RTM :-)
http://www.aps.anl.gov/epics/base/R3-14/9-docs/KnownProblems.html
HTH
-- Till
K.M Ha wrote:
> Hi All,
> I found error messages when the base-3.14.9 IOC compile.
> Dose anyone have a proposal for solve this errors?
> /usr/local/rtems/rtems-4.7/bin/m68k-rtems4.7-gcc --pipe -B/usr/local/rtems/rtems-4.7/m68k-rtems4.7/uC5282/lib/ -specs bsp_specs -qrtems -fasm -c -m528x -DUNIX -ansi -O4 -g -g -Wall -DMY_DO_BOOTP=NULL -DRTEMS_NETWORK_CONFIG_DNS_DOMAINNAME=aps.anl.gov -DRTEMS_NETWORK_CONFIG_DNS_DOMAINNAME=aps.anl.gov -I. -I.. -I../../../../include/os/RTEMS -I../../../../include ../rtems_init.c
> ../rtems_init.c:40:19: error: iocsh.h: No such file or directory
> ../rtems_init.c: In function 'initialize_local_filesystem':
> ../rtems_init.c:151: warning: implicit declaration of function 'open'
> ../rtems_init.c: In function 'initialize_remote_filesystem':
> ../rtems_init.c:192: warning: implicit declaration of function 'rpcUdpInit'
> ../rtems_init.c:193: warning: implicit declaration of function 'nfsInit'
> ../rtems_init.c:248: warning: implicit declaration of function 'nfsMount'
> ../rtems_init.c: At top level:
> ../rtems_init.c:305: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'netStatArg0'
> ../rtems_init.c:306: error: expected '=', ',', ';', 'asm' or '__attribute__' before '*' token
> ../rtems_init.c:307: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'netStatFuncDef'
> ../rtems_init.c:308: warning: type defaults to 'int' in declaration of 'iocshArgBuf'
> ../rtems_init.c:308: error: expected ';', ',' or ')' before '*' token
> ../rtems_init.c:313: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'stackCheckFuncDef'
> ../rtems_init.c:314: warning: type defaults to 'int' in declaration of 'iocshArgBuf'
> ../rtems_init.c:314: error: expected ';', ',' or ')' before '*' token
> ../rtems_init.c:319: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'heapSpaceFuncDef'
> ../rtems_init.c:320: warning: type defaults to 'int' in declaration of 'iocshArgBuf'
> ../rtems_init.c:320: error: expected ';', ',' or ')' before '*' token
> ../rtems_init.c:335: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'nfsMountArg0'
> ../rtems_init.c:336: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'nfsMountArg1'
> ../rtems_init.c:337: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'nfsMountArg2'
> ../rtems_init.c:338: error: expected '=', ',', ';', 'asm' or '__attribute__' before '*' token
> ../rtems_init.c:340: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'nfsMountFuncDef'
> ../rtems_init.c:341: warning: type defaults to 'int' in declaration of 'iocshArgBuf'
> ../rtems_init.c:341: error: expected ';', ',' or ')' before '*' token
> ../rtems_init.c: In function 'iocshRegisterRTEMS':
> ../rtems_init.c:362: warning: implicit declaration of function 'iocshRegister'
> ../rtems_init.c:362: error: 'netStatFuncDef' undeclared (first use in this function)
> ../rtems_init.c:362: error: (Each undeclared identifier is reported only once
> ../rtems_init.c:362: error: for each function it appears in.)
> ../rtems_init.c:362: error: 'netStatCallFunc' undeclared (first use in this function)
> ../rtems_init.c:363: error: 'stackCheckFuncDef' undeclared (first use in this function)
> ../rtems_init.c:363: error: 'stackCheckCallFunc' undeclared (first use in this function)
> ../rtems_init.c:364: error: 'heapSpaceFuncDef' undeclared (first use in this function)
> ../rtems_init.c:364: error: 'heapSpaceCallFunc' undeclared (first use in this function)
> ../rtems_init.c:366: error: 'nfsMountFuncDef' undeclared (first use in this function)
> ../rtems_init.c:366: error: 'nfsMountCallFunc' undeclared (first use in this function)
> ../rtems_init.c: In function 'initConsole':
> ../rtems_init.c:378: warning: implicit declaration of function 'fileno'
> ../rtems_init.c: In function 'Init':
> ../rtems_init.c:535: warning: implicit declaration of function 'tzset'
> ../rtems_init.c:545: warning: implicit declaration of function 'main'
> make[4]: *** [rtems_init.o] error 1
> make[4]: ³ª°¨ `/usr/local/epics/base-3.14.9/src/RTEMS/base/O.RTEMS-uC5282' directory
> make[3]: *** [install.RTEMS-uC5282] error 2
> make[3]: ³ª°¨ `/usr/local/epics/base-3.14.9/src/RTEMS/base' directory
> make[2]: *** [base.install] error 2
> make[2]: ³ª°¨ `/usr/local/epics/base-3.14.9/src/RTEMS' directory®
> make[1]: *** [RTEMS.install] error 2
> make[1]: ³ª°¨ `/usr/local/epics/base-3.14.9/src' directory
> make: *** [src.install] error 2
> [root@localhost base-3.14.9]#
> Kiman Ha,
> Pohang Accelator Labaratory
- base3.14.9 compile error under uC5282-RTEMS K.M Ha
Re: base3.14.9 compile error under uC5282-RTEMS Janet Anderson
Re: CAC: Ignored conn resp to conn chan CID=0 SID=4180934912? Jeffrey O. Hill
<2007>
2025
2026
CAC: Ignored conn resp to conn chan CID=0 SID=4180934912? Dirk Zimoch
<2007>
2025
2026
