OK, so sometimes I'm my own worst enemy.
I hadn't completely deleted an old installation of edm, and the
edmObjects file was pointing to the old entries.
I deleted the stuff and recreated it, and it works great.
Problems just keep disappearing. What am I to do????
david
>>> Kay-Uwe Kasemir <[email protected]> 3/16/2007 12:15 PM >>>
On Mar 16, 2007, at 12:48 , David Dudley wrote:
> OK, have the problems with compiling the Channel Archiver looking
> like they're resolved.
> Now, to move on to other things- edm
> I'm trying to setup everything so that the binaries reside in /usr/
> local/EPICS/bin/linux-x86.
Usually, EPICS 'base' and 'extensions' have their own subtree and
don't
end up in the same bin,lib,include,doc,...
> The includes install in /usr/local/EPICS/extension/include/edm.
> Shouldn't they have gone into /usr/local/EPICS/include?
Exactly the thing: extensions/include (and usually also a
base/include).
> When you try to start the program, you get:
> home/daviddu/local/src/EPICS/extensions/src/edm/baselib/O.linux-x86/
> libEdmBase.so: cannot open shared object file: No such file or
> directory
> Where'd that come from? libEdmBase.so and libEdmBase.a are in /usr/
> local/EPICS/lib/linux-x86.
You tell EDM where to load those via
and env. variable EDMOBJECTS that points to a file which lists
the objects and shared libs where they reside.
edm/setup/setup.sh is meant to help to create those files
and set the env. vars, but I think most sites end up
doing something else manually to pick which objects they
want to use.
-Kay
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
Re: Compiling edm John Sinclair
Accessing Date and Time information David Dudley
<2007>
2025
2026
<2007>
2025
2026
