1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ca_sg_put problem with DISP=1
To: Dirk Zimoch <[email protected]>
Cc: TechTalk EPICS <[email protected]>
Date: Thu, 01 Mar 2007 10:54:16 -0600
Dirk Zimoch wrote:
You said, ca_sg functions are not that useful. I thought they are the correct way to implement a "caput and wait until processing has completed". Isn't that correct? Is there an other way to do that?
As Ben has already pointed out, that functionality is implemented by ca_put_callback(), not the ca_sg functions. Looking at it I can see that the CA documentation doesn't really explain the rationale for sync groups or emphasize the fundamental difference between ca_put() and ca_put_callback() very well (and ca_put_callback() isn't even listed in the function index). I've filed a bug report to ask Jeff to improve these aspects of the documentation.
- Andrew
The right to be heard does not automatically include
the right to be taken seriously. -- Hubert H. Humphrey
ca_sg_put problem with DISP=1 Dirk Zimoch
Re: ca_sg_put problem with DISP=1 Andrew Johnson
Re: ca_sg_put problem with DISP=1 Dirk Zimoch
Prev: Re: task priorities, busy cpu, and timeout Korhonen Timo
Next: Serial port access and loging services for IOCs? Thompson, David H.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: ca_sg_put problem with DISP=1 Benjamin Franksen
