1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: wxPython timer and KEK CaPython314 cause core dump
To: [email protected]
Cc: [email protected]
Date: Wed, 06 Dec 2006 10:47:29 +0900
I'm not familiar with WxPytho (yet).
But, the following code works on MacBook running MacOSX 10.4.8 with
Python2.5, wxPython2.7-osx-unicode-2.7.2.0-universal10.4-py2.5.dmg
and KEK version of CaPython314 ( I should have used the different name
to avoid confusion with FNAL version. Sorry).
import wx,ca
class MyApp(wx.PySimpleApp):
    def OnInit(self):
        frame = wx.Frame(None, -1, "Hello from wxPython")
        frame.Show(True)
        self.frame=frame
        self.ch=ca.channel("fred")
        self.ch.wait_conn()
        self.ch.monitor(self.ca_callback)
        self.ch.flush()
        self.SetTopWindow(frame)
        return True
    def ca_callback(self,valstat):
        self.ch.update_val(valstat)
        self.frame.Title="%s:%f"%(self.ch.name,self.ch.val)
if __name__ == "__main__":
    app = MyApp(0)
    app.MainLoop()
I hope this can give some idea.
Noboru Yamamoto
EPICS group/J-PARC control group
KEK, JAPAN
Zhong Ren wrote:
> I managed to isolate a core dump in a minimized Python code
> (see below).  I found two components are essential to cause a
> core dump: wx.Timer and ca.Monitor (or ca.Get).  Can someone
> tell what the problem is?
> import wx
> import ca
> def onTimer(event): pass
> ca.Monitor('S:SRcurrentAI')
> appli = wx.PySimpleApp()
> frame = wx.Frame(None)
> timer = wx.Timer()
> timer.Bind(wx.EVT_TIMER, onTimer)
> timer.Start(milliseconds = 10, oneShot = False)
> appli.MainLoop()
> Other info:
> Pyhton 2.5
> wxPython 2.6.3.3
> RedHat Linux x86_64
> GCC 4.1.1
> To test, let the routine run for a while.  A core dump will
> occur in a few minutes.
begin:vcard
fn:Noboru Yamamoto
n:Yamamoto;Noboru
email;internet:[email protected]
tel;work:+81-29-864-1171, ext. 5309
tel;fax:+81-29-864-0321
x-mozilla-html:FALSE
version:2.1
end:vcard
wxPython timer and KEK CaPython314 cause core dump Zhong Ren
Prev: next EPICS meeting at DESY in April 2007 Matthias Clausen
Next: JCA, Gateways and EPICS_CA_ADDR_LIST Rees, NP (Nick)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: wxPython timer and KEK CaPython314 cause core dump Zhong Ren
Next: wxPython timer and KEK CaPython314 cause core dump Matt Newville
