1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Compiling edm
To: David Dudley <[email protected]>
Cc: [email protected]
Date: Fri, 16 Mar 2007 13:15:15 -0400
On Mar 16, 2007, at 12:48 , David Dudley wrote:
OK, have the problems with compiling the Channel Archiver looking like they're resolved.
Now, to move on to other things- edm
I'm trying to setup everything so that the binaries reside in /usr/ local/EPICS/bin/linux-x86.
Usually, EPICS 'base' and 'extensions' have their own subtree and don't end up in the same bin,lib,include,doc,...
The includes install in /usr/local/EPICS/extension/include/edm. Shouldn't they have gone into /usr/local/EPICS/include?
Exactly the thing: extensions/include (and usually also a base/include).
When you try to start the program, you get:
home/daviddu/local/src/EPICS/extensions/src/edm/baselib/O.linux-x86/ libEdmBase.so: cannot open shared object file: No such file or directory
Where'd that come from? libEdmBase.so and libEdmBase.a are in /usr/ local/EPICS/lib/linux-x86.
You tell EDM where to load those via and env. variable EDMOBJECTS that points to a file which lists the objects and shared libs where they reside.
edm/setup/setup.sh is meant to help to create those files
and set the env. vars, but I think most sites end up
doing something else manually to pick which objects they
want to use.
-Kay
Compiling edm David Dudley
Prev: Re: Compiling edm Matthieu Bec
Next: Re: Compiling edm John Sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
