1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Another Dual NICs question
To: "Emmanuel Mayssat" <[email protected]>, <[email protected]>
Date: Tue, 20 Mar 2007 21:45:03 -0500
Hi Emmanuel,
The CA Reference Manual says in regards to
export EPICS_CAS_INTF_ADDR_LIST=192.168.168.167
"In R3.14 and previous releases the CA server employed by iocCore does not implemet this feature."
I think you may instead need to tell the clients what address to look at:
export EPICS_CA_ADDR_LIST=192.168.168.167
EPICS_CA_AUTO_ADDR_LIST=NO
Instead of a single IOC you could set EPICS_CA_ADDR_LIST to the broadcast address of the subnet on the NIC you want to use.
Sent: Tue 3/20/2007 6:09 PM
To: [email protected]
Subject: Another Dual NICs question
Hello,
First, I would like to mention that I looked in the mailing list
archive. But although that question was raised in the past, the answer I
read were not satisfying.
Basically I want to start an IOC server on a dual homed ( 2 different
subnets) host. When I do a caget, I get:
[bluice@cxs0bl1 usr]$ caget bluiceHost:aiExample
bluiceHost:aiExample           4
CA.Client.Exception...............................................
    Warning: "Identical process variable names on multiple servers"
    Context: "Channel: "bluiceHost:aiExample", Connecting to:
192.168.168.167:5064, Ignored: 192.168.1.204:5064"
    Source File: ../cac.cpp line 1224
    Current Time: Tue Mar 20 2007 09:56:15.161158000
After reading the CA reference manual, it seems that I just need to set
But that doesn't work.
I am using R3.14.8.2
Note: I don't want to fix the client side (i.e. caget environment ), but
rather the server side (environment where the ioc is started and
running).
Emmanuel
RE: Another Dual NICs question Emmanuel Mayssat
Prev: Re: EPICS/BluIce gateways Wayne Lewis
Next: RE: Another Dual NICs question Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Another Dual NICs question Emmanuel Mayssat
