1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Accessing Date and Time information
To: <[email protected]>
Date: Fri, 16 Mar 2007 15:29:30 -0500
Is there a method that allows access of Date and Time information from
inside the database?
I need to set the clocks on some remote devices, and they are all
attached through Modbus.  I need to preset a set of registers and then
trigger a 'load' command on the remote.
David
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
Re: Accessing Date and Time information Andrew Johnson
Prev: Re: Compiling edm David Dudley
Next: date format Graham Waters
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Accessing Date and Time information Andrew Johnson
