1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epics compiling problem
To: Daron Chabot <[email protected]>
Cc: EPICS <[email protected]>, åæç <[email protected]>
Date: Thu, 15 Mar 2007 06:34:39 -0500
It appears that -lrtemsNfs found its way into configure/os/ CONFIG.Common.RTEMS
Try changing
OP_SYS_LDLIBS += -lrtemsCom -lrtemscpu -lCom -lrtemsNfs -lm
to
OP_SYS_LDLIBS += -lrtemsCom -lrtemscpu -lCom -lm
Or you could install the RTEMS NFS support library. This makes it much easier to support things like autosave and such.
On Mar 14, 2007, at 11:41 PM, Daron Chabot wrote:
On 14-Mar-07, at 6:59 PM, åæç wrote:
hi, I'v succeeded in building the cross-compiler for RTEMS- mvmv5500 on my PC
in the directory /opt/rtems, my linux shell is tcsh, so I add "set
path=($path /opt/rtems/bin /opt/rtems/powerpc-rtems/bin)" in the file .cshrc.
Next I'll install EPICS(base-3.14.9), I modified the file
base/configure/CONFIG_SITE with CROSS_COMPILIER_TARGET_ARCH=RTEMS- mvme5500,
and CROSS_COMPILER_HOST_ARCHS=linux-x86. then I make in the directory base. so
I find the error:
make -C libCom/test install
make[2]: Entering directory `/home/rtems/base-3.14.9/base/src/ libCom/test'
make -C O.linux-x86 -f ../Makefile TOP=../../../.. T_A=linux-x86 install
make[3]: Entering directory
`/home/rtems/base-3.14.9/base/src/libCom/test/O.linux-x86'
make[3]: Nothing to be done for `install'.
make[3]: Leaving directory
make -C O.RTEMS-mvme5500 -f ../Makefile TOP=../../../.. T_A=RTEMS- mvme5500 install
`/home/rtems/base-3.14.9/base/src/libCom/test/O.RTEMS-mvme5500'
/usr/local/rtems/rtems-4.7/bin/powerpc-rtems-g++
-B/opt/rtems//powerpc-rtems/mvme5500/lib/ -specs bsp_specs - qrtems -o
rtemsTestHarness -static -L/home/rtems/base-3.14.9/base/lib/RTEMS- mvme5500
-mcpu=750 -mmultiple -mstring -mstrict-align -u Init
/opt/rtems//powerpc-rtems/mvme5500/lib/no-dpmem.rel
/opt/rtems//powerpc-rtems/mvme5500/lib/no-mp.rel
/opt/rtems//powerpc-rtems/mvme5500/lib/no-part.rel
/opt/rtems//powerpc-rtems/mvme5500/lib/no-signal.rel
/opt/rtems//powerpc-rtems/mvme5500/lib/no-rtmon.rel
rtemsTestHarness.o epicsCalcTest.o epicsAlgorithmTest.o epicsMathTest.o
epicsStdioTest.o epicsStringTest.o epicsTimeTest.o epicsThreadTest.o
epicsThreadPriorityTest.o epicsThreadPrivateTest.o epicsExitTest.o
epicsTimerTest.o ringPointerTest.o epicsEventTest.o epicsMutexTest.o
epicsExceptionTest.o epicsMessageQueueTest.o macEnvExpandTest.o
blockingSockTest.o epicsRunLibComTests.o epicsThreadPerform.o
epicsMaxThreads.o buckTest.o -lCom -lm -lrtemsCom - lrtemscpu -lCom
-lrtemsNfs -lm
/opt/rtems/lib/gcc/powerpc-rtems/4.0.2/../../../../powerpc-rtems/ bin/ld:
cannot find -lrtemsNfsrtem
collect2: ld returned 1 exit status
make[3]: *** [rtemsTestHarness] Error 1
make[2]: *** [install.RTEMS-mvme5500] Error 2
make[2]: Leaving directory `/home/rtems/base-3.14.9/base/src/ libCom/test'
make[1]: *** [libCom/test.install] Error 2
make[1]: Leaving directory `/home/rtems/base-3.14.9/base/src'
make: *** [src.install] Error 2
In fact, on my PC,
/opt/rtems/lib/gcc/powerpc-rtems/4.0.2/../../../../powerpc-rtems/ bin/ld equals
to /opt/rtems/powerpc-rtems/bin/ld, is it because I've not added the parameter
"-lrtemsNfs" when I built the cross compiler somewhere? thank you very much!
For what it's worth, I get a very similar error when the epics build process is in softIoc:
( i'm compiling on darwin-ppc, EPICS 3.14.8.2, and using RTEMS from the HEAD cvs branch)
/opt/rtems/bin/i386-rtems-g++ -B/opt/rtems/i386-rtems/pc386/lib/ - specs bsp_specs -qrtems -o softIoc -static -L../../../lib/RTEMS- pc386/ -u Init /opt/rtems/i386-rtems/pc386/lib/no- dpmem.rel /opt/rtems/i386-rtems/pc386/lib/no-mp.rel /opt/rtems/i386- rtems/pc386/lib/no-part.rel /opt/rtems/i386-rtems/pc386/lib/no- signal.rel /opt/rtems/i386-rtems/pc386/lib/no-rtmon.rel -Wl,-Ttext, 0x100000 softIoc_registerRecordDeviceDriver.o softMain.o -lrecIoc -lsoftDevIoc -liocsh -lmiscIoc -lrsrvIoc - ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca - lCom -lm -lrtemsCom -lrtemscpu -lCom -lrtemsNfs -lm
/opt/rtems/lib/gcc/i386-rtems/4.1.1/../../../../i386-rtems/bin/ld: cannot find -lrtemsNfs
make[3]: *** [softIoc] Error 1
make[2]: *** [install.RTEMS-pc386] Error 2
make[1]: *** [softIoc.install] Error 2
And yes, I added OP_SYS_CFLAGS += -DOMIT_NFS_SUPPORT to os/ CONFIG_SITE.Common.RTEMS
It looks like librtemsNFS is being linked against regardless of the previous setting...
Any ideas ??
-- dc
BTW -- Eric, you may want to change OMIT_NFS to OMIT_NFS_SUPPORT in your EPICS/RTEMS tutorial. I thought that may have been causing the linking error, but that isn't the case...
-- Eric Norum <[email protected]> Advanced Photon Source Argonne National Laboratory (630) 252-4793
Re: epics compiling problem Êïïï
epics compiling problem 师昊礼
Re: epics compiling problem Daron Chabot
Prev: Re: epics compiling problem Daron Chabot
Next: Re: epics compiling problem Êïïï
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
