1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Timed Execution
To: tech talk <[email protected]>
Date: Tue, 20 Mar 2007 09:28:04 -0400
On Mar 19, 2007, at 17:12 , David Dudley wrote:
Is there a way to:
1. Set a particular database block to scan at a specific time?
Hi Dave:
There is no simple building block like a "run-at" record.
I had a similar question some time ago,
and when you search tech-talk, you might still find the answers.
Things one can do:
1) run a 'cron' job on the host that basically performs a 'caput'
   to some PV which then triggers stuff.
   Trivial to set up, but then you depend on the host to trigger
   the IOC.
2) Andrew Johnson had a device support module that periodically
   causes a record to do something. As far as I remember, it's used
   to basically print a periodic time stamp to the console, which helps
   the debug port logger because now you have some idea if the
   IOC is still alive, plus you get time stamps.
3) You compute times yourself within a sequence (SNL) program.
   Below is an example of what I do to schedule stuff at some
   specific hour:minute + N * period each day.
-Kay
/* Determine delay in seconds until the next arrival
* of target hour:minutes + multiple of period_sec
* hour: 0..23
* minute: 0..59
* period_sec: >=1
static long determine_sleep_seconds(int hour, int minute, int period_sec)
epicsTimeStamp now_ts;
struct tm tm;
unsigned long nano;
long now_sec, pivot, goal;
long sleep_sec;
if (period_sec < 1)
printf("Schedule: Invalid period of %d seconds, correcting to 24 hours\n", period_sec);
period_sec = 24*60*60;
epicsTimeGetCurrent(&now_ts);
epicsTimeToTM(&tm, &nano, &now_ts);
now_sec = tm.tm_hour*60*60 + tm.tm_min*60 + tm.tm_sec;
printf("\nNow: %02d:%02d:%02d (%ld seconds)\n", tm.tm_hour, tm.tm_min, tm.tm_sec, now_sec);
printf("Schedule: %02d:%02d + N* %g minutes\n", hour, minute, period_sec/60.0);
    /* Calculation of the next time (goal) */
    pivot = hour*60*60 + minute*60;
    /* Correction to assert pivot <= 'now' */
    if (pivot > now_sec)
        pivot -= (1 + (pivot - now_sec)/period_sec) * period_sec;
    goal = (1 + (now_sec - pivot)/period_sec) * period_sec + pivot;
    /* Delay in seconds until then */
    sleep_sec = goal - now_sec;
    printf("Need to wait %ld seconds, until ", sleep_sec);
    show_seconds_as_time(goal);
    return sleep_sec;
ss Schedule /* Schedule Tests */ { ...
    state schedule /* Determine next runtime */
        when (ctl == 0)
        {} state disabled /* when disabled */
when ()
%% pVar->sleep_secs = determine_sleep_seconds(
%% (int)pVar->hour, (int)pVar->minute, (int)(pVar- >period*60));
} state wait /* when have next runtime */
    state wait /* Wait */
        when (efTestAndClear(hour_mon) ||
              efTestAndClear(minute_mon) ||
              efTestAndClear(period_mon) ||
              ctl == 0)
        {} state schedule /* when setup was changed */
        when (cmd)
            cmd = 0;
        } state trigger /* when manual trigger */
        when (delay(sleep_secs))
        {} state trigger /* when at scheduled time */
Re: Timed Execution Maren Purves
Timed Execution David Dudley
Prev: .cmd file downloading problem 师昊礼
Next: EPICS_TIMEZONE, TIMEZONE, vxWorks daylight saving Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Timed Execution David Dudley
Next: Re: Timed Execution Maren Purves
