I thought it would be of value to publish a summary of results from some prototyping and evaluation work I did. I was interested in exploring alternatives to channel access in EPICS for several different reasons. One, I wanted to learn more about details of the codebase of rsrv and by extension, the behavior of channel access. Two, I wanted to learn more about the OMG DDS specification, and in particular the underlying wire protocol called RTPS. Three, I think it would be useful to have a more broadly known and standards-based controls protocol in EPICS. I focused on applying RTPS to EPICS, while a colleague here (Shifu Xu) has been looking at ICE (still a work in progress, report forthcoming). Caveat: I didn't have enough time to get really deep, so there are probably some unexplored angles. In summary, here's two bullet points to take away from this: 1. Implementations of OMG DDS Wire Protocol, as specified by OMG's "The Real-time Publish-Subscribe Wire Protocol, DDS Interoperability Wire Protocol (Final Adopted Specification ptc/08-02-2006)", are not well suited as a substitute for EPICS channel access. 2. I have come to appreciate how precisely optimized the channel access protocol is for what we do. Still, I think it is a valuable exercise to explore the tradeoffs involved in alternatives. What follows is some background information and details of what I did. The Object Management Group (OMG) originally released a specification called the Data Distribution Service (DDS). This was really just an API and high-level behavior specification. Implementations could be completely non-interoperable. Some time later, one commercial vendor of DDS (RTI NDDS) submitted their implementation and standardized that as the interoperable wire protocol, called the Real-Time Publish-Subscribe (RTPS) protocol. To my knowledge, there are now 3 implementations available: 1. RTI NDDS 4.0 - a commercial implementation and generally considered THE implementation 2. Thales Splice - a commercial implementation 3. Ocera Project ORTE - an open-source implementation called ORTE from the Ocera project The RTPS wire protocol specification consists of a PIM (Platform Independent Model) part, and a PSM (Platform Specific Model) part. The specification includes only the PSM for running RTPS on UDP/IP. I used the ORTE open-source implementation to prototype with. This implementation leaves much to be desired in that it is most certainly not zero-copy, and uses malloc all over the place, but it is interoperable (ie. "correct"), and works fine for basic prototyping. One claimed benefit of RTPS on UDP is that the implementation becomes much more portable, since we are now in full control and are not dependent on the vagaries of various platform's TCP stacks. Reliable delivery is built on top of UDP within RTPS. Disadvantage, possibly, is that much of protocol is now in user-space (or, rather it is for ORTE). The essence of RTPS is that one creates "topics" to which pre-defined message structures may be published, and clients may subscribe. Think channel access monitors. Secondly, all nodes on the network maintain a cache that knows about all the available topics on the network. There is no topic "nameserver". There is a peer-to-peer "discovery protocol" which takes care of disseminating all topics to all caches (and cleaning out topics that no longer exist). Topics are a one-way communication (although through QoS settings you can specify guaranteed or best-effort delivery). There are all kinds of neat bells-and-whistles to RTPS, but I mainly had trouble using it at a fundamental level. Messages to topics are fixed size. The protocol will batch messages in network packets, but still, you have to enumerate every possible structure you might send as a separate message type, and register that with the topic. Not very convenient given the variety of message sizes that are conveyed via channel access. My prototype goal was to gut the EPICS rsrv of all channel access, replace it with ORTE, and then code a simple caget and camonitor command line client. I did not try to emulate the channel access API. Although I managed to cobble this together, I ran into several dilemmas which revealed how unsuited this was. Using rsrv as a basis... 1. I began with making a topic per process variable. Since topics are one-way, I actually had to define 2 per process variable. One "writer" topic was for clients to send commands to (like put, synchronous get, monitor), and one "reader" topic was for the get response or monitor events. This was clearly unscalable, since when an IOC comes up, the RTPS discovery protocol has to communicate every single topic (PV) to every single other node (including other IOCs). It does this regardless of what PV's a given client on a given node would be interested in. 2. Ok, try again. I decided to view topics more like channel access virtual circuits, and create them on demand. Basically, a pair of topics for each desired host-host communication. This allows me to do some of the nice things channel access does like clean up ioc resources when clients go away. But publish-subscribe by its very nature is not good for this, since fundamentally, publishers do not know who has subscribed (or even IF anyone is currently subscribed). So I wound up having to create special topics that are just there for the purpose of establishing a set of "virtual circuit" topics. Then there is the problem of naming these "virtual circuit" topics. The names have to be unique network-wide. In short, this all turns out quite unwieldy as well. It just gets ugly when you try to use fundamental abstractions like topics to emulate other abstractions like TCP circuits. Although I got something working along the lines of (2), I gave up at this point. I think for something like RTPS to work for us, we would wind up needing a custom discovery protocol (allowable), and even then we would wind up abusing the idea of topics anyways. Much of the advantage of using a standards-based protocol would be lost, as we would not be interoperable. Hope this is of interest,
Claude Saunders
| ANJ, 10 Nov 2011 |
Home
News
About
Talk
Base
Modules
Extensions
