1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Compiling edm
To: David Dudley <[email protected]>
Cc: [email protected]
Date: Fri, 16 Mar 2007 13:12:04 -0400
look at the content of your edmObjects text file
it's in $EDMOBJECTS or the edm source location if you haven't it set, I think
David Dudley wrote:
OK, have the problems with compiling the Channel Archiver looking like they're resolved.
Now, to move on to other things- edm
I'm trying to setup everything so that the binaries reside in /usr/local/EPICS/bin/linux-x86.
So far, up until edm, I've worked out the configuration so that they all work.
Now, for edm,
The executable installs in /usr/local/EPICS/bin/linux-x86.  That's good.
The libraries install in /usr/local/EPICS/lib/linux-x86.  That's good, also.
The includes install in /usr/local/EPICS/extension/include/edm.  Shouldn't they have gone into /usr/local/EPICS/include?
When you try to start the program, you get:
home/daviddu/local/src/EPICS/extensions/src/edm/baselib/O.linux-x86/libEdmBase.so: cannot open shared object file: No such file or directory
Where'd that come from? libEdmBase.so and libEdmBase.a are in /usr/local/EPICS/lib/linux-x86.
Doing an ldd edm gives me:
ldd edm
        linux-gate.so.1 =>  (0xffffe000)
        libEdmBase.so => /usr/local/EPICS/lib/linux-x86/libEdmBase.so (0x6fdeb000)
        libcfcaa62e-8199-11d3-a77f-00104b8742df.so => /usr/local/EPICS/lib/linux-x86/libcfcaa62e-8199-11d3-a77f-00104b8742df.so (0x6fce3000)
        lib114135a4-6f6c-11d3-95bc-00104b8742df.so => /usr/local/EPICS/lib/linux-x86/lib114135a4-6f6c-11d3-95bc-00104b8742df.so (0x6fcd8000)
        libca.so => /usr/local/EPICS/lib/linux-x86/libca.so (0x6fc7c000)
        libCom.so => /usr/local/EPICS/lib/linux-x86/libCom.so (0x6fc37000)
All those files DO exist in /usr/local/EPICS/lib/linux-x86.
The directory it's trying to load from however, it doesn't exist.
David Dudley
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
-- Matthieu Bec Gemini Observatory Tel: +56 51 205785 Colina El Pino S/N Fax: +56 51 205650 La Serena, Chile
Attachment: smime.p7s
Description: S/MIME Cryptographic Signature
Compiling edm David Dudley
Prev: Compiling edm David Dudley
Next: Re: Compiling edm Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
