A couple of small additions: ------------- ------ ------- ----------------------------in drvTS (which will hopefully soon be history) this task communicates either with a NTP time server or a "timing master" IOC to synchronize the local time to one of these time sources. This is executed typically rather seldom (like once in 10 sec), defined by the TS sync rate parameter in TSConfigure. TSwdIncTime 109 90=High drvTS (apsEvent module)This is a "Watchdog task", and the essential part of the code runs at interrupt level. This routine increments the IOC local time every system clock tick (60 Hz, unless set otherwise.) In the new code that also Ralph Lange mentioned a couple of days ago, we have got rid of this stuff (and I am very happy about that.) Timo -- Timo Korhonen PSI (Paul Scherrer Institut, http://www.psi.ch) CH-5232 Villigen PSI tel + 41- 56 3103262 fax + 41 - 56 310 3383 e-mail: [email protected]
| ANJ, 10 Nov 2011 |
Home
News
About
Talk
Base
Modules
Extensions
