1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: String In and Output records
To: David Dudley <[email protected]>
Cc: [email protected]
Date: Tue, 27 Mar 2007 14:02:55 -0500
David,
VAL fields of string records are hardcoded to be 40 characters.  I would use a waveform record, data type = char, length = 8.  This will always return a character array ... size 8.
  Ned
David Dudley wrote:
When you setup a String input or output record, how do you limit the
length, or can you?
I need to setup a String Output that outputs 8 characters.  no more, no
less.
David Dudley
BEGIN:VCARD VERSION:2.1 X-GWTYPE:USER FN:David Dudley TEL;WORK:880-3740 ORG:;MIS TEL;PREF;FAX:880-3741 EMAIL;WORK;PREF;NGW:[email protected] N:Dudley;David END:VCARD
String In and Output records David Dudley
Prev: String In and Output records David Dudley
Next: Re: What's wrong if a PV with DISA=1 still processes? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Agilent 89410A Peter Mueller
