On 14-Mar-07, at 6:59 PM, åæç wrote:
hi, I'v succeeded in building the cross-compiler for RTEMS-mvmv5500
on my PC
in the directory /opt/rtems, my linux shell is tcsh, so I add "set
path=($path /opt/rtems/bin /opt/rtems/powerpc-rtems/bin)" in the
file .cshrc.
Next I'll install EPICS(base-3.14.9), I modified the file
base/configure/CONFIG_SITE with CROSS_COMPILIER_TARGET_ARCH=RTEMS-
mvme5500,
and CROSS_COMPILER_HOST_ARCHS=linux-x86. then I make in the
directory base. so
I find the error:
make -C libCom/test install
make[2]: Entering directory `/home/rtems/base-3.14.9/base/src/
libCom/test'
make -C O.linux-x86 -f ../Makefile TOP=../../../.. T_A=linux-x86
install
make[3]: Entering directory
`/home/rtems/base-3.14.9/base/src/libCom/test/O.linux-x86'
make[3]: Nothing to be done for `install'.
make[3]: Leaving directory
make -C O.RTEMS-mvme5500 -f ../Makefile TOP=../../../.. T_A=RTEMS-
mvme5500 install
`/home/rtems/base-3.14.9/base/src/libCom/test/O.RTEMS-mvme5500'
/usr/local/rtems/rtems-4.7/bin/powerpc-rtems-g++
-B/opt/rtems//powerpc-rtems/mvme5500/lib/ -specs bsp_specs -
qrtems -o
rtemsTestHarness -static -L/home/rtems/base-3.14.9/base/lib/RTEMS-
mvme5500
-mcpu=750 -mmultiple -mstring -mstrict-align -u Init
/opt/rtems//powerpc-rtems/mvme5500/lib/no-dpmem.rel
/opt/rtems//powerpc-rtems/mvme5500/lib/no-mp.rel
/opt/rtems//powerpc-rtems/mvme5500/lib/no-part.rel
/opt/rtems//powerpc-rtems/mvme5500/lib/no-signal.rel
/opt/rtems//powerpc-rtems/mvme5500/lib/no-rtmon.rel
rtemsTestHarness.o epicsCalcTest.o epicsAlgorithmTest.o
epicsMathTest.o
epicsStdioTest.o epicsStringTest.o epicsTimeTest.o epicsThreadTest.o
epicsThreadPriorityTest.o epicsThreadPrivateTest.o epicsExitTest.o
epicsTimerTest.o ringPointerTest.o epicsEventTest.o epicsMutexTest.o
epicsExceptionTest.o epicsMessageQueueTest.o macEnvExpandTest.o
blockingSockTest.o epicsRunLibComTests.o epicsThreadPerform.o
epicsMaxThreads.o buckTest.o -lCom -lm -lrtemsCom -
lrtemscpu -lCom
-lrtemsNfs -lm
/opt/rtems/lib/gcc/powerpc-rtems/4.0.2/../../../../powerpc-rtems/
bin/ld:
cannot find -lrtemsNfsrtem
collect2: ld returned 1 exit status
make[3]: *** [rtemsTestHarness] Error 1
make[2]: *** [install.RTEMS-mvme5500] Error 2
make[2]: Leaving directory `/home/rtems/base-3.14.9/base/src/libCom/
test'
make[1]: *** [libCom/test.install] Error 2
make[1]: Leaving directory `/home/rtems/base-3.14.9/base/src'
make: *** [src.install] Error 2
In fact, on my PC,
bin/ld equals
to /opt/rtems/powerpc-rtems/bin/ld, is it because I've not added
the parameter
"-lrtemsNfs" when I built the cross compiler somewhere? thank you
very much!
For what it's worth, I get a very similar error when the epics build
process is in softIoc:
( i'm compiling on darwin-ppc, EPICS 3.14.8.2, and using RTEMS from
the HEAD cvs branch)
/opt/rtems/bin/i386-rtems-g++ -B/opt/rtems/i386-rtems/pc386/lib/ -
specs bsp_specs -qrtems -o softIoc -static -L../../../lib/RTEMS-
pc386/ -u Init /opt/rtems/i386-rtems/pc386/lib/no-dpmem.rel /
opt/rtems/i386-rtems/pc386/lib/no-mp.rel /opt/rtems/i386-rtems/pc386/
lib/no-part.rel /opt/rtems/i386-rtems/pc386/lib/no-signal.rel /opt/
rtems/i386-rtems/pc386/lib/no-rtmon.rel -Wl,-Ttext,0x100000
softIoc_registerRecordDeviceDriver.o softMain.o -lrecIoc -
lsoftDevIoc -liocsh -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -
lregistryIoc -ldbStaticIoc -lca -lCom -lm -lrtemsCom -lrtemscpu -
lCom -lrtemsNfs -lm
/opt/rtems/lib/gcc/i386-rtems/4.1.1/../../../../i386-rtems/bin/ld:
make[3]: *** [softIoc] Error 1
make[2]: *** [install.RTEMS-pc386] Error 2
make[1]: *** [softIoc.install] Error 2
And yes, I added OP_SYS_CFLAGS += -DOMIT_NFS_SUPPORT to os/
CONFIG_SITE.Common.RTEMS
It looks like librtemsNFS is being linked against regardless of the
previous setting...
Any ideas ??
-- dc
BTW -- Eric, you may want to change OMIT_NFS to OMIT_NFS_SUPPORT in
your EPICS/RTEMS tutorial. I thought that may have been causing the
linking error, but that isn't the case...
- Re: epics compiling problem Eric Norum
- epics compiling problem 师昊礼
<2007>
2025
2026
<2007>
2025
2026
ANJ, 10 Nov 2011 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
