1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: StreamDevice ioc dying
To: [email protected]
Date: Fri, 12 Jan 2007 09:35:39 +0100
Hi Mike,
you can try to switch on debugging (var streamDebug 1) to see what's going on inside StreamDevice.
This may produce a lot debugging output. Better only switch it on after iocInit.
StreamDevice should be able to handle null characters. Of course there may be a bug inside
StreamDevice that crashes the ioc under certain conditions. I need more detailled information about
the error conditions.
Can you send me your records and protocol file? What is your operating system?
I guess the "Killed" message comes from the operating system. It does not come from StreamDevice or
asyn or EPICS base. You can try to switch on core dumps (ulimit -c unlimited) before starting your
IOC and analyse it with a debugger.
Dirk
Mike Forster wrote:
Hi folks,
We've got a new ioc that controls a power supply over RS-232 with StreamDevice. When the control power on the power supply is cycled, the ioc dies with only the message "Killed". (Specifically the ioc dies when the PS is turned back on.)
Turning on asyn tracing shows that upon turning the PS back on, some extra data like null characters are read in through StreamDevice. (Perhaps data that was interrupted?) On reading this, the ioc dies. The mismatch exception handling is turned on, but I'm not quite sure what command to put inside the handler to deal with this problem. I've tried several ideas but none seem to work.
Using epics 3.14.8.2 <http://3.14.8.2>, streamDevice 2-1, and asyn 4-6.
(Also tried with 3.14.7, 2-1, and 4-3)
Any ideas on what could be going on that the ioc can't handle?
Mike Forster
Wilson Lab
Cornell University
-- Dr. Dirk Zimoch Swiss Light Source Computing and Controls Paul Scherrer Institut phone +41 56 310 5182 fax +41 56 310 4413
StreamDevice ioc dying Mike Forster
Prev: Re: StreamDevice ioc dying Eric Norum
Next: Re: Re: VME-based arbitary function generator Damjan Golob
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: EPICS driver for Libera released Michael Abbott
