1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: What's wrong if a PV with DISA=1 still processes?
To: Dayle Kotturi <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 27 Mar 2007 14:05:08 -0500
Hi Dayle,
Dayle Kotturi wrote:
I am using SNL to manage the operational mode of a phase and amplitude ctrllr. Mode is either CALIBRATING or RUNNING. When RUNNING, I attempt to disallow changes to gain setting via entry{} clause of state RUNNING where I set DISA to 1 for the gain PV. I can see DISA field is set correctly to 1 via dbpr. On the EDM GUI, however, I am still able to change the gain. The gain is a longout record.
From the doc, I understand that when DISA==DISV==1, processing should
not occur. Why does it?
Are you sure that your gain is actually being sent out to the hardware when DISA==DISV? What disabling the record means is that the record's process routine will not run, thus no device support output or alarm checking, DRVH/DRVL clipping etc. However this does not stop CA from being able to write to the record's modifiable fields, nor any CA monitors from seeing those updated field values (since a ca_put automatically causes a monitor event on the field that is changed).
HTH,
- Andrew
The right to be heard does not automatically include
the right to be taken seriously. -- Hubert H. Humphrey
vxWorks, IP-OCTAL-232, interrupt, and reboot John Dobbins
What's wrong if a PV with DISA=1 still processes? Dayle Kotturi
Prev: Re: String In and Output records Ned D. Arnold
Next: Re: What's wrong if a PV with DISA=1 still processes? Ned D. Arnold
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: What's wrong if a PV with DISA=1 still processes? Dayle Kotturi
