On Wednesday 28 February 2007 23:18, Andrew Johnson wrote:
> Dennis Nicklaus wrote:
> > Is there an existing document/web page describing the duties and
> > relative priorities of the various Epics tasks somewhere? Which
> > task(s) are responsible for responding to a CA Client (the CAS-client
> > tasks, I'm guessing)?
> Sorry, there probably should be but no such document exists.
I have made a start by quickly compiling teh following table from vxWorks
console output and what I found in the sources. It might be incomplete
and/or erroneous.
Apart from filling in missing information (see question marks), it might be
sensible to have some sort of rationale for the relative priorities. For
instance, it is unclear to me why the timerQueue task has higher priority
than cbLow task.
EPICS TASKS
NAME VX_PRI OSI_PRI DESCRIPTION
ts_Casync 109 90=High drvTS (apsEvent module)
TSwdIncTime 109 90=High drvTS (apsEvent module)
cbHigh 128 71=ScanHigh+1 callback task (prio=high)
timerQueue 129 70=ScanHigh scan task
scanOnce 129 70=ScanHigh scan task
scan0.1 133 66=ScanLow+6 scan task
scan0.2 134 65=ScanLow+5 scan task
cbMedium 135 64=ScanLow+4 callback task (prio=medium)
scan0.5 135 64=ScanLow+4 scan task
scan1 136 63=ScanLow+3 scan task
scan2 137 62=ScanLow+2 scan task
scan5 138 61=ScanLow+1 scan task
scan10 139 60=ScanLow scan task
timerQueue 139 60=ScanLow epicsTimer
cbLow 140 59=ScanLow-1 callback task (prio=low)
asCaTask 142 57=ScanLow-3 access security
CAC-UDP 147 52=Medium+2 CA client
timerQueue 148 51=Medium+1 epicsTimer
CAC-event 148 51=Medium+1 CA client
dbCaLink 149 50=Medium CA links (client? server?)
poolPoll 149 50=Medium ???
CAC-event 178 21=CAServerLow+1 CA Server
CAS-TCP 181 18=CAServerLow-2 CA Server
CAS-beacon 182 17=CAServerLow-3 CA Server
CAS-UDP 183 16=CAServerLow-4 CA Server
errlog 189 10=Low errlog
taskwd 189 10=Low task watchdog
ipToAsciiPr 189 10=Low ???
CAC-repeate 189 10=Low CA Client (repeater)
Cheers
Ben
"Programming = Mathematics + Murphy's Law" (Dijkstra in EWD1008)
- Re: task priorities, busy cpu, and timeout Kay-Uwe Kasemir
- RE: task priorities, busy cpu, and timeout Jeff Hill
- Re: task priorities, busy cpu, and timeout Korhonen Timo
- task priorities, busy cpu, and timeout Dennis Nicklaus
- Re: task priorities, busy cpu, and timeout Andrew Johnson
Re: ca_sg_put problem with DISP=1 Dirk Zimoch
Re: ca_sg_put problem with DISP=1 Benjamin Franksen
<2007>
2025
2026
<2007>
2025
2026
ANJ, 10 Nov 2011 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
