1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Serial port access and loging services for IOCs?
To: "Thompson, David H." <[email protected]>
Date: Fri, 02 Mar 2007 10:40:02 +0100
Have a look at conserver (a free tool available at www.conserver.com):
--- snip ---
Conserver is an application that allows multiple users to watch a serial console at the same time. It can log the data, allows users to take write-access of a console (one at a time), and has a variety of bells and whistles to accentuate that basic functionality. The idea is that conserver will log all your serial traffic so you can go back and review why something crashed, look at changes (if done on the console), or tie the console logs into a monitoring system (just watch the logfiles it creates). With multi-user capabilities you can work on equipment with others, mentor, train, etc. It also does all that client-server stuff so that, assuming you have a network connection, you can interact with any of the equipment from home or wherever.
--- snip ---
So its basic functionality is similar to iocConsole, but it offers:
   * write access only to one client, others get a read-only
     connection, but may force a takeover
   * ssh/ssl access from the client program (running on your office
     machine) to the console-server (that provides the access to IOCs)
   * access control configuration that allows definition of users
     (groups) that may be assigned a password to get specified access
     (r/o or r/w) to specified groups of serial lines
   * for each serial: configurable commands how to re-connect to it, in
     case the connection is down or the console-server was restarted
   * rotated log files, either per serial line or combined
   * you can configure multiple console-servers to accept all
     connections and forward connections to serials that are not local
     to the "real" host of that serial line.
We use it for over a year now, and it's just marvelous.
vxWorks IOCs are connected to through terminal servers (via telnet to the terminal server), soft IOCs are started with screen and connected to using ssh: one pseudo user per IOC on the soft IOC host machine, the authorized_keys file restricts access to the console-server and starts the screen client (in your case probably "cu"), so that the console-server just has to ssh to the soft IOC host with the right user name.
We keep daily per-IOC logs for a month, plus a weekly combined log of all IOCs (actually one for each group, such as controls, diagnostics, beamlines). All log files are accessible through a web server (just a regular one with trivial configuration).
There are matching tools available that grep through the log files, and may execute commands (as writing mails, send SMS ...) when they "see" certain things in a log file. We didn't start using these, though. Yet, maybe.
Hope this helps,
Ralph
ps. This tool could also be very interesting for your IT guys (monitoring server farms, switch hardware and such) - in our case that's where I got the idea and lots of support from.
Thompson, David H. wrote:
Here at SNS we have lately had problems with IOCs crashing without leaving any trail for analyzing what the problem was. We have our own home grown procServe and we are looking into the iocConsole/screen software that SLAC is using. We are different from SLAC in that we use Digi port servers with a driver on one of the linux servers that maps port server ports into local /dev/ttyXXNNN devices. We just use 'cu' to open a serial port. IocConsole does not support that but making it do so would not be hard I don't think.
Looks like a modified iocConsole is our best option but before we commit to it we thought we out to see what others are doing to capture the last few lines of terminal activity from running and crashed hard IOCs.
Any ideas?
Serial port access and loging services for IOCs? Thompson, David H.
Prev: First Light in Beamline at the Australian Synchrotron Richard Farnsworth
Next: epics / fpga David Kline
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Serial port access and loging services for IOCs? Pete Jemian
Next: Re: Serial port access and loging services for IOCs? Theo Larrieu
