I think that WIN32 does provide this routine -- at least my quick
check with google seems to imply this.
The vxWorks case is a little trickier. I suppose that someone out
there actually uses the IOC shell rather than the vxWorks shell.
What's' your feeling on weak references?
How about an epicsTzset() macro in some os-dependent header. This
would do nothing on vxWorks and expand to tzset() on all others.
On Mar 13, 2007, at 11:17 AM, Andrew Johnson wrote:
Eric Norum wrote:
Since we're on the topic of time, I'd like to propose the
following change to the IOC shell. This is in the handler
function for the epicsEnvSet command.
epicsEnvSet (name, value);
+ if (strcmp(name, "TZ") == 0) {
+ extern void tzset(void);
+ tzset();
This will ensure that changes to the TZ environment variable (in
an st.cmd file, for example) actually have an effect.
That change is not portable; according to my reference manual
vxWorks doesn't have a tzset() routine, and I have similar doubts
about WIN32. Maybe the correct solution would be to register an OS-
specific command that can set the IOC's timezone data?
The right to be heard does not automatically include
the right to be taken seriously. -- Hubert H. Humphrey
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
- Re: Daylight savings time Andrew Johnson
- Re: Daylight savings time Eric Norum
- Daylight savings time Thompson, David H.
- Re: Daylight savings time Lawrence T. Hoff
<2007>
2025
2026
<2007>
2025
2026
ANJ, 10 Nov 2011 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
