I've been watching DDS from the sidelines as well, and only recently
decided to take the plunge. It really has not achieved widespread
support, and I'm not sure if that's because of limitations like those I
discovered, or because it didn't reallly follow what I would consider a
normal progression towards being a standard. It started out as
proprietary, then became an odd API-only "standard" through OMG for some
time. Clearly not interoperable. Only later was a wire protocol
released. Even so, there are so many options and extensible areas of the
specification that it seems unlikely initial implementations will play
well together. The DDS spec is really quite recent (2004), so if CORBA
is any guide, we should see this mature in about 10 years :)
I only looked at a few of the QoS capabilities implemented by ORTE, but
the RTPS specification is an interesting read in this area, and can give
lots of ideas. For example, they consider timestamping of messages a QoS
option. Also, you can have multiple publishers of the same message type
on the same topic, each with a relative "strength". Subscribers can
indicate that they want a message from strength "2" publishers first,
unless some time window passes without a message, in which case the
subscriber will accept a message from strength "1" publishers. So in
this manner one could implement a form of failover. The specification
also has something called "Content-Filtered Topics", which is much like
the "beam flavor subscriptions" that Jeff has been talking about for CA.
The filtering can be implemented on the subscriber side, or on the
publisher side (preferred, but more complex). There is also something
called "Coherent Sets", which seems to be similar to the channel access
"sync groups". At any rate, it's interesting to find the parallels. I
think DDS makes many of these concepts more explicit.
Just out of curiosity, what other RTI S/W have you used? Other than
NDDS, I'm only aware of their SkyBoard product (which is very odd and
interesting at the same time).
regards, Claude
Lawrence T. Hoff wrote:
Thanks for sharing, Claude!
I have been watching DDS "from the sidelines" for some time now.
Ignoring the technical details, my chief reservation is that DDS
does not
seem to be achieving widespread support, despite active marketing by RTI.
Disclaimer: I am actually a very satisfied user of other RTI S/W, but
trying
to use a communication standard that is not widely adopted gives me
visions
of trying to make hotel reservations in Esperanto. :-)
On the plus side, DDS does provide "connection management" (built
on top of UDP/IP), and (more importantly, perhaps) includes some level
of support for user-defined Quality of Service (QoS) parameters when
establishing connections.
Did you learn anything about DDS's QoS capabilities that could
(theoretically) be applied to CA?
-- Larry
- Re: evaluation of OMG DDS as a controls protocol for EPICS Kay-Uwe Kasemir
- Re: evaluation of OMG DDS as a controls protocol for EPICS Lawrence T. Hoff
- evaluation of OMG DDS as a controls protocol for EPICS Claude Saunders
Re: "Heartbeat" databases or sequences? Kay-Uwe Kasemir
Re: MODBUS communication with H2-ECOM100 AuotmationDirect DL205 system? D. Peter Siddons
<2007>
2025
2026
<2007>
2025
2026
ANJ, 10 Nov 2011 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
