Emmanuel,
Here's a description of the DISP field from the record reference manual.
DISP Disable putFields If this field is set to TRUE, then all
dbPutFields (normally issued by channel access) directed to this record are
ignored except to the field DISP itself.
We used the permissive record back in early EPICS days. As Andrew mentioned,
it was used for communicating between two or more programs. We used it
primarily to communicate to/from the sequencer, but I haven't used it in
application for many years.
Deb
Deb Kerstiens
LANL AOT_IC
[email protected]
- vxWorks, IP-OCTAL-232, interrupt, and reboot John Dobbins
- What's wrong if a PV with DISA=1 still processes? Dayle Kotturi
- Re: What's wrong if a PV with DISA=1 still processes? Ned D. Arnold
- DISP and permissive record. Emmanuel Mayssat
Re: DISP and permissive record. Andrew Johnson
Re: drvTS Korhonen Timo
<2007>
2025
2026
Re: What's wrong if a PV with DISA=1 still processes? Till Straumann
<2007>
2025
2026
ANJ, 10 Nov 2011 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
