hi, there is an error about downloading the st.cmd(OS is RTEMS). in the NVRAM
configuration, I fill the "Command Line Parameters" with
"INIT=/home/shl/psApp/iocBoot/iocmvme5500/power_supply.cmd",but something
wrong appears as follows:
Till Straumann, Stanford/SLAC/SSRL 2002
See LICENSE file for licensing info
Trying to synchronize NTP...OK
Loading as 'shl' from '192.168.20.162' using RSH
Trying symfile 'BUILTIN', system script '/tmp/rshcpya00001'
Type 'cexpsh.help()' for help (no quotes)
Trying user script '/home/shl/psApp/iocBoot/iocmvme5500/power_supply.cmd':
Change Dir to '/home/shl/psApp/iocBoot/iocmvme5500/'
'power_supply.cmd':
opening script file: No such file or directory
Cexp>
why can't it find my .cmd file? (the file indeed lies in the directory, my
TFTP path is /home/shl/tftpboot, and my NFS shared directory is
/home/shl/psApp/iocBoot/iocmvme5500/, but here I use the absolute path)
another question, in the NVRAM configuration, one can pass a parameter to
application by filling "Command Line Parameters" with "NAME=value". if I won't
pass a parameter, how can I cancel the parameter? thanks a lot!
best regards
Haoli Shi
- Re: .cmd file downloading problem Till Straumann
Timed Execution David Dudley
Re: Timed Execution Kay-Uwe Kasemir
<2007>
2025
2026
Re: Timed Execution Andrew Johnson
<2007>
2025
2026
