Denison, PN (Peter) wrote: If you _really_ want it, we can give you 'our' version of drvTS. However,I was searching for drvTS yesterday, and couldn't find it for versions of base after 3.14.8 if you are using 3.14., I would recommend moving to GeneralTime. We have a GeneralTime time driver for the MicroResearch EVR/EVG( although it may need some minor modifications for the 200-series EVRs.). We have no intentions to support drvTS further. GeneralTime is a big improvement over drvTS. I would like to state it once again:I assume that this is orthogonal to generalTime, and I'll still need a version of drvTS to support the MicroResearch EVR, even if I were to get hold of generalTime (which I have managed to find a link for)? We have the drivers for the EVR, but they don't compile against base-3.14.8 because drvTS is missing. the drvTS will not be supported anymore and will be replaced by General Time. (as discussed in the last EPICS meeting. It took us a while to implement the replacement but at least a first version exists since a few months.) There are still a few issues to be sorted out, but we have tested the GeneralTime (event) driver extensively. We have sent our GeneralTime package (GT base + our eventTime driver) to Andrew and a few other people for them to take a look at it and to do the necessary preparations for integrating it. We can of course send you the same package, and try to help you to get started. There will also be a talk in the Epics meeting in Hamburg (by Babak) and Babak will be there for detail discussions. I do not immediately remember what the dependency between the EVR drivers and drvTS is, but Babak could probably tell it right away. Let us take a look at it (however, this week there is a SLS shutdown and people are pretty busy with maintenance and testing new stuff.) best regards, Timo -- Timo Korhonen PSI (Paul Scherrer Institut, http://www.psi.ch) CH-5232 Villigen PSI tel + 41- 56 3103262 fax + 41 - 56 310 3383 e-mail: [email protected]
| ANJ, 10 Nov 2011 |
Home
News
About
Talk
Base
Modules
Extensions
