1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS Driver for motor through Ethernet/Serial?
To: "Denison, PN \(Peter\)" <[email protected]>, <[email protected]>, "tech-talk" <[email protected]>
Date: Mon, 22 Jan 2007 07:57:35 -0600
There are two levels at which asyn can be used with the motor record.  The first is as the low-level communication layer between the motor driver and the serial, Ethernet or GPIB port.  That use is supported by any motor controller supported by the motor module, including many models from Newport, IMS, ACS, Faulhaber, and many others.  With that asyn layer, you can use either local serial ports or Ethernet to serial converters with no changes to the motor driver.
The second use is what Peter described, i.e. as the interface between the motor record device support and the motor record driver.  That is a relatively recent development, and is currently supported for the Newport MM400, Newport XPS, and Delta Tau TPMAC.
From: Denison, PN (Peter) [mailto:[email protected]]
Sent: Mon 1/22/2007 3:54 AM
To: [email protected]; tech-talk
It would help if you gave a few more details about the exact model of motor.
The latest release of the motor support (R6-1, from http://www.aps.anl.gov/upd/people/sluiter/epics/motor/R6-1/motorR6-1.tar.gz) includes a driver for Newport motor controllers, using Asyn as the low-level protocol to talk to the motor controller.  There is also a driver for Delta-Tau motor controllers (tpmac at http://epics.svn.sourceforge.net/epics/applications/tags/tpmac/3-3/) which also uses this release of motor support, and serial Asyn as the lowest layer transport to the motor controller.
To support your motor, you could have a look at one of these, and adapt it to talk the protocol required by your serial-port motor. The ethernet/serial converter box should be transparently supported by Asyn, if you're lucky.
Peter Denison, Senior Software Engineer
Diamond Light Source Ltd., Diamond House, Chilton, Didcot, Oxon, OX11 0DE
Tel: +44 1235 778511
	Sent: 22 January 2007 07:20
	To: tech-talk
	Subject: EPICS Driver for motor through Ethernet/Serial?
	hi,
	  I want to find a EPCIS 314 driver for a motor which has a serial port, connected to an Ethernet/Serial converter boxes, IOC is redhat linux. all the control string is ASCII code. Is there somebody using Asyn driver to implement this? Can you send me an application?
	  Thanks a lot for your help.
	Best wishes
	Geyang 2007/1/22
RE: EPICS Driver for motor through Ethernet/Serial? Denison, PN (Peter)
Prev: RE: EPICS Driver for motor through Ethernet/Serial? Denison, PN (Peter)
Next: Re: EPICS Driver for motor through Ethernet/Serial? Pete R. Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
