1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: drvTS
To: "Korhonen Timo" <[email protected]>
Cc: <[email protected]>, "Kalantari Babak" <[email protected]>
Date: Wed, 28 Mar 2007 11:53:36 +0100
> From: Korhonen Timo [mailto:[email protected]]
> Denison, PN (Peter) wrote:
> > I was searching for drvTS yesterday, and couldn't find it for
versions
> > of base after 3.14.8
> > I know that it was removed from base, and I found this section of
the
> > release notes: "These are removed from EPICS base. The version that
> > previously came with base was the version that worked with the APS
> > event system. It is available from APS. The version that works with
> > the newer event systems that evolved from the APS system is
available
> > from the Swiss Light Source."
> > As we are using the "newer event systems", I guess we'll need the
SLS
> > version. Can anyone help me get hold of it - Timo?
> If you _really_ want it, we can give you 'our' version of
> drvTS. However, if you are using 3.14., I would recommend
> moving to GeneralTime. We have a GeneralTime time driver for
> the MicroResearch EVR/EVG( although it may need some minor
> modifications for the 200-series EVRs.). We have no
> intentions to support drvTS further. GeneralTime is a big
> improvement over drvTS.
I was planning to move to generalTime eventually, and I'm pleased to
hear that it's ready to try.
> > I assume that this is orthogonal to generalTime, and I'll still need
a
> > version of drvTS to support the MicroResearch EVR, even if I were to
> > get hold of generalTime (which I have managed to find a link for)?
We
> > have the drivers for the EVR, but they don't compile against
> > base-3.14.8 because drvTS is missing.
> I would like to state it once again:
> the drvTS will not be supported anymore and will be replaced
> by General Time.
>  (as discussed in the last EPICS meeting. It took us a while to
> implement the replacement but at least a first version exists
> since a few months.)
> There are still a few issues to be sorted out, but we have tested the
> GeneralTime (event) driver extensively.
> We have sent our GeneralTime package (GT base + our eventTime
> driver) to Andrew and a few other people for them to take a look
> at it and to do the necessary preparations for integrating it.
> We can of course send you the same package, and try to help you
> to get started. There will also be a talk in the Epics meeting in
> Hamburg (by Babak) and Babak will be there for detail discussions.
I've got hold of the 1-2-0 release from a link recently posted to
tech-talk by David.
By "our eventTime driver", do you mean the MicroResearch EVR driver, or
another intermediate driver that is also required?
> I do not immediately remember what the dependency between the EVR
> drivers and drvTS is, but Babak could probably tell it right away.
> Let us take a look at it (however, this week there is a SLS shutdown
> and people are pretty busy with maintenance and testing new stuff.)
I've done a bit more digging and now understand a little more. The only
dependency seemed to be on TSepochUnixToEpics(), which I've replaced
with a little rearrangement and epicsTimeFromTimespec(). There were also
trivially some header files that had been included by drvTS.h as well.
It now builds, but I haven't yet done the calls to iocClockRegister to
make it supply the IOC time. Is that sufficient to make it work in the
absence of drvTS and generalTime, or do I need at least one of them?
(provided of course that the timing system stays alive - I know that
I'll have no fallback until I implement generalTime)
Peter Denison, Senior Software Engineer
Diamond Light Source Ltd., Diamond House, Chilton, Didcot, Oxon, OX11
0DE
Tel: +44 1235 778511
Re: drvTS Korhonen Timo
Prev: Re: drvTS Korhonen Timo
Next: Agilent 89410A Peter Mueller
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: symbDev in 3.14? Sue Witherspoon
