On Mar 1, 2007, at 06:27 , Benjamin Franksen wrote:
I have made a start by quickly compiling teh following table from
vxWorks
console output and what I found in the sources. It might be incomplete
and/or erroneous.
For what it's worth, I think
ipToAsciiPr 189 10=Low ???
is the task that CA uses to resolve host names for IP addresses.
Apart from filling in missing information (see question marks), it
might be
sensible to have some sort of rationale for the relative
priorities. For
instance, it is unclear to me why the timerQueue task has higher
priority
than cbLow task.
I'm really unclear about another task where I wonder if it
disturbs the intended order of things:
On vxWorks, there's the "tNetTask" at a very high priority.
At the SNS, we have had problems whenever that task doesn't get
to run as often as it wants to. When computations that can take
millisecs run higher than tNetTask, the result is an irrecoverable
messup of the network stack, at least with our 5.5.1 kernels
on MVME 2100 CPUs.
It might make sense that the network chips require to be serviced
right away, or maybe that's just an imperfection in our version
of the network code, fixed in more recent vxWorks versions,
but in any case:
Doesn't a tNettask at a high priority mean that even if we
otherwise move all the CA tasks to the bottom, network
traffic will still disturb the scanning?
-Kay
EPICS TASKS
NAME VX_PRI OSI_PRI DESCRIPTION
ts_Casync 109 90=High drvTS (apsEvent module)
TSwdIncTime 109 90=High drvTS (apsEvent module)
cbHigh 128 71=ScanHigh+1 callback task (prio=high)
timerQueue 129 70=ScanHigh scan task
scanOnce 129 70=ScanHigh scan task
scan0.1 133 66=ScanLow+6 scan task
scan0.2 134 65=ScanLow+5 scan task
cbMedium 135 64=ScanLow+4 callback task (prio=medium)
scan0.5 135 64=ScanLow+4 scan task
scan1 136 63=ScanLow+3 scan task
scan2 137 62=ScanLow+2 scan task
scan5 138 61=ScanLow+1 scan task
scan10 139 60=ScanLow scan task
timerQueue 139 60=ScanLow epicsTimer
cbLow 140 59=ScanLow-1 callback task (prio=low)
asCaTask 142 57=ScanLow-3 access security
CAC-UDP 147 52=Medium+2 CA client
timerQueue 148 51=Medium+1 epicsTimer
CAC-event 148 51=Medium+1 CA client
dbCaLink 149 50=Medium CA links (client? server?)
poolPoll 149 50=Medium ???
CAC-event 178 21=CAServerLow+1 CA Server
CAS-TCP 181 18=CAServerLow-2 CA Server
CAS-beacon 182 17=CAServerLow-3 CA Server
CAS-UDP 183 16=CAServerLow-4 CA Server
errlog 189 10=Low errlog
taskwd 189 10=Low task watchdog
CAC-repeate 189 10=Low CA Client (repeater)
Cheers
Ben
"Programming = Mathematics + Murphy's Law" (Dijkstra in EWD1008)
- RE: task priorities, busy cpu, and timeout Jeff Hill
- task priorities, busy cpu, and timeout Dennis Nicklaus
- Re: task priorities, busy cpu, and timeout Andrew Johnson
- Re: task priorities, busy cpu, and timeout Benjamin Franksen
Re: ca_sg_put problem with DISP=1 Benjamin Franksen
<2007>
2025
2026
<2007>
2025
2026
