KEK CaPython314 cause core dump
To: [email protected]
Date: Tue, 5 Dec 2006 11:03:46 -0600 (CST)
I managed to isolate a core dump in a minimized Python code
(see below).  I found two components are essential to cause a
core dump: wx.Timer and ca.Monitor (or ca.Get).  Can someone
tell what the problem is?
import wx
import ca
def onTimer(event): pass
ca.Monitor('S:SRcurrentAI')
appli = wx.PySimpleApp()
frame = wx.Frame(None)
timer = wx.Timer()
timer.Bind(wx.EVT_TIMER, onTimer)
timer.Start(milliseconds = 10, oneShot = False)
appli.MainLoop()
Other info:
Pyhton 2.5
wxPython 2.6.3.3
RedHat Linux x86_64
GCC 4.1.1
To test, let the routine run for a while.  A core dump will
occur in a few minutes.
Re: wxPython timer and KEK CaPython314 cause core dump Noboru Yamamoto
Prev: Re: libPV.so contains no edm components Dorothea Wehler
Next: wxPython timer and KEK CaPython314 cause core dump Matt Newville
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: wxPython timer and KEK CaPython314 cause core dump Noboru Yamamoto
