1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: .cmd file downloading problem
To: åæç <[email protected]>
Cc: [email protected]
Date: Thu, 22 Mar 2007 13:21:43 -0700
Hi.
Let me first say that I'm not sure
'tech-talk' is the right forum to
address with this question which is
rather specific about the mvme5500 RTEMS
BSP and related software but has nothing
to do with EPICS.
åæç wrote:
hi, there is an error about downloading the st.cmd(OS is RTEMS). in the NVRAM
configuration, I fill the "Command Line Parameters" with
"INIT=/home/shl/psApp/iocBoot/iocmvme5500/power_supply.cmd",but something
wrong appears as follows:
Till Straumann, Stanford/SLAC/SSRL 2002
See LICENSE file for licensing info
Trying to synchronize NTP...OK
Loading as 'shl' from '192.168.20.162' using RSH
Trying symfile 'BUILTIN', system script '/tmp/rshcpya00001'
Type 'cexpsh.help()' for help (no quotes)
Trying user script '/home/shl/psApp/iocBoot/iocmvme5500/power_supply.cmd':
Change Dir to '/home/shl/psApp/iocBoot/iocmvme5500/'
'power_supply.cmd':
opening script file: No such file or directory
Cexp>
why can't it find my .cmd file? (the file indeed lies in the directory, my
TFTP path is /home/shl/tftpboot, and my NFS shared directory is
/home/shl/psApp/iocBoot/iocmvme5500/, but here I use the absolute path)
It seems you use RSH for downloading the
operating system. There is no RSH support
however for downloading other pieces such
as scripts or loadable objects etc.
You must use TFTP or (more convenient) NFS.
The path to the '.cmd' file must contain
information about
 a) the remote file-system type (TFTP vs. NFS)
 b) the server
 c) the remote path
E.g., you could say
INIT=/TFTP/123.4.56.8/psApp/iocBoot/iocmvme5500/power_supply.cmd
or
INIT=nfsserver:/home/shl:psApp/iocBoot/iocmvme5500/power_supply.cmd
another question, in the NVRAM configuration, one can pass a parameter to application by filling "Command Line Parameters" with "NAME=value". if I won't pass a parameter, how can I cancel the parameter?
You just leave 'command line parameters'
empty or let 'INIT=<path>' be the only
<NAME>=<value> pair...
HTH -- Till
thanks a lot!
best regards Haoli Shi
.cmd file downloading problem 师昊礼
Prev: Re: vxWorks, IP-OCTAL-232, interrupt, and reboot John Dobbins
Next: vxWorks 5.5.2 (Tornado 2.2.2) on MVME6100 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: .cmd file downloading problem 师昊礼
Next: Re: .cmd file downloading problem Kate Feng
