1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Daylight savings time
To: [email protected]
Date: Mon, 12 Mar 2007 17:30:06 -0400
Something very weird just happened here and we are still trying to figure out why.
Running iocs were updated by just setting the TIMEZONE environment variable and all is fine.
Iocs that were rebooted today had the TIMEZONE variable set in a common startup script that is called before everything else.  Those IOCS seemed to display the correct time but camonitor was reporting the time an hour earlier.  The hardware timing module displayed the time an hour later than it was. The timing system was not rebooted and had the correct time on the hardware link.
We fixed the problem by moving the TIMEZONE setting to the post-startup script.
Has anyone else had similar problems?
RE: Daylight savings time Laznovsky, Michael
Re: Daylight savings time Andrew Johnson
Re: Daylight savings time Lawrence T. Hoff
RE: Daylight savings time Gurd, Pamela A.
Prev: Easy EPICS Installation for the mortal user Ernest L. Williams Jr.
Next: RE: Daylight savings time Laznovsky, Michael
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Easy EPICS Installation for the mortal user Stefan Heim
