Hi- we rebuilt camonitor with EPICS base patched with Andrew Johnson's
DST fix from last week, to fix this same problem.
Mike
-----Original Message-----
From: Thompson, David H. [mailto:[email protected]]
Sent: Monday, March 12, 2007 2:30 PM
To: [email protected]
Subject: Daylight savings time
Something very weird just happened here and we are still trying to figure
out why.
Running iocs were updated by just setting the TIMEZONE environment variable
and all is fine.
Iocs that were rebooted today had the TIMEZONE variable set in a common
startup script that is called before everything else. Those IOCS seemed
to display the correct time but camonitor was reporting the time an hour
earlier. The hardware timing module displayed the time an hour later than
it was. The timing system was not rebooted and had the correct time on the
hardware link.
We fixed the problem by moving the TIMEZONE setting to the post-startup
script.
Has anyone else had similar problems?
- Daylight savings time Thompson, David H.
Re: Daylight savings time Andrew Johnson
<2007>
2025
2026
<2007>
2025
2026
