I maintain oagwish so I would definitely recommend it :) It started with
et_wish but has evolved since then. But the basics are still the same.
Your command "pv linkw cur PVname" does not set the variable "cur" in
the current context, instead it sets the global variable "cur". Also you
probably always want to use linkw and putw instead of link and put. This
way you don't have to use any pv info commands in some loop waiting for
the PV to respond. So your code would look like:
proc my_test {} {
global cur errorCode
if {[pv linkw cur bl_mag_crv1_cmd] != 0} {
puts "error: $errorCode"
exit
set cur 0.001
puts "cur = $cur"
if {[pv putw cur] != 0} {
exit
puts "executed test"
my_test
Hope this helps,
--Bob Soliday
John Dobbins wrote:
Dear All,
(Preface: new to using Tcl so please don't assume I know what I'm doing)
I have built et_wish from the distribution
http://www.aps.anl.gov/epics/download/extensions/caTCL_20020802.tar.gz
I can start et_wish and the various Channel Access commands work fine
from the et_wish command line, but when I try to use them from inside a
proc they stop working. If inside a proc I use
pv link variable_name record_name
pv put variable_name
then the value of the record remains unchanged. See example code below.
1) Does anyone have any ideas about this?
(Tcl8.3.5 on Scientific Linux 3)
2) I see that oagwish from APS appears more actively maintained. Should
I be using this instead?
Thanks
John Dobbins
This et_wish command line code works:
% pv link cur bl_mag_crv1_cmd
0
% set cur 0.001
0.001
% pv put cur
0
This script does not:
proc my_test {} {
set x [pv info cur state]
puts $x
set cur 0.001
puts "cur = $cur"
pv put cur
after 50
puts $x
my_test
and has output:
{cur OK}
cur = 0.001
{cur OK}
executed test
- Channel Access and Tcl John Dobbins
APS IT Maintenance Andrew Johnson
<2006>
2025
2026
<2006>
2025
2026
