1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Timed Execution
To: tech talk <[email protected]>
Date: Tue, 20 Mar 2007 08:45:12 -1000
Kay-Uwe Kasemir wrote:
On Mar 19, 2007, at 17:12 , David Dudley wrote:
Is there a way to:
1. Set a particular database block to scan at a specific time?
Hi Dave:
There is no simple building block like a "run-at" record.
I had a similar question some time ago,
and when you search tech-talk, you might still find the answers.
Things one can do:
1) run a 'cron' job on the host that basically performs a 'caput'
   to some PV which then triggers stuff.
   Trivial to set up, but then you depend on the host to trigger
   the IOC.
you can also run a cron job (spawn a process) on the IOC (we do that on some of ours).
Aloha,
Maren
Re: Timed Execution Pete Jemian
Timed Execution David Dudley
Re: Timed Execution Kay-Uwe Kasemir
Prev: Re: Timed Execution Andrew Johnson
Next: Re: Timed Execution Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Timed Execution Kay-Uwe Kasemir
