1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: StreamDevice ioc dying
To: Mike Forster <[email protected]>
Cc: tech-talk tech-talk <[email protected]>
Date: Thu, 11 Jan 2007 11:24:46 -0600
Have you tried running the IOC under GDB? (assuming you're running this on Linux or Darwin) You can then do some post-mortem investigations.
On Jan 11, 2007, at 11:07 AM, Mike Forster wrote:
Hi folks,
We've got a new ioc that controls a power supply over RS-232 with StreamDevice. When the control power on the power supply is cycled, the ioc dies with only the message "Killed". (Specifically the ioc dies when the PS is turned back on.)
Turning on asyn tracing shows that upon turning the PS back on, some extra data like null characters are read in through StreamDevice. (Perhaps data that was interrupted?) On reading this, the ioc dies. The mismatch exception handling is turned on, but I'm not quite sure what command to put inside the handler to deal with this problem. I've tried several ideas but none seem to work.
Using epics 3.14.8.2, streamDevice 2-1, and asyn 4-6.
(Also tried with 3.14.7, 2-1, and 4-3)
Any ideas on what could be going on that the ioc can't handle?
Mike Forster
Wilson Lab
Cornell University
-- Eric Norum <[email protected]> Advanced Photon Source Argonne National Laboratory (630) 252-4793
StreamDevice ioc dying Mike Forster
Prev: StreamDevice ioc dying Mike Forster
Next: Re: StreamDevice ioc dying Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <2007>  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
