1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Another Dual NICs question
To: Emmanuel Mayssat <[email protected]>
Cc: [email protected]
Date: Wed, 21 Mar 2007 19:07:40 +0100
Mark is right: There are still two CA servers in EPICS base.
rsrv - The old server (C) that is running as part of the iocCore
cas - The new server (C++) that is running as part of several host-side applications (e.g. CA-Gateway)
The new server implements the additional configuration options (which are heavily used by e.g. the CA-Gateway), the old server doesn't (so the IOC can't make use of it).
Ralph
For your application, using a virtualization layer (VMware, xen or similar) that provides a virtual machine with only one of the NICs may be feasable.
Emmanuel Mayssat wrote:
"In R3.14 and previous releases the CA server employed by iocCore does not implement this feature."
Isn't R3.14(.9) the latest release of the EPICS base?
It is according to http://www.aps.anl.gov/epics/index.php
In other words, are you telling me that this is documented but not
implemented yet?
Another Dual NICs question Emmanuel Mayssat
RE: Another Dual NICs question Mark Rivers
RE: Another Dual NICs question Emmanuel Mayssat
Prev: RE: Another Dual NICs question Mark Rivers
Next: vxWorks, IP-OCTAL-232, interrupt, and reboot John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: EPICS/BluIce gateways Emmanuel Mayssat
