1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: DISP and permissive record.
To: Emmanuel Mayssat <[email protected]>
Cc: "Ned D. Arnold" <[email protected]>, Dayle Kotturi <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Tue, 27 Mar 2007 17:47:41 -0500
Hi Emmanuel,
Emmanuel Mayssat wrote:
On Tue, 2007-03-27 at 14:10 -0500, Ned D. Arnold wrote:
A better solution might be to use Channel Access security rules such that writes to GAIN are not allowed when RUNNING. This stops CA from writing to VAL and EDM should show you that writing is disallowed.
What are you referring to here? The DISP field?
If you've never heard of Channel Access security rules I suggest you sit down with Chapter 8 (Access Security) of the IOC Application Developers' Guide sometime. They have nothing to do with the DISP field.
I just remembered that there is a permissive record in the record
manual. What are the typical application for such a record?
http://www.aps.anl.gov/epics/wiki/index.php/RRM_3-13_Permissive
The Permissive record was designed to facilitate interlocked communication between two programs. It has not been converted to R3.14 to my knowledge, and I'm not aware of anyone who is actually using it. There have been at least a couple more recent records designed for vaguely similar activities such as the APS runControl record and the CAD/CAR/SIR records from Gemini and Observatory Sciences.
- Andrew
The right to be heard does not automatically include
the right to be taken seriously. -- Hubert H. Humphrey
vxWorks, IP-OCTAL-232, interrupt, and reboot John Dobbins
What's wrong if a PV with DISA=1 still processes? Dayle Kotturi
Re: What's wrong if a PV with DISA=1 still processes? Ned D. Arnold
DISP and permissive record. Emmanuel Mayssat
Prev: DISP and permissive record. Emmanuel Mayssat
Next: Re: DISP and permissive record. Debora Kerstiens
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
