On Tue, 2007-03-27 at 14:10 -0500, Ned D. Arnold wrote:
> A better solution might be to use Channel Access security rules such
> that writes to GAIN are not allowed when RUNNING. This stops CA from
> writing to VAL and EDM should show you that writing is disallowed.
What are you referring to here? The DISP field?
I just remembered that there is a permissive record in the record
manual. What are the typical application for such a record?
Emmanuel
- Re: DISP and permissive record. Andrew Johnson
- Re: DISP and permissive record. Debora Kerstiens
- vxWorks, IP-OCTAL-232, interrupt, and reboot John Dobbins
- What's wrong if a PV with DISA=1 still processes? Dayle Kotturi
- Re: What's wrong if a PV with DISA=1 still processes? Ned D. Arnold
Re: What's wrong if a PV with DISA=1 still processes? Till Straumann
<2007>
2025
2026
<2007>
2025
2026
