1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: ca_sg_put problem with DISP=1
To: TechTalk EPICS <[email protected]>
Date: Wed, 28 Feb 2007 16:49:28 +0100
Hi all,
I got a strange effect with ca_sg_put if writing to a record where DISP=1.
The ca_sg_put succeeds (returns ECA_NORMAL) but then,
an error message is printed asynchronously:
CA.Client.Exception...............................................
Warning: "Channel write request failed"
Context: "op=1, channel=DZ-AO3, type=DBR_invalid, count=0, ctx="write notify request rejected""
Source File: ../syncGroupWriteNotify.cpp line 98
Current Time: Wed Feb 28 2007 16:40:34.421658000
Finally, ca_sg_block times out, long after it was clear to CA that writing failed.
Especially the last point is strange to me. Is this a bug or is it designed this way?
If it works as intended, what is the correct way to handle failing synchronous writes to records with DISP=1 without timing out?
I am using R3.14.8.2.
Dirk
-- Dr. Dirk Zimoch Computing and Controls Paul Scherrer Institut phone +41 56 310 5182 fax +41 56 310 4413
Re: ca_sg_put problem with DISP=1 Andrew Johnson
Prev: task priorities, busy cpu, and timeout Dennis Nicklaus
Next: Re: task priorities, busy cpu, and timeout Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: task priorities, busy cpu, and timeout Korhonen Timo
Next: Re: ca_sg_put problem with DISP=1 Andrew Johnson
